Pages: (4) 1 [2] 3 4  ( Go to first unread post )
Video .ts
marande
Posted: Apr 19 2011, 01:42 PM
Screenshot.
I tried to open the way you said it did not work.
You could open it normally?
Thanks.
ale5000
Posted: Apr 19 2011, 03:54 PM
You can't open it normally, only with "File => Open video file => select the video (single click, not double click) => select "DirectShow input driver" from drop down list => select the Open button".
Explain exactly what happens.
New VirtualDub forum
marande
Posted: Apr 19 2011, 06:55 PM
The space of the video goes black, the program virtually lock, but there is no picture.
malky
Posted: Apr 20 2011, 05:53 PM
FWIW.
Audio seems to have a LATM? wrapper.
I demuxed the ts file using DGMPGDec (DgIndex).
Used Winamp to load the aac audio and convert to a wav.
Used Avisynth to load the .dga and the new .wav into VirtualDub (I couldn't hear the audio in VD - perhaps because it's 6 channels) -but it saved ok to the avi and played back ok using VLC.
LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\DGAVCDecode.dll")
Video=AVCSource("C:\Users\Superuser\Downloads\Desktop\_dgi\por.dga")
audio=wavSource("C:\Users\Superuser\Downloads\Desktop\_dgi\-1 - 1035ms.WAV")
AudioDub(Video, Audio)
ale5000
Posted: Apr 20 2011, 06:34 PM
Why convert the aac/he-aac audio?
VirtualDub can import the aac/he-aac audio (not directly, but it works fine if it is inside avi, flv or mkv/mka).
malky
Posted: Apr 20 2011, 07:29 PM
I can't load aac audio - using W7.
ale5000
Posted: Apr 20 2011, 09:29 PM
Edit: Post removed
malky
Posted: Apr 20 2011, 10:25 PM
I know.
It won't install in W7.
The 32 bit version installs under XP OK.
ale5000
Posted: Apr 20 2011, 10:28 PM
Edit: Post removed
plamengv
Posted: Apr 21 2011, 01:10 AM
QUOTE (malky @ Apr 20 2011, 10:25 PM)
I know.
This is how I did it.
1. Extract the AACACM archive somewhere.
2. Copy the files from x86 to C:\
You may need to disable UAC to be able to copy files there.
3. Install the x86 version by running the BAT file from elevated Command Prompt window.
4. Remove the files from C:\
5. Copy the files from x64 to C:\
6. Install the x64 version by running the BAT file from elevated Command Prompt window.
7. Remove the files from C:\
I did it that way because I knew from Huffyuv that this is the proper way to install both versions of Huffyuv (32bit & 64bit) on Windows 7 64bit.
ale5000
Posted: Apr 21 2011, 01:37 AM
@plamengv: You really don't need this mess if you follow my instructions.
To make clear you must use the x86 folder for 32-bit VirtualDub instead the x64 folder for 64-bit VirtualDub (the bit of the OS doesn't matter).
ale5000
Posted: Apr 21 2011, 12:18 PM
Try with the updated files here: http://forums.virtualdub.org/index.php?act...t=40#entry85120
Note: You must right click the .bat file an select "Run as administrator" if you are using Windows Vista or higher.
marande
Posted: Apr 21 2011, 01:21 PM
Why I still can not open it?
ale5000
Posted: Apr 21 2011, 01:29 PM
Edit: Post removed
ale5000
Posted: Apr 21 2011, 01:30 PM
Edit: Post removed
45 replies since Apr 16 2011, 07:27 PM Track this topic | Email this topic | Print this topic
