| Posted: Aug 9 2008, 09:41 PM |
| CODE | Build 29958 (1.8.4, stable): [August 9, 2008] [features added] * Export > Raw Audio defaults to .mp3 extension when the audio track is in MPEG layer III format. * Capture: Optimized display code slightly when main window is minimized.
[bugs fixed] * Fixed another crash with uncompressed paletted video. * Fixed several dialogs that had placeholder icons. * "Open shared job list" dialog now shows the correct title. * Fixed shared job list sync errors when using a job file originally saved from non-shared mode. * Image sequence export jobs didn't reload properly. * Perspective filter no longer shows garbage preview frame before a frame is sampled. * Capture: The "track active window client area" setting of the screencap driver is now saved properly. * Capture: Fixed crash when exiting Set Custom Format dialog with no width or height selected. * DV: Fixed noise when audio switches between 12-bit and 16-bit encoding. * D3D: Fixed wrong-boxing of video when source frame is YCbCr and larger than screen.
[regressions fixed] * Video > Select Range dialog now works again. It now sets the selection. | |
| picaso |
Posted: Sep 1 2008, 01:49 AM |
Ok, I have not tried it yet ,but will.
I just wanted to know, You know how Virtualdub does not save settings for "codecs used" for video , and "codecs used" for Audio ?
When I do an edit ,to a vid , each time I edit a new vid , I must select which codec to use for Audio and Video, otherwise by default Virtualdub selects the first codec ontop of the codec lists. Am I right ?
Will this ever become optional so that VD remembers last/previuos codecs used ?? |
| foxidrive |
| Posted: Sep 1 2008, 08:23 PM |
You can setup and then save the settings from the File menu and load that settings file with a command line switch. |
