| Posted: Mar 17 2014, 04:53 PM |
My sucky script created the wrong folder names in the .zip files
Instead of ffdlls, the folders were called dlls32 or dlls64 They can be renamed back to ffdlls (delete any old ffdlls folder)
So beta2 is just a name change in the .zip files and you don't need to download it again
| Posted: Mar 17 2014, 10:42 PM |
810 beta3
Better handling of audio/video just before the end of the file
| Posted: Mar 19 2014, 04:37 PM |
V0810 added
| Posted: Mar 20 2014, 08:17 PM |
v0.8.1.1 [20 Mar 2014] After a night sleep, thought of a better way to get the very end frames of the source file
| -vdub- |
| Posted: Mar 21 2014, 06:18 PM |
As many people need guidance to unpack this to the correct PluginsXX directory. Using a 7z archive that has a script to copy only the files and folders. This would not be an installer only a copy script that 7z executes so nothing is added to the registry install/uninstall locations etc. I have seen this type of 7z install script with other softwares that works as needed
Anyone needing to still unpack as normally should be able to do so if correct 7z archive type is used (unknown which supports script and normal unpack). Although I have seen this type of 7z archive done with a few other softwares previously. 7z could also be used to compress the FFMpeg archive further using settings such as 7z | Ultra | LZMA (or better)
As long as script can detect what version Virtualdub is been unpacked to. maybe it checks for PluginsXX folder name to do so. Better if is done automatically after Virtualdub folder destination is chosen for when many Virtualdub are at the same location, example
SameDrive:\ABC\Virtualdub1\ SameDrive:\ABC\Virtualdub2\ SameDrive:\ABC\Virtualdub3\
note: Unknown if 7zip still has this type of archive PluginsXX - Plugins, Plugins32 or Plugins64 |
| Posted: Mar 21 2014, 06:48 PM |
There's a setup installer on the sourceforge page now that lets you pick a folder with virtualdub in (32 or 64 bit) and puts the right files in the right place
| Posted: Mar 21 2014, 11:56 PM |
0812 beta Fixes frame stepping backward Better seeking https://sourceforge.net/projects/virtualdub.../V0812%20beta1/
I'd appreciate any comments better/worse thanks - pm's best, to avoid clogging the thread (there are so many formats etc out there I can't check if making one thing better has broken a different thing)
Confirmed problems H265 - trouble with seeking AVCHD - trouble with seeking I can't see anything obvious the plugins doing wrong - possibly it's ffmpeg's dlls, as ffmpeg.exe also has trouble with the samples I've tested
| moody2014 |
| Posted: Mar 25 2014, 10:54 PM |
| QUOTE (dloneranger @ Mar 21 2014, 11:56 PM) | 0812 beta Fixes frame stepping backward Better seeking https://sourceforge.net/projects/virtualdub.../V0812%20beta1/
Confirmed problems H265 - trouble with seeking AVCHD - trouble with seeking I can't see anything obvious the plugins doing wrong - possibly it's ffmpeg's dlls, as ffmpeg.exe also has trouble with the samples I've tested |
Crash opening any video file with latest 64 bit Zeranoe FFmpeg dll's Build (avcodec-55 version 55.54.100.0, avformat-55 v.55.35.100.0, avutil-52 v.52.69.100.0 and swscale-2 v.2.5.102.0) |
| Posted: Mar 25 2014, 11:20 PM |
You can't just swap dll's If the dll's conventions have changes at all (between the ones it comes with and the ones your trying) the plugin has to be recompiled with the new sdk files that match the new dlls
| moody2014 |
| Posted: Mar 25 2014, 11:28 PM |
| QUOTE (dloneranger @ Mar 25 2014, 11:20 PM) | You can't just swap dll's If the dll's conventions have changes at all (between the ones it comes with and the ones your trying) the plugin has to be recompiled with the new sdk files that match the new dlls |
Ok, it means I can not update only the dll without recompile the all plugin, it's a pity.
I have updated until git-63dbba6 (23-Mar-2014) and work great only not work with new git-c25d2cd
thanks |
| Posted: Mar 25 2014, 11:41 PM |
ffmpeg 2.2.0 should be on Zeranoes' site soon I'll recompile with that when it's out, as I'd prefer to include a stable build that a dev one
| Posted: Mar 26 2014, 05:07 PM |
0812 test version https://dl.dropboxusercontent.com/u/1702491..._test_razon.zip
razon sent me some test files that didn't seek properly (AVCHD) once you had seeked, you couldn't step forwards/backwards properly and all you got were keyframes every so often
hopefully this fixes it, but it's a bit slower at seeking if this problem happens the decodable keyframes are so far apart you have to keep seeking further and further back until you get something you can work with and then scoot forwards to the right place should solve other problems where the pts's and dts's are really out of whack
if this doesn't break anything for anyone the new version will be out when zeranoe updates the ffdlls to v2.2.0
| moody2014 |
| Posted: Mar 27 2014, 03:57 PM |
Thanks, now work with lastest git |
| Posted: Mar 27 2014, 04:10 PM |
It's using ffmpeg-20140326-git-c05065a so it should be ok to swap them around for a while
| Posted: Mar 28 2014, 03:10 PM |
v0.8.1.2 [28 Mar 2014] Fixed some formats with large keyframe intervals or weird pts/dts had trouble seeking and would only show keyframes after the first seek Extra seeking further back to find a valid keyframe is done now if an initial seek fails Some seeking optimizations Updated FFMpeg dlls to 27/03/2014 - v2.2.0 isn't on zeranoes site, so these are the first dlls after v2.2.0
