Cropping Problem, Cropping
Troels83DK
Posted: Oct 30 2014, 11:32 PM
Hi experts.
It's been years since I last used VD so kinda forgot most about it.
I'm trying to crop a video, but my result is very odd...
The video was recorded in WinUAE Amiga-emulator with Xvid MPEG-4 codec and PCM 44,100kHz, 16 bit stereo.
I'm using the filter Null Transform, and saving as segmented AVI
Here is how it looks after save
http://postimg.org/image/k8l0xhm73/
The colours are actually fine, don't know why they are not in the snapshot but the video is all warped.
How do I fix this?
Thanks
ALbino
Posted: Oct 30 2014, 11:57 PM
Is the video a weird resolution? I sometimes have troubles with some decoders if it's like 1278x720 instead of 1280x720. Maybe try using FFInputDriver:
https://code.google.com/p/ffinputdriver/downloads/list
Posted: Oct 31 2014, 06:20 AM
Yes it's the width of the video that's the problem
Best practice is to make sure you're cropping to a multiple of 8 for the width and 4 for the height
Many decoders can use 4/2, but 8/4 covers practically all of them
PS
Newer ffmpeg versions than the above link are available in my sig or from the List Of Input Plugins page
Troels83DK
Posted: Oct 31 2014, 09:46 AM
The original size is 800x600. The FFInputDriver didn't help.
The cropped size is 573x343.
Trying to make it 8parts width x 4 parts hight 686x343, didn't help. Same result, only now in black and white.
Since you said it is a width/hight issue I figured 800x600 is 4:3 so scaling to 600x450 should be the same and that did the trick smile.gif
Now I have to fine tune a bit.
EDIT: forund this http://size43.com/jqueryVideoTool-4x3.html and ended up with 572x429.
Posted: Oct 31 2014, 01:05 PM
Instead of the Nulltransform filter you can better use the "Resize" filter.
It allows you to combine cropping AND resizing.
When you have select it, via Video > Filters... > Add... "Resize" > OK, you can set the
- New size to "Absolute" 640x480 (4:3) / 640x360 (16:9),
>> Please try to use these default sizes if possible. If not, then please use multiples of 4 or 8...
- Aspect ratio to "Disabled",
- Filter mode to "Lanczos",
- Framing options "Do not letterbox or crop",
- Codec-friendly sizing "Do not adjust" + OK.
This was the Configure... process for the Resize-filter.
Now, you can click the "Cropping..."-button, to crop unneeded pieces.
Click OK to confirm.
Troels83DK
Posted: Oct 31 2014, 01:21 PM
5 replies since Oct 30 2014, 11:32 PM Track this topic | Email this topic | Print this topic
