| -vdub- |
| Posted: Jul 31 2011, 08:17 AM |
When load a mpeg-2 video can it be made to load with DAR set as default, PAR set as sub option. DAR always for me seems to be the correct AR to be used when viewing.
Also have you any consideration and thoughts for supporting ts container with mpeg-2 sd or/and also hd video ? |
| Posted: Jul 31 2011, 11:36 PM |
I'm not sure what you mean. MPEG-2 video only has DAR information; there is no PAR as in MPEG-1. The DAR is reported to VirtualDub, but there is no way programatically for a plugin to change the aspect ratio of VirtualDub's input/output panes. You have to do that manually as far as I know.
I never say never, but for now I have no plans to support Transport Streams. Sorry.
| -vdub- |
| Posted: Aug 1 2011, 07:38 AM |
Hi ffcHandler i have uploaded two small samples that show this problem. Clips chosen have round circles to tell correct AR or not when loaded into virtualdub.
The .mpg file with g-spot shows the PAR is not 16:9 where the DAR is 16:9 When loaded in virtualdub they show with 4:3 type AR not the correct AR of 16:9. These cannot be re-sized from loaded 4:3 type to correct AR 16:9 using the internal virtualdub resize filter or the VDModResize filter.
Other mpg (mpeg-2) i have noticed having this problem includes also all dvd videos. That when checked with g-spot shows DAR having correct AR. When loaded into virtualdub the AR shown always using wrong AR of PAR not the correct AR of DAR.
| CODE | PAR-DAR.mpg [mpeg-2 raw clip]
http://qfs.mobi/f22707
PAR-DAR.ts (raw) clip
http://qfs.mobi/f22708 |
.ts included for when you decide to do a .ts plugin |
| Posted: Aug 1 2011, 02:19 PM |
I still don't see a problem, and I surely don't know what you mean by "cannot be re-sized". You can resize the video to any size you want.
If your complaint is that the video input/output panes are the wrong size, I have no control over that. By default you see the video at its true size (720 x 576, for example). If you want to see it in a different size then you have to change the AR manually, as I said.
For example, load PAR-DAR.mpg then right-click on one of the video panes. In the aspect ratio column there are several choices; the one labeled "Source" is the aspect ratio reported by the MPEG-2 plugin.
| -vdub- |
| Posted: Aug 1 2011, 03:14 PM |
Open mpg with virtualdub, open resize filter and click on preview. Notice how the preview is showing the AR of PAR 1.422 (~10:7) the correct AR for the video is DAR 1.778 (16:9)
Load with VDMod_Resize filter and will see the AR the video is loaded with PAR 1.422 (~10:7) not real AR which should be DAR 1.778 (16:9)
Try to use either filter to resize to same as source video DAR 1.778 (16:9). Nearest i can achieve is 720v405 that give true ratio +0.000% 1.777777777777778 to 1 which you will know is 1.778 (16:9) that is the same value the mpg video has for its DAR 1.778 (16:9)
The video has been loaded with wrong AR using PAR instead of DAR value. test with win os video players (using default settings) mpc, vlc, wmp and mpc-hc all show with using the DAR 1.778 (16:9) value
You can also find the same if dump a dvd raw to vob or load dvd in an editor shows the video true AR used would be DAR. Play the video and will see that DAR is the AR used and never yet the PAR value
s the video loads with PAR and not DAR working with video and saving with correct resolution and AR of source mpg 720x576 1.778 (16:9) is not possible atm
A reason for choosing those clips it also shows you that the circles are not circular for example with the earth exploding PAR-DAR.mpg. That in the resize filters preview it is egg shape not round as it should be. |
| Posted: Aug 1 2011, 03:41 PM |
it's a standard pal dvd with the video stream marked as 16:9
video players see that flag on playback and automatically resize it to the correct width/height 1024x576
virtualdub works with square pixels though, so a plugin that did the same as video players do would have to a lot of lying to virtualdub and resize the video frames themselves
that's a lot more work than just adding the resize filter (admittedly, it would be useful if the resize filter had the option to resize the width based on the height, not the other way around as it is now)
I don't think I'd want the plugin to automatically resize the video though, as after editing you can currently add the video back to an mpeg encoder as-is, without having the pluing resize it to 16:9, and then have to resize it back to 720x576
| Posted: Aug 1 2011, 04:06 PM |
OK, there is something weird happening.
You are correct that the plugin reports the AR to VirtualDub as 1.422:1. This math came about after toying with the input/output panes to get correct results. I determined that the PAR was the value VirtualDub wanted in its GetStreamSourceInfo() query, and it makes sense because the name of the field we fill in is VDXStreamSourceInfo.mPixelAspectRatio.
However, the resize preview window behaves in a totally different manner from the input/output panes. Note what happens when you right-click the preview window and choose the following in this order:
1.422:1 pixel (Source) 16:9 frame (Wide) 1.422:1 pixel (Source)
The first time you choose 1.422:1, you get an incorrect AR. Then switching to 16:9 gives a correct AR, then switching back to 1.422:1 doesn't change the AR! This seems to be a bug in VirtualDub's resize filter.
| -vdub- |
| Posted: Aug 2 2011, 05:35 AM |
Which means that not only virtualdub internal resize filter is incorrect. But hard to believe that far better VDMod_resize filter is also incorrect. Since it shows far more in the filter than virtualdub own resize filter does. While also ben extremely helpful in making adjustments easy to do. This was the reason i though that the video decoder itself was at fault.
The only player i see that does upscale to 1024x576 for playing is mplayer. Where if load into say mpc or mpc-hc with Video Frame > Normal Size and Keep Aspect Ratio doesn't show the video as 1024x576 but as resolution of 720x576.
Also as said g-spot also reports what the actual resolution is 720x576.
I know 720x576 and 1024x576 are true AR for 16:9 whether all tv broadcasters film in higher resolution than 720x576 for sd unknown. The bbc from which the clips are from, captured digitally years ago. The bbc do film 16:9 for sd only at 720x576. That said i know if upscale the videos using the resize filters with virtualdub to 1024x576 does then show correct AR (upscaled corrected AR).
Then the problem next that the videos are interlaced during processing will remain the same, with no de-interlaced applied. Upscaling interlace is not recommended even says so on the resize filters also would prefer not to upscale or downscale the video. Needing the video able to load into virtualdub to process using the video source DAR 1.778 (16:9)
I suppose then we are at the point of seeing what phaeron has to say or can do for this if a virtualdub problem. Still feeling virtualdub will only display what the decoder loads. The decoder or virtualdub which is the one that's unable to load and use the DAR info from the video loaded.
As said happens with pal dvd videos, a few infos from g-spot (have not ntsc dvd to test). The DAR is always used for correct AR when playing.
| CODE | Forest Gump
SAR 1.250 (5:4) PAR 1.422 (~10:7) DAR 1.778 (16:9)
Hellraiser
Interview With The Vampire
Meet Joe Black
Roots
SAR 1.250 (5:4) PAR 1.067 (16:15) DAR 1.333 (4:3) |
Also load these clips into videoredo for example and see how it does edit and playback is using correct AR. Other mpeg-2 editors also do the the same. Are you sure it could be virtualdub or its filter that is at fault and not the mpeg-2 decoder ! |
| Posted: Aug 2 2011, 05:05 PM |
The AR information is never used by the plugin. You can browse the source code and see for yourself. All I do is report it to the user via the File Information dialog, and pass it to VirtualDub via his GetStreamSourceInfo() query. What he does with the info is out of my control.
It isn't explicitly stated in the plugin SDK, but based on the name of the field (mPixelAspectRatio) and the behavior of the input/output panes, I assume the PAR is what he is asking for. If that is an incorrect assumption then we will need Avery Lee to clarify...
| Posted: Aug 8 2011, 12:44 AM |
I tried to reproduce the issue with the resize preview window, and couldn't do so on either 1.9.11 or the dev tree -- the result was a 16:9 window each time. Any chance you guys are running at a low desktop resolution that might force the window to resize on initial display?
| QUOTE | | Open mpg with virtualdub, open resize filter and click on preview. Notice how the preview is showing the AR of PAR 1.422 (~10:7) the correct AR for the video is DAR 1.778 (16:9) |
I don't understand what you're saying here. The pixel aspect ratio (PAR) and the display aspect ratio (DAR) are related through the encoded resolution of 720x576 -- there is no difference between a PAR of 64:45 = ~1.422 and a DAR of 16:9 at that resolution. A frame encoded with a specific resolution and displayed at specific frame size has both a specific PAR and DAR. |
| -vdub- |
| Posted: Aug 8 2011, 10:51 AM |
The pc i use virtualdub monitor display is set to 1600x900 - 32bit - 60 hertz. I see the same using virtualdub directx or opengl settings
These below are with using fccHandler MPEG-2 plugin filter with the PAR-DAR.mpg clip
 After loading clip (notice the earth is eliptical (egg shaped) not round as would be if was showed at 16:9) Sure can adjust to force 16:9 here but it should be loading as 16:9 to begin with (prefer not to force to display 16:9). Also note if force display to 16:9 it doesn't change what is shown below.
 Internal Resize filter preview (with no resize adjustments made notice the display is showing 5:4) (display should be 16:9 same as video source input) (elipcal egg shaped again 5:4 would be round if 16:9)
 VDMod_Resize filter (after opened with no adjustment made) (notice 5:4) (should be 16:9 same as video source input)
 VDMod_Resize filter (16:9 adjustment made notice pixel size has changed from 720x576 to 720x405) (It does preview as 16:9 but has lost resolution i need as video source 720x576)
 VDMod_Resize filter (16:9 and also round to multiples of 16x16 adjustments made. Note also the Output Aspect Ratio is no longer true AR)
Other video softwares, dvd authors, editors etc, show the video as 720x576 16:9 on load, editing, adjusting and after saving. I need need to use virtualdub instead of other tools for processing. |
| -vdub- |
| Posted: Aug 8 2011, 11:16 AM |
Media Player Classic - Home Cinema
http://img84.imageshack.us/img84/4974/mpchcfs.jpg
http://img29.imageshack.us/img29/3341/mpch...cvideoframe.jpg
http://img189.imageshack.us/img189/8933/mp...cvideoinput.jpg
http://img217.imageshack.us/img217/7910/mp...videooutput.jpg
| CODE | Video: PAR-DAR.mpg
MPC-HC: Filters > MPEG-2 Video Decoder
Pin Info - [IN] Video
Filter : MPEG-2 Video Decoder - CLSID : {39F498AF-1A09-4275-B193-673B0BA3D478}
- Connected to:
CLSID: {1365BE7A-C86A-473C-9A41-C0A6E82C9FA3} Filter: J:\PAR-DAR.mpg Pin: Video
- Connection media type:
Video: MPEG2 Video 720x576 (16:9) 25.00fps 6500Kbps
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_MPEG2_VIDEO {E06D8026-DB46-11CF-B4D1-00805F6CBBEA} formattype: FORMAT_MPEG2_VIDEO {E06D80E3-DB46-11CF-B4D1-00805F6CBBEA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 282
VIDEOINFOHEADER: rcSource: (0,0)-(0,0) rcTarget: (0,0)-(0,0) dwBitRate: 6500000 dwBitErrorRate: 0 AvgTimePerFrame: 400000
VIDEOINFOHEADER2: dwInterlaceFlags: 0x00000000 dwCopyProtectFlags: 0x00000000 dwPictAspectRatioX: 16 dwPictAspectRatioY: 9 dwControlFlags: 0x00000000 dwReserved2: 0x00000000
MPEG2VIDEOINFO: dwStartTimeCode: 0 cbSequenceHeader: 150 dwProfile: 0x00000004 dwLevel: 0x00000008 dwFlags: 0x00000000
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 0 biBitCount: 0 biCompression: 0 biSizeImage: 0 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 @............... 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070: 00 00 00 00 96 00 00 00 04 00 00 00 08 00 00 00 ....–........... 0080: 00 00 00 00|00 00 01 b3 2d 02 40 33 0f de a3 82 .......³-.@3.Þ£‚ 0090: 10 20 20 26 20 26 2c 2c 2c 2c 2c 2c 34 30 34 36 . & &,,,,,,4046 00a0: 36 36 34 34 34 34 36 36 36 3a 3a 3a 44 44 44 3a 664444666:::DDD: 00b0: 3a 3a 36 36 3a 3a 40 40 44 44 4a 4c 4a 46 46 44 ::66::@@DDJLJFFD 00c0: 46 4c 4c 50 50 50 60 60 5c 5c 70 70 74 8a 8a a7 FLLPPP``\\pptŠŠ§ 00d0: 10 11 11 12 12 12 13 13 13 13 14 14 14 14 14 15 ................ 00e0: 15 15 15 15 15 16 16 16 16 16 16 16 17 17 17 17 ................ 00f0: 17 17 17 17 18 18 18 19 18 18 18 19 1a 1a 1a 1a ................ 0100: 19 1b 1b 1b 1b 1b 1c 1c 1c 1c 1e 1e 1e 1f 1f 21 ...............! 0110: 00 00 01 b5 14 82 00 01 00 00 ...µ.‚.... |
[b]Pin Info - [OUT] Video[/b]
- Connected to:
CLSID: {B87BEB7B-8D29-423F-AE4D-6582C10175AC} Filter: Video Mixing Render 7 (Renderless) Pin: VMR Input0
Video: YUY2 1024x576 25.00fps 6500Kbps
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_YUY2 {32595559-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1179648 cbFormat: 1152
VIDEOINFOHEADER: rcSource: (0,0)-(720,576) rcTarget: (0,0)-(720,576) dwBitRate: 6500000 dwBitErrorRate: 0 AvgTimePerFrame: 400000
BITMAPINFOHEADER: biSize: 40 biWidth: 1024 biHeight: -576 biPlanes: 1 biBitCount: 16 biCompression: YUY2 biSizeImage: 1179648 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 00 04 00 00 ........(....... 0050: c0 fd ff ff 01 00 10 00 59 55 59 32 00 00 12 00 Àýÿÿ....YUY2.... 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070:|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0200: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0210: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0220: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0230: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0240: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0250: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0260: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0270: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0280: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0290: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0300: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0310: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0320: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0330: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0340: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0350: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0360: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0370: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0380: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0390: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0400: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0410: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0420: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0430: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0440: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0450: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0460: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0470: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
- Enumerated media type 0:
Video: YV12 720x576 (16:9) 25.00fps 6500Kbps
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_YV12 {32315659-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 112
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 3 biBitCount: 12 biCompression: YV12 biSizeImage: 622080 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 03 00 0c 00 59 56 31 32 00 7e 09 00 @.......YV12.~.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
- Enumerated media type 1:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_YV12 {32315659-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 88
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 3 biBitCount: 12 biCompression: YV12 biSizeImage: 622080 biXPelsPerMeter: 6480 biYPelsPerMeter: 9216 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 03 00 0c 00 (...Ð...@....... 0040: 59 56 31 32 00 7e 09 00 50 19 00 00 00 24 00 00 YV12.~..P....$.. 0050: 00 00 00 00 00 00 00 00 ........
- Enumerated media type 2:
Video: I420 720x576 (16:9) 25.00fps 6500Kbps
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: Unknown GUID Name {30323449-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 112
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 3 biBitCount: 12 biCompression: I420 biSizeImage: 622080 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 03 00 0c 00 49 34 32 30 00 7e 09 00 @.......I420.~.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
- Enumerated media type 3:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: Unknown GUID Name {30323449-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 88
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 3 biBitCount: 12 biCompression: I420 biSizeImage: 622080 biXPelsPerMeter: 6480 biYPelsPerMeter: 9216 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 03 00 0c 00 (...Ð...@....... 0040: 49 34 32 30 00 7e 09 00 50 19 00 00 00 24 00 00 I420.~..P....$.. 0050: 00 00 00 00 00 00 00 00 ........
- Enumerated media type 4:
Video: IYUV 720x576 (16:9) 25.00fps 6500Kbps
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_IYUV {56555949-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 112
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 3 biBitCount: 12 biCompression: IYUV biSizeImage: 622080 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 03 00 0c 00 49 59 55 56 00 7e 09 00 @.......IYUV.~.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
- Enumerated media type 5:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_IYUV {56555949-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 88
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 3 biBitCount: 12 biCompression: IYUV biSizeImage: 622080 biXPelsPerMeter: 6480 biYPelsPerMeter: 9216 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 03 00 0c 00 (...Ð...@....... 0040: 49 59 55 56 00 7e 09 00 50 19 00 00 00 24 00 00 IYUV.~..P....$.. 0050: 00 00 00 00 00 00 00 00 ........
- Enumerated media type 6:
Video: YUY2 720x576 (16:9) 25.00fps 6500Kbps
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_YUY2 {32595559-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 112
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 16 biCompression: YUY2 biSizeImage: 829440 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 01 00 10 00 59 55 59 32 00 a8 0c 00 @.......YUY2.¨.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
- Enumerated media type 7:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_YUY2 {32595559-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 88
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 16 biCompression: YUY2 biSizeImage: 829440 biXPelsPerMeter: 6480 biYPelsPerMeter: 9216 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 01 00 10 00 (...Ð...@....... 0040: 59 55 59 32 00 a8 0c 00 50 19 00 00 00 24 00 00 YUY2.¨..P....$.. 0050: 00 00 00 00 00 00 00 00 ........
- Enumerated media type 8:
Video: 720x576 (16:9) 25.00fps 6500Kbps
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_ARGB32 {773C9AC0-3274-11D0-B724-00AA006C1A01} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 112
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 32 biCompression: 0 biSizeImage: 1658880 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 01 00 20 00 00 00 00 00 00 50 19 00 @..... ......P.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
- Enumerated media type 9:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_ARGB32 {773C9AC0-3274-11D0-B724-00AA006C1A01} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 88
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 32 biCompression: 0 biSizeImage: 1658880 biXPelsPerMeter: 6480 biYPelsPerMeter: 9216 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 01 00 20 00 (...Ð...@..... . 0040: 00 00 00 00 00 50 19 00 50 19 00 00 00 24 00 00 .....P..P....$.. 0050: 00 00 00 00 00 00 00 00 ........
- Enumerated media type 10:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB32 {E436EB7E-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 112
- Enumerated media type 11:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB32 {E436EB7E-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 88
- Enumerated media type 12:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB24 {E436EB7D-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 112
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 24 biCompression: 0 biSizeImage: 1244160 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 01 00 18 00 00 00 00 00 00 fc 12 00 @............ü.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
- Enumerated media type 13:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB24 {E436EB7D-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 88
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 24 biCompression: 0 biSizeImage: 1244160 biXPelsPerMeter: 6480 biYPelsPerMeter: 9216 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 01 00 18 00 (...Ð...@....... 0040: 00 00 00 00 00 fc 12 00 50 19 00 00 00 24 00 00 .....ü..P....$.. 0050: 00 00 00 00 00 00 00 00 ........
- Enumerated media type 14:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB565 {E436EB7B-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 112
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 16 biCompression: 0 biSizeImage: 829440 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 01 00 10 00 00 00 00 00 00 a8 0c 00 @............¨.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
- Enumerated media type 15:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB565 {E436EB7B-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 88
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 16 biCompression: 0 biSizeImage: 829440 biXPelsPerMeter: 6480 biYPelsPerMeter: 9216 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 01 00 10 00 (...Ð...@....... 0040: 00 00 00 00 00 a8 0c 00 50 19 00 00 00 24 00 00 .....¨..P....$.. 0050: 00 00 00 00 00 00 00 00 ........
- Enumerated media type 16:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB555 {E436EB7C-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 112
- Enumerated media type 17:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB555 {E436EB7C-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 88
- Enumerated media type 18:
Video: 3 720x576 (16:9) 25.00fps 6500Kbps
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_ARGB32 {773C9AC0-3274-11D0-B724-00AA006C1A01} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 124
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 32 biCompression: 3 biSizeImage: 1658880 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 01 00 20 00 03 00 00 00 00 50 19 00 @..... ......P.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070:|00 00 ff 00 00 ff 00 00 ff 00 00 00 ..ÿ..ÿ..ÿ...
- Enumerated media type 19:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_ARGB32 {773C9AC0-3274-11D0-B724-00AA006C1A01} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 100
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 32 biCompression: 3 biSizeImage: 1658880 biXPelsPerMeter: 6480 biYPelsPerMeter: 9216 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 01 00 20 00 (...Ð...@..... . 0040: 03 00 00 00 00 50 19 00 50 19 00 00 00 24 00 00 .....P..P....$.. 0050: 00 00 00 00 00 00 00 00|00 00 ff 00 00 ff 00 00 ..........ÿ..ÿ.. 0060: ff 00 00 00 ÿ...
- Enumerated media type 20:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB32 {E436EB7E-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 124
- Enumerated media type 21:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB32 {E436EB7E-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 100
- Enumerated media type 22:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB24 {E436EB7D-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 124
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 24 biCompression: 3 biSizeImage: 1244160 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 01 00 18 00 03 00 00 00 00 fc 12 00 @............ü.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070:|00 00 ff 00 00 ff 00 00 ff 00 00 00 ..ÿ..ÿ..ÿ...
- Enumerated media type 23:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB24 {E436EB7D-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 100
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 24 biCompression: 3 biSizeImage: 1244160 biXPelsPerMeter: 6480 biYPelsPerMeter: 9216 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 01 00 18 00 (...Ð...@....... 0040: 03 00 00 00 00 fc 12 00 50 19 00 00 00 24 00 00 .....ü..P....$.. 0050: 00 00 00 00 00 00 00 00|00 00 ff 00 00 ff 00 00 ..........ÿ..ÿ.. 0060: ff 00 00 00 ÿ...
- Enumerated media type 24:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB565 {E436EB7B-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 124
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 16 biCompression: 3 biSizeImage: 829440 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 01 00 10 00 03 00 00 00 00 a8 0c 00 @............¨.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070:|00 f8 00 00 e0 07 00 00 1f 00 00 00 .ø..à.......
- Enumerated media type 25:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB565 {E436EB7B-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 100
BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 16 biCompression: 3 biSizeImage: 829440 biXPelsPerMeter: 6480 biYPelsPerMeter: 9216 biClrUsed: 0 biClrImportant: 0
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 01 00 10 00 (...Ð...@....... 0040: 03 00 00 00 00 a8 0c 00 50 19 00 00 00 24 00 00 .....¨..P....$.. 0050: 00 00 00 00 00 00 00 00|00 f8 00 00 e0 07 00 00 .........ø..à... 0060: 1f 00 00 00 ....
- Enumerated media type 26:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB555 {E436EB7C-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 124
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 00 00 00 00 00 00 00 00 10 00 00 00 09 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 01 00 10 00 03 00 00 00 00 a8 0c 00 @............¨.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070:|00 7c 00 00 e0 03 00 00 1f 00 00 00 .|..à.......
- Enumerated media type 27:
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_RGB555 {E436EB7C-524F-11CE-9F53-0020AF0BA770} formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 100
pbFormat: 0000: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0010: 00 00 00 00 00 00 00 00 d0 02 00 00 40 02 00 00 ........Ð...@... 0020: a0 2e 63 00 00 00 00 00 80 1a 06 00 00 00 00 00 .c.....€....... 0030: 28 00 00 00 d0 02 00 00 40 02 00 00 01 00 10 00 (...Ð...@....... 0040: 03 00 00 00 00 a8 0c 00 50 19 00 00 00 24 00 00 .....¨..P....$.. 0050: 00 00 00 00 00 00 00 00|00 7c 00 00 e0 03 00 00 .........|..à... 0060: 1f 00 00 00 .... |
[edit] Images were breaking the board layout
This post has been edited by stephanV on Aug 8 2011, 05:13 PM |
| stephanV |
| Posted: Aug 8 2011, 05:08 PM |
| QUOTE | | After loading clip (notice the earth is eliptical (egg shaped) not round as would be if was showed at 16:9) Sure can adjust to force 16:9 here but it should be loading as 16:9 to begin with (prefer not to force to display 16:9). |
It really shouldn't. Anamorphic content is stored, well, anamorphic and any automaic alteration on the editing display is possibly harmful to the editing process. There is no sense in comparing it to what a player does because an editing tool is not intended for playback.
I think you are confused about what anamorphic really means.
| -vdub- |
| Posted: Aug 8 2011, 09:06 PM |
Anamorphic well they could i have no idea or care, but for me that is not the issue. The issue is it doesn't display on load correctly with virtualdub and also all other processes such as the filters. Cannot work with a video if the editor doesn't load and work with the actual source ar and resolution.
With many mpeg-2 editors i have tried they all load and work with these videos correctly using source video ar and resolution. Also dvd author tools all work with videos and process them using correct ar and resolution. I do not force any tool to do this, they actually know are correct ar and resolution to use and do use them. Though i also need to use virtualdub with these videos i prefer virtualdub with its features, ease of use and the various filters available for use to process a video further when needing to do so.
As a side note for Phaeron have a look at virtualdub mpeg-2 (that maybe fcchandler modified) v1.6.19 (build 24586\release). Load the clip and notice the display is correct and also so is the information for the loaded source clip. Though the filters are still wrong same as virtualdub screen images show above. Virtualdub code need modifying maybe so is able to do the same, for main display, plugins and other processes.
Why mpc-hc images posted since often read on forums people asking is what does it look like in mpc. So put those images there just in case the question is asked. Also same for mpeg-2 decoder in/output pins data. |
| stephanV |
| Posted: Aug 9 2011, 04:44 PM |
| QUOTE (-vdub- @ Aug 8 2011, 11:06 PM) | Anamorphic well they could i have no idea or care, but for me that is not the issue. The issue is it doesn't display on load correctly with virtualdub and also all other processes such as the filters. Cannot work with a video if the editor doesn't load and work with the actual source ar and resolution. | Virtualdub displays how the video is stored. Any automatic alteration of that is possibly harmful. The AR is just a flag and I think if you want to do video editing you should educate yourself at least a little in this matter.
VirtualDub is not doing anything wrong. It maybe is not doing something you expect it to do, but that is, bluntly said, your misunderstanding.
