Pages: (26) « First ... 13 14 [15] 16 17 ... Last » ( Go to first unread post )
Ffmpeg Input Driver, Experimental driver based on ffmpeg libs
Posted: Apr 11 2014, 08:12 PM
Probably, but I have no idea how you would get that to work
Your quite welcome to find programmers to make this plugin work better :-)
jpsdr
Posted: Apr 12 2014, 12:28 PM
Noticed a little annoying issue on x64 version (not checked on x86). When pluggin is installed, .avs file are not listed anymore in the first "all" provided by VDub...
Posted: Apr 12 2014, 12:54 PM
I can add .avs to ffmpeg's list for the next version - it's not specifically in there
Avs should be in virtualdub's list already though...
What can happen is that the open dialog just takes ages to show everything, I tested a folder with 2000+ files in, and .avs appeared, but it did require a wait as the list was populated
-vdub-
Posted: Apr 12 2014, 11:07 PM
What If Phaeron changed Virtualdub code to allow selecting Driver plugins to load with. Then selecting for example FFmpeg Input Driver from then always has priority over decoders, that is until set to default again or another decoder
I think that would be the only way to make Virtualdub easier for more people to look at using it. Though FFmpeg would still have no Direct Copy and maybe in time if possible it would also change so it has the ability. Easy then to set and forget load everything using FFmpeg Input Driver to do what you need to do with Virtualdub
jpsdr
Posted: Apr 13 2014, 09:22 AM
There was only 10 files in the directory.
Seems to be specific with XP64... occurs with both 32bits and 64bits version of VDub.
But it's not occuring apparently with XP32. So, don't bother, if everything is working fine on your side with most recent OS in both 32&64.
Posted: Apr 20 2014, 04:54 PM
v0814 released
Posted: May 26 2014, 03:53 PM
v0815 released
updated to use ffmpeg 2.2.2
moody2014
Posted: May 26 2014, 10:19 PM
QUOTE (dloneranger @ May 26 2014, 03:53 PM)
v0815 released
with v0815 I can not open some mkv files using last git of ffmpeg.
but with version 0814 and last ffmeg git i can open files that do not open with version 0815.
When try open with version 0815 shows no error message, just loading for long time.
Posted: May 26 2014, 10:32 PM
Haven't had a problem myself
Could be a problem with 2.2.2 dlls from http://ffmpeg.zeranoe.com/builds/, but that's down to ffmpeg's site and would have to wait for a new release to see if it's fixed
Previous versions are kept available because ffmpeg is so flaky - they fix 2 things and break 1 ;-)
(the changelog on their site is scary.....)
moody2014
Posted: May 26 2014, 11:34 PM
QUOTE (dloneranger @ May 26 2014, 10:32 PM)
use 0814 with last git had to add the swresample-0.dll to ffdlls folder for open any file.
but even if they do this in 0815 not work
Posted: May 27 2014, 04:42 AM
You can't just mix and match the dlls like that
Only from the same version branch, and not even that's guaranteed without a recompile of the plugin
The releases newer than the one supplied with the plugin may work, until any calling conventions or types change
Just plonking different dlls in is more a case of luck, and your own support problem
moody2014
Posted: May 27 2014, 04:58 PM
QUOTE (dloneranger @ May 27 2014, 04:42 AM)
Posted: Jul 17 2014, 03:54 PM
V0816 released
Update ffdlls to 2.3.0
FFDlls now need swresample-0.dll also
swresample-0.dll added
moody2014
Posted: Aug 10 2014, 03:09 PM
QUOTE (dloneranger @ Jul 17 2014, 03:54 PM)
V0816 released
@dloneranger
Can you update to the new avcodec-56.dll, avformat-56.dll, avutil-54.dll, and swscale-3.dll?
thanks
Posted: Aug 10 2014, 03:47 PM
Updating to 2.3.1's on my list of possible things to do, but there's nothing in the 2.3.0 -> 2.3.1 changes should make any difference for users (doesn't improve/change decoding in any way)
I don't update to the daily releases, only the stable releases
So those dlls may appear in the 2.3.2 release
378 replies since May 10 2011, 10:20 AM Track this topic | Email this topic | Print this topic
