Virtualdubmod 1.5.10.2
Suiryc
Posted: Aug 29 2005, 08:08 PM
Developer of VirtualdubMod
Group: VirtualdubMod Team
Since a lot of people bugged me to get a new bugfix release, here it is : VirtualDubMod 1.5.10.2
[VirtualDubMod 1.5.10.2]
Fizick:
- Fixed: inserted frame range and imported frameset end position was
 not correct in Avisynth Script editor.
- Fixed: too small string buffer to show Avisynth Information messagebox.
- Updated: added new Avisynth v2.5.5 and v2.5.6 keywords to highlight list.
Cyrius:
- Fixed: (1.5.10.1) an input file containing audio would remain opened even
 after "Clode video file" (thus preventing from deleting the file).
- Fixed: (1.5.10.1) crash when starting capture.
- Fixed: (1.5.10.1) ticks in the trackbar. Now have the same behaviour than
 VirtualDub (when in "Frames" mode).
- Fixed: (1.5.10.1) not enough space was reserved for the KaxSeekHead at the
 beginning of Matroska files. Added warnings (logs) when this happen.
- Fixed: duplicated references when writting 2 KaxSeekHead in Matroska files.
- Fixed: (1.5.10.1) logs shown 2 times when saving a Matroska file.
- Fixed: issues when decompressing AC3 (1.5.10.1) or audio using ACM.
- Fixed: issue with the input audio filter (graph) that would stuck the dubbing.
- Fixed: (1.5.10.1) problem with empty selection when doing a Refresh.
- Merged latest version of VirtualDub Sync by Andreas Dittrich (1.5.4, Sync 1.04)
- Fixed: livelock that could appear in some specific cases (the program encountered
 a problem and is aborting the dubbing, but a livelock prevent it to properly end
 the dubbing as well as showing you the error causing the problem).
- Fixed: issue when processing the very beginning of some AVI with MP3 VBR (this
 problem would cause the previously fixed livelock).
- Added: 'Delete' key deletes entries in the stream, comment & chapter lists.
- Fixed: bug preventing some Matroska files from correctly being opened.
- Fixed: bug preventing files made with latest mkvmerge to be opened.
- Fixed: (Matroska) bug preventing processing of Matroska files (generally
 resulting in a dubbing process stuck at the very beginning).
- Fixed: (stupid) bug concerning 'corrupted' data handling in DTS files.
- Fixed: (1.5.10.1) speed issue concerning dubbing thread priorities, and VBR
 audio as input (e.g. VBR MP3 in AVI or as external source).
- Fixed: bug that could crash the program when using the Asus ASV2 codec.
 Thanks to Michael Koester for the patch.
- Fixed: bug preventing to delete a file used as external audio source even after
 having removed it from the stream list (VDM would still keep the file opened).
- Fixed: bug cutting audio too early (33% or 50% of the stream) when muxing VBR
 Mpeg Audio other than Mpeg1-Layer3 or Mpeg-Layer2.
- Updated: fccHandler's MPEG2 support to latest version (1.5.10, 2004-03-04).
- Now read and write the new tags for Matroska files.
- Fixed: bug preventing 'clean' finalization of subtitle streams in OGM files.
- Fixed: (1.5.4) deadlock when muxing many audio/text streams in OGM/MKV files.
- Read and write aspect ratio info in AVI files.
- Fixed: take into account default OGM packets duration.
- Fixed: misbehaviour (duplicating software/title tags) for video tracks when
 editing MKV files.
- Fixed: misbehaviour when processing corrupted Ogg/OGM files.
- Fixed: some subtitle out-of-sync issues when muxing some subtitles sources.
- Fixed: some random livelocks on audio muxing (due to race conditions).
 Thanks to Michael Keeley for the patch.
- Fixed: possible issue with Symantec Corporate AntiVirus 10
 Thanks to vladlp : http://forum.doom9.org/showthread.php?t=93554
- Updated Matroska libs to libeml 0.7.5 and libmatroska 0.7.7
 Added warning on first startup since Matroska support is rather outdated :P
- Fixed (?): sometimes after loading avisynth at startup the VirtualDub exception
 handler (crash dialog) wasn't used anymore
ChristianHJW
Posted: Aug 30 2005, 02:10 PM
Wow ohmy.gif !!
Suiryc
Posted: Aug 30 2005, 07:00 PM
Actually the CVS was quite up to date (I had already integrated the new tagging system after it was redesigned).
Also it seems I forgot to mention that another bug 'should' be fixed : due to race conditions, sometimes final frames weren't flushed to the output file for b-frames encodings.
stephanV
Posted: Aug 30 2005, 07:03 PM
there is also a nice crash if you open non-VFW MKV files and press the input play button. smile.gif
useful links:
GravuTrad
Posted: Sep 10 2005, 05:33 PM
Hi suiryc!
Does it say that version 1.6.x of vdm is in progress? (with a 1.6 stable version of Virtualdub)
Sarreq Teryx
  Posted: Sep 11 2005, 07:00 PM
VirtualdubMod Alpha tester
In the word of Kermit D Frog
Sarreq Teryx
Posted: Sep 11 2005, 07:03 PM
QUOTE (GravuTrad @ Sep 10 2005, 12:33 PM)
Hi suiryc!
Please say it'll be true!!
GravuTrad
Posted: Sep 12 2005, 11:02 PM
\RED_DWARF_SEASON_1\EP6 Me²:
EXCEPTION: Open avi failed
GravuTrad
Posted: Sep 14 2005, 11:47 PM
I believe the term ² is not compatible with the opening in VD? VDM?.... huh.gif
wsbsteven
Posted: Sep 20 2005, 08:25 PM
Yay! I just happened to troll the forums and found that the project lives again. I'll get it installed tonight and hope for the best.
ChristianHJW
Posted: Oct 2 2005, 08:19 AM
I don't want to disappoint you, but i guess its overrated to assume that the project is 'alive' again ..... at least i didn't get the impression when talking to Cyrius, that he is now working on VDM 1.6.x ...... this release is more like a bugfix of long known bugs, and a compile of VDM against the very latest libmatroska/libebml, thats all.
Sorry sad.gif ....
10 replies since Aug 29 2005, 08:08 PM Track this topic | Email this topic | Print this topic
