Pages: (26) « First ... 10 11 [12] 13 14 ... Last » ( Go to first unread post )
Ffmpeg Input Driver, Experimental driver based on ffmpeg libs
Posted: Mar 2 2014, 05:26 PM
V0809
Fixes a silly bug I made in 0807 when downsampling audio
Posted: Mar 2 2014, 09:02 PM
@dloneranger
Thanks a lot for all your effort to make this inputdriver better with every next release.
This time, I can not get to download your newest version 0.8.0.9 ... Can you please verify the hyperlinks ?
http://sourceforge.net/projects/virtualdub...in/files/V0809/
Posted: Mar 2 2014, 09:48 PM
sourceforge takes a while for it to populate to all mirrors
you might see a little clock icon on the far right of the filename, that means it hasn't reached the mirror site you're on
(does seem to be a bit slow today though)
Posted: Mar 3 2014, 12:12 AM
Sourceforge is full of 'why are my downloads not showing up?' on the support pages
So, just for now
https://dl.dropboxusercontent.com/u/1702491...Plugin_0809.zip
Posted: Mar 3 2014, 05:47 PM
Thanks for the additional information.
This monday-evening - 18:30 - the files were available via Sourceforge.
Unfortunately with this version, when opening whatever MP4 or FLV (not yet tried with other video container formats), VirtualDub 1.10.5 (build 35512) crashes with following crashinfo (extract):
Crash reason: Illegal instruction
Crash context:
An instruction not supported by the CPU was executed in module 'FFInputDriver'.
Version 0808 does not have this problem. For me it seems to be the FFInputDriver.vdplugin file that causes the problem (not the dll's).
(I have a Windows 7 - 32-bit Home Edition)
Posted: Mar 3 2014, 06:15 PM
I'll put fixed ones up (I used the AVX build by mistake)
Gral
Posted: Mar 3 2014, 07:23 PM
I had the same problem.
It's OK now, with new build.
Thank you.
Posted: Mar 3 2014, 07:42 PM
I can also confirm that the problem has been resolved now - no more crash on opening MP4 or FLV files with the 32-bit version of the 0809 release.
(I see that the 64-bit version has not been recompiled... maybe that AVX problem was not in there ?)
Also confusing behaviour on those Sourceforge servers...
Via the Summary-tab and the darkgreen Download-button I got the most recent and correct(ed) version (3 March 2014).
Via the Files-tab and subfolder V0809, I still get the older version (2 March 2014).
Thanks and kind regards.
Gral
Posted: Mar 3 2014, 07:50 PM
I never use http for download, only for browse and locate. When i know or expect new version of any software on sourceforge just go directly to ftp mirror (Heanet in Ireland is one of the best)
- ftp://ftp.heanet.ie/mirrors/download.sour...peginputplugin/ in this case.
Posted: Mar 3 2014, 08:02 PM
QUOTE (Abrazo @ Mar 3 2014, 08:42 PM)
Yeah - I put the wrong 32bit version in and the 64bit one was fine
Sourceforge is just weird at times
What I'll do from now on is put the version number as part of the zip file name so it's obvious what your getting
You know what?
I'm going to blame Twin Peaks
Amazon's prime has just added video in the UK and I was having a Twin Peaks weekend at the same time as doing this
Posted: Mar 3 2014, 08:09 PM
Thanks for your information Gral.
Myself, I would never had gone that way to look for a copy ...
I just guess, next time I am going to wait a bit longer before downloading...
Also thanks to dloneranger... Good idea to put the version number into the ZIP's filename.
DarrellS
Posted: Mar 7 2014, 06:13 PM
32bit still broken. Crashes Virtualdub. Trying to open HEVC in Virtualdub. Was sure that I used to be able to open HEVC months ago without using any plugins. Not sure why I'm having problems now.
Posted: Mar 7 2014, 07:38 PM
A lot depends on the ffdlls and the file itself - all the actual decoding etc is done by that
(in a crash I'll usually see avutil-52 as the cause)
If I run that crashing file through ffmpeg's standalone .exe I'll normally see a lot of errors thrown up
FFMpeg itself is still very much a work in progress and improving as time goes by - two steps forwards (and one back sometimes)
I'll keep it updated, and you can always download the latest dlls from their site
H265 is one area that's still very new
I don't get any problem with a sample at http://labs.divx.com/node/127909 though
raffriff42
Posted: Mar 7 2014, 07:42 PM
Hi DarrellS, did you delete the old plugins32\ffdlls folder before unzipping?
Posted: Mar 15 2014, 05:55 PM
Upgraded next version to 810 beta and moved to sourceforge page
It's not quite 810 yet as there are a few other little things I want to do to it first
Changes
Problem that caused incomplete video frames to be returned to virtualdub (garbled moving blocks) especially after seeking
Problem with some formats (eg mkv) when seeking back to the start of the file
Problem with the wrong video frame being shown (repeatedly) after turning audio display off and back on
(Some of these problems only happen with virtualdub's audio display turned on)
378 replies since May 10 2011, 10:20 AM Track this topic | Email this topic | Print this topic
