| Posted: Dec 10 2007, 05:02 AM |
| CODE | Build 28312 (1.7.7, stable): [December 9, 2007] [bugs fixed] * Improved accuracy of "set so audio and video durations match" for short clips. * Fixed vertical chroma positioning errors when converting to 4:2:0 or 4:1:0 YCbCr. * PluginSDK: Direct stream copy from a plugin audio stream caused dwStreamSize in the AVI to be set incorrectly. * PluginSDK: Fixed crash when using plugin to load a file with an audio stream that isn't AVI compatible. * Capture: When "wait for OK" was enabled with a DirectShow driver, time spent in the dialog was counted against a time stop condition. * Capture: Fixed crash when an error occurs while starting capture with a custom hotkey.
[regressions fixed] * "Save segmented AVI" no longer crashes when only video is enabled. * Prohibit zero for frame rate adjustment. * Filters: The error return from runProc is ignored again for compatibility with earlier versions of VirtualDub; this fixes some video filters that broke in the 1.7.x series. * D3D: Fixed a display change related crash.
| stephanV |
| Posted: Dec 11 2007, 05:30 PM |
Hi.
Again thanks for your efforts on VirtualDub. It does wonders!
| DarrellS |
| Posted: Dec 12 2007, 11:11 PM |
Where did "Audio From Other File..." go?
It's back to "Wave Audio..." only. |
| squid_80 |
| Posted: Dec 13 2007, 03:47 AM |
Audio from other file is an option in 1.7.X, not the main branch. |
| Posted: Dec 13 2007, 04:49 AM |
That's correct -- that functionality hasn't made it into an official release yet, just test releases. |
| DarrellS |
| Posted: Dec 13 2007, 05:47 AM |
OK, I thought 1.7.7 was going to be official stable release of 1.7.X.
1.7.X is pretty much all I use now. |
