Pages: (4) 1 2 [3] 4  ( Go to first unread post )
Video .ts
malky
Posted: Apr 21 2011, 03:48 PM
Comments are for my Win7 64 bit system.
Opening the folder using Windows Explorer and selecting 'Run as Aministrator' generates an error message.
Simply running the Command Prompt and running the .bat file(s) generates error message.
Selecting the Command Prompt and running that as Administrator will allow running the .bat file(s) without error.
The Read Me file is quite explicit that a 64 bit system uses the bat file in the x64 folder.
"Note that this zip contains two builds of the codec. The files in the
"x86" folder are for Windows 32-bit operating systems, and the files
in the "x64" folder are for Windows 64-bit operating systems."
As long as the Command Prompt is being run as Administrator, the file runs without error and Control Panel shows the codec as being installed.
As regards to the sample from 'marande', the .ts file will not load (even with 'DirectShow input driver' selected) - in my case VirtualDub freezes.
Demuxing the .ts file and loading via AviSynth gives an error indicating that the aac file format is not supported.
Using VLC command line to strip out the LATM wrapper, a new aac file can be loaded using Avisynth.
VirtualDub will not play this audio and will not convert it to stereo because 'the source channel count is not supported - must be mono or stereo'.
Converting this multi-channel aac file to another format allows the audio to be loaded and the new avi saved.
This LATM wrapper business seems to be a common problem in UK - Aus and NZ according to the posts I have read and there does not seem to be a simple solution offered to get around it.
ale5000
Posted: Apr 21 2011, 04:48 PM
QUOTE (malky @ Apr 21 2011, 04:48 PM)
Because you aren't using my fixed version (AACACM-AC3ACM_fix_2.zip).
The readme is wrong, in my updated version I have fixed also the readme.
The AAC ACM Codec support multichannel aac audio, with direct stream copy it will work directly instead if you want to convert you must set Audio => Conversion => Stereo.
New VirtualDub forum
marande
Posted: Apr 21 2011, 04:54 PM
QUOTE (malky @ Apr 21 2011, 03:48 PM)
So there is no way to open the file .TS in Virtualdub?
ale5000
Posted: Apr 21 2011, 05:00 PM
QUOTE (marande @ Apr 21 2011, 05:54 PM)
The video is loaded directly on my pc (with 'DirectShow input driver' selected), I'm not sure why it doesn't work on your pc.
For audio you must demux it and import separately (at least until someone fix the Gabest/Haali splitters to support it).
malky
Posted: Apr 21 2011, 05:53 PM
I downloaded the fixed version and uninstalled the first version.
I can open the folder on the Desktop and 'Run as administrator' ok to install the codec.
The results were the same as before, the .ts file has to be demuxed and the audio converted.
marande
Posted: Apr 21 2011, 06:56 PM
As I understand it, in Win 7 x64, without converting the audio file, the .TS does not work in Virtualdub. Am I correct?
ale5000
Posted: Apr 21 2011, 07:07 PM
When opening the .ts file it just ignore the audio, so it isn't that the cause of your problem with opening the ts (that won't have audio).
For the audio I'm saying that you can also demux without convert it.
Edit: Using VLC gui you can remux the audio in another container.
Open VLC => Media => Convert / Save => Add file => press "Convert / Save" =>
Set "Destination file" => Add new profile => select Encapsulation: MKV, Video: unchecked, Audio: Keep original audio track => Select the new profile => Press Start.
marande
Posted: Apr 21 2011, 08:54 PM
But Malky said VirtualDub freezes when trying to open my file, if I understand correctly. And here also happens.
What to do?
ale5000
Posted: Apr 21 2011, 09:30 PM
It doesn't freeze here (on Win XP).
Check that you have the latest version of the DirectShow input plugin.
You could also try to set ffdshow as preferred for H.264 with Win7DSFilterTweaker.
marande
Posted: Apr 22 2011, 02:02 AM
Please explain to me that part of trying to set up ffdshow as favoring Win7DSFilterTweaker with H.264.
ale5000
Posted: Apr 22 2011, 04:00 AM
Win7DSFilterTweaker is inside K-Lite Codec Pack.
Just run it, click on Preferred decoders, select ffdshow under H.264 and confirm.
marande
Posted: Apr 22 2011, 01:32 PM
I found Codec Tweak Tool, but found Win7DSFilterTweaker.
Where is it?
ale5000
Posted: Apr 22 2011, 07:32 PM
It should be under start menu => All programs => K-Lite Codec Pack => Tools
Or you can take it directly here: http://www.codecguide.com/windows7_preferr...ter_tweaker.htm
marande
Posted: Apr 22 2011, 10:25 PM
Now I found it. But I do not know how to run after him. A window appears with three options. Which one should I choose?
marande
Posted: Apr 26 2011, 01:49 AM
45 replies since Apr 16 2011, 07:27 PM Track this topic | Email this topic | Print this topic
