Batch Scanning Videofiles For Errors, it is possible use the function that?
trodas
  Posted: Sep 9 2012, 07:40 PM
I do wonder, if it is possible to use the function in "Video" - "Scan video stream for errors..." to do a batch checking of about 1000 or more videofiles.
Cause - Partition Magic 8 bug cause some disk troubles. It is necessary to know, witch files are damaged and witch are fine. Usually a damaged file come up with message (using the Scan video stream for errors... function) like:
ASF: Missing object (Media_Object_Number=162, current_obj=70, pktpos=33821770)
So, it is possible to make VirtualDub log each good and each bad file in sort of automatic batch processing? And if yes, then - how to accomplish such task?
trodas
  Posted: Sep 16 2012, 11:51 AM
ale5000
Posted: Sep 16 2012, 01:27 PM
Try to post a video (possibly small) with the problem.
New VirtualDub forum
trodas
  Posted: Jan 22 2013, 08:52 PM
Slight problem. Can't find any reasonably small vid that is damaged AND most of the vids are quite, ehm... special? laugh.gif
I did not even remember witch one is producing that error, so... even the video will be big and will be at least weird, then I can't get it right now sad.gif Gotta check that out more.
3 replies since Sep 9 2012, 07:40 PM Track this topic | Email this topic | Print this topic
