Threshold Filter
limona
  Posted: Apr 17 2013, 09:24 AM
hi, i'm trying to put two filters on one video. both filters should use the opened, unfiltered video.
for example "threshold" and "Sketch Effect (Image Processor Plugin)" to get black / white shadows and sketchy lines
but the second filter normaly uses the first filtered material.
is there any possibility / plugin / script for virtualdub (or avisynth)?
thanks and greetings, limona
Posted: Apr 17 2013, 01:51 PM
It it's a new virtualdub 1.10.1.test8 or greater then there are filter naming/blend/merging options
http://forums.virtualdub.org/index.php?act...hl=blend+layers
It's a bit weird, and this is the first time i've looked at it, but here's a first steps walkthrough
I'll just use box blur and threshold as two example filters
Add a filter threshold - right click on it and select 'name output' I called it thresh
Add a filter box blur and config it for lots of blur - right click on it and name output, I called it blur
Right click on the blur filter again and pick add input - right click on the new 'no connection' and change it to 'source' so that filter uses the original frame, not the one affected by the threshold filter
...phew almost there
Add the bland layers filter - pick normal for the mode
Right click on the blend layers filter and 'add input' twice
Change 1 of the blend layers 'no connection' to 'blur' and the other to 'thresh'
The go back to the blend layers config and you can alter the blend %
limona
Posted: Apr 17 2013, 02:40 PM
great! your tutorial works very well!
thanks for the fast reply.
unfortunately if i take the "MSU Cartoonizer" filter i need (instead of "box blur") virtualdub crashes.
MSU Cartoonizer isn't working with this virtualdub release at all.
seems that MSU Cartoonizer isn't compatible with this release . Is it possible?
Do you have any suggestion?
Thanks and best, limona
crashinfo:
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'MSU_Cartoonizer'...
...reading address 06D26002...
...while running filter "MSU Cartoonizer v 3.0" (FilterInstance.cpp:2157).
Posted: Apr 17 2013, 03:09 PM
They never updated the older msu ones to work properly with newer virtualdubs
There is a 'try and fix it' option that was introduced just for them
In the filters dialog, select the msu filter you added then click the options button, and tick the 'force single framebuffer'
It's not a 100% guarantee but might help
limona
Posted: Apr 19 2013, 12:49 AM
GREAT! It works! Thanks a lot
limona
Posted: Apr 19 2013, 11:40 AM
hy, one more question. is it also possible to batch "convert" jpg images in virtualdub? batch video files with this filters works nice.
if i open an image and export image sequence it works. but i can't batch this step. i understand if vd is not made for image processing...
kind regards
Posted: Apr 19 2013, 12:38 PM
Yes you can
The easiest way to create a base script is to do everything like you normally would but instead of saving as avi, use the file menu's 'queue batch operation'
That'll save a .jobs file in the virtualdub directory. That .jobs file will have the script that will be used to automate the steps you went through.
(You could also use the 'save processing settings' to save a script file)
You copy and alter that .jobs file and use vdub.exe in a batch file to automate it all
(The normal file extension for scripts is .vdscript)
So here's an example saved job that loads images blurs them and exports the images as targa files
// VirtualDub job list (Sylia script format)
// This is a program generated file -- edit at your own risk.
// $signature 0 1
// $numjobs 1
// $job "Job 1"
// $input "C:\Users\Karl\Desktop\New folder\test0000.tga"
// $output "C:\Users\Karl\Desktop\New folder\test*.tga"
// $state 0
// $id 614773c704549230
// $start_time 00000000 00000000
// $end_time 00000000 00000000
// $script
VirtualDub.Open("C:\\Users\\Karl\\Desktop\\New folder\\test0000.tga","",0);
VirtualDub.audio.SetMode(0);
VirtualDub.audio.SetEditMode(1);
VirtualDub.audio.SetVolume();
VirtualDub.audio.EnableFilterGraph(0);
VirtualDub.video.SetInputFormat(0);
VirtualDub.video.SetOutputFormat(7);
VirtualDub.video.SetMode(3);
VirtualDub.video.SetPreserveEmptyFrames(0);
VirtualDub.video.SetIVTC(0, 0, 0, 0);
VirtualDub.video.SetCompression();
VirtualDub.video.filters.Add("blur");
VirtualDub.subset.Clear();
VirtualDub.subset.AddRange(0,18);
VirtualDub.video.SetRange();
VirtualDub.project.ClearTextInfo();
 // -- $reloadstop --
VirtualDub.SaveImageSequence("C:\\Users\\Karl\\Desktop\\New folder\\test", ".tga", 4, 4, 95);
VirtualDub.Close();
// $endjob
// $done
Next is to strip out most of the bits it doesn't need, and change the filenames to use cmdline parameters
VirtualDub.Open(VirtualDub.params[0],"",0);
VirtualDub.SaveImageSequence(VirtualDub.params[1], ".tga", 4, 4, 95);
VirtualDub.Close();
Then you'd set up a batch file to automate just dragging the first source image to it
Here's one that will process the files and save them with 'Modified-' at the start of the filename, in the same folder
@echo off
rem save to the same folder
set newfilepath=%~dp1
set newfilename=Modified-%~n1.tga
rem change the paths fo these to match your real exe and .vdscript locations
set VDubExe="C:\Users\Karl\Desktop\VirtualDub-1.10.3-test11\vdub.exe"
set MyScriptToRun="C:\Users\Karl\Desktop\VirtualDub-1.10.3-test11\BlurAndSaveAsTarga.vdscript"
%VDubExe% /i %MyScriptToRun% %1 "%newfilepath%%newfilename%"
if errorlevel 1 echo Oh dear an error happened
pause
limona
Posted: Apr 19 2013, 02:08 PM
nice! it almost works.
the images have different resolutions. after saving the first image successfully it says:
"doesn't match the image dimensions of the first image"
Posted: Apr 19 2013, 02:28 PM
Ahh, virtualdub does require the images to be the same for sequences
If it finds an images with a number 1 higher than the loaded one it'll assume it's a sequence
(Can't see any way around that)
There's a few ways you could work around that
1) make sure the files aren't numbered sequentially
2) resize them all to be the same size
3) make the batch file temporarily rename them before converting, then rename back after
Here's an example for #3 that'll separately process files dragged to it
@echo off
:loop
if %1.==. goto done
set origionalfilename=%~nx1
set tmpfilename=tmp_%newfilename%
ren %1 "%tmpfilename%"
%VDubExe% /i %MyScriptToRun% "%newfilepath%%tmpfilename%" "%newfilepath%%newfilename%"
ren "%newfilepath%%tmpfilename%" "%origionalfilename%"
shift
goto loop
:done
echo done
pause
limona
Posted: Apr 19 2013, 02:53 PM
marvelous! now it works perfect. thanks again!
limona
Posted: Apr 19 2013, 07:27 PM
me again, maybe a new topic :-)
i saw on a "video cartoon app" a filter that smoothes threshold, it looked perhaps like the Oilpaint Filter (Pixel Bender Plugin) from PhotoShop Filtermenue.
tooncamera app:
http://a518.phobos.apple.com/us/r1000/111/....320x480-75.jpg
http://25.media.tumblr.com/b2d8ae808efe213...hv6x8o1_500.jpg
photoshop filter:
http://farm6.staticflickr.com/5018/5466337...8f8451547_z.jpg
i haven't seen the effect on videos or editing programs before.
is there a virtualdub filter like this or has it a different name?
greets
10 replies since Apr 17 2013, 09:24 AM Track this topic | Email this topic | Print this topic
