| simons-photography |
| Posted: Jun 25 2007, 07:38 PM |
well I have win xp I tried the registry hack: i no longer have any mp3 codec installed for virtual dub it seems,
how do I get to encode at above 56 Kbps ?
-------------------- my photography: www.simons-photography.com my forum: http://forum.simons-photography.com |
| foxidrive |
| Posted: Jun 26 2007, 01:40 AM |
Install the LAME MP3 audio codec |
| Posted: Jun 26 2007, 05:24 AM |
ok done it thanks
| Dstruct |
| Posted: Feb 17 2009, 01:28 PM |
| QUOTE (fccHandler @ Oct 6 2004, 05:30 PM) | | It isn't locked AFAIK, it's just not registered with the ACM. I got it to work on my WinXP system, but I don't remember exactly how. If you use XP, run regedit and find "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32\msacm.l3acm", and make sure it's value is "L3codecp.acm." Then reboot. That might do it. |
Thanks for this note!
By default the value reads "L3codeca.acm" |
