| Posted: Jul 19 2008, 09:10 PM |
| CODE | Build 29883 (1.8.2, stable): [July 19, 2008] [features added] * JobControl: Job control dialog now shows machine name and PID. * Filters: Added mOutputFrame field to VDXFilterStateInfo for reliable frame rate change operations.
[bugs fixed] * The window maximized state is also saved in addition to position/size. * Reopening a video file that has multiple audio streams no longer loses secondary streams. * Scene detection now works again when RGB565 or a YCbCr format is selected as the input format. * Input preview didn't start in the correct place if a frame rate changing filter was present. * The picture format tokens (p/P) in the timestamp UI options sometimes started from 1 instead of 0 due to rounding errors. * Fixed stall at frame 0 when attempting to render with a VBR audio stream that has an extremely low data rate. * Filters: Fixed field order swapping in bob doubler. * JobControl: Fixed distributed list sync errors due to mixing up revision numbers when switching job files. * Capture: Process and thread priority are now restored after capture rather than being unilaterally reset to normal/normal.
[regressions fixed] * Fixed audio desyncs with frame rate conversion. * Type-1 DV audio works again. * The video.SetRange() command works in unadjusted source milliseconds again. * Fixed read errors with AVI files that have frames out of order in the index. (Note: This is rare, and often actually a sign of a corrupt index.) * Filters: Filter sampling didn't work correctly if there was a conversion required at the start of the filter. * Capture: Fixed crash in screencap driver with OpenGL capture disabled. | |
| Barough |
| Posted: Jul 20 2008, 05:01 AM |
Thnx for the new Stable release
| Posted: Jul 20 2008, 09:17 AM |
Go to 1.8.3 -- 1.8.2 has a dumb bug in its startup code. |
| Barough |
| Posted: Jul 20 2008, 01:48 PM |
Thnx for the heads up
