| Posted: Feb 27 2006, 02:58 AM |
VirtualDub 1.6.13 has been released. It is not yet up on the download page or main website, since I have to wait for the SourceForge mirroring system to propagate the files, but right now you can get to it from the file download page, and it should be mirrored in 24 hours.
| CODE | Build 24390 (1.6.13, experimental): [February 26, 2006] [features added] * Added support for pass-through of PCM audio that has more than 2 channels. * Added limited support for correct seeking when reading AVI files with VBR audio. The VBR audio still cannot be written as such in Direct mode, however. * Added /hexedit command-line switch. * Converted help file to HTML Help (.chm) format. * Hex editor: Open dialog now persists its "open as read-only" setting. * Hex editor: Added keyboard shortcuts for open and save. * Hex editor: Stopping a RIFF scan still shows partial info. * Capture: Increased speed of audio resampler. * Capture: Added ability to fine-tune channel tuning. * Capture: The command-line /capstart option can now trigger a capture for shorter than one minute using an "s" prefix, i.e. 10s. * Capture: The "hide on capture" setting is now auto-saved.
[bugs fixed] * JPEG files lacking a JFIF or Exim header were not recognized. * Error dialogs from Windows on disk or DLL load errors are now suppressed for command-line invocations. * TARGA files with a width of 1 were not written correctly. * Previewing an advanced audio filter graph using a format that the sound card could not play led to a deadlock. * Attempting to use audio conversion or resampling with an input PCM format that was not mono/stereo 8/16-bit led to a crash. For now, attempting to do this now throws an error. * Fixed redraw problems when adjusting the cropping settings of a video filter that is already being cropped on input. * Added workaround for broken AVI files that have MP3 audio streams with nBlockAlign=0. * Fixed audio stream sometimes being truncated when the audio stream's nBlockAlign doesn't match its dwSampleSize value. * Tabbing now works within the border fields of the cropping dialogs. * 16-bit (565) format was using a bogus bit mask for the green channel. * Added workaround for livelock when using Creative MP3 codec caused by strange PostThreadMessage() call within that codec. * When a video filter failed with an error during filter preview, the error was not displayed. * Fixed clicking in DV type-1 audio decoding when switches in audio sampling rate are encountered. * Added code to prevent confusion when multiple MP3 audio codecs are installed. * Capture: Video timing adjustment now defaults to enabled. * Capture: Cropping dialog did not always display live video properly if preview acceleration wasn't enabled. * Capture: Fixed intermittent crash when disabling filtering with a DirectShow driver. * Capture: An error is now displayed when DirectShow filter graph construction fails when starting capture. * Capture: The default display mode for DirectShow drivers couldn't be set to None. * Capture: BT8x8 Tweaker could cause U and V to swap on some cards.
[regressions fixed] * Filter cropping dialog crashed when no video file was loaded. * Redraw requests could cause the output frame to be updated even if the output frame was disabled. * Capture: Frame rate went crazy when using Set Custom Format with DirectShow drivers. * Capture: Video codecs received a frame rate that was 1/10th that of the correct value (messed up bitrate values accordingly).
| meilin |
| Posted: Feb 27 2006, 07:10 AM |
thx so much |
| neuron2 |
| Posted: Feb 27 2006, 02:28 PM |
| stephanV |
| Posted: Feb 27 2006, 02:40 PM |
It is here --> http://sourceforge.net/project/showfiles.p...p?group_id=9649
| Moitah |
| Posted: Feb 27 2006, 07:58 PM |
Thanks Avery! |
| Posted: Feb 27 2006, 08:49 PM |
I've switched over the web page links now. The reason for the delay was to avoid a repeat of the last time where there was a span of about six hours where no mirrors showed up on SourceForge for you to download from. |
