Virtualdub 1.6.15 Released, tadaaaa!
stephanV
Posted: May 29 2006, 09:32 AM
link
Build 24442 (1.6.15, stable): [May 28, 2006]
  [bugs fixed]
  * Added workaround for BMP files with bad BITMAPINFOHEADER::bfSize fields.
  * Added workaround for TARGA files with run-length encodings that span
    scanlines (not allowed by spec).
  * Fixed abort confirm and disk I/O options not saving consistently.
  * Warnings, particularly the VBR warning, are now displayed after opening a
    file through command-line arguments.
  * Fixed crash when VirtualDub.jobs file is not writable.
  * Fixed crash when dealing with RLE4 and RLE8 encoded videos.
  * Fixed stride error with odd-width TARGA files.
  * Fixed occasionally oversized wave format structure being written when
    decompressing audio.
  * The "autoselect" input color format now also tries 256 color mode in order
    to support old codecs that can only output this format.
  * Capture: Switched graph construction code in DirectShow layer to prefer
    Video Renderer over VMR to avoid Direct3D.
  * AMD64: Fixed one-byte PUSH/POP instructions reporting incorrect registers
    in disassembly.
  * AMD64: Fixed field swap filter.
Thanks phaeron!
useful links:
0 replies since May 29 2006, 09:32 AM Track this topic | Email this topic | Print this topic
