| ale5000 |
| Posted: Dec 25 2010, 12:38 PM |
There isn't SBR in Hatsune Miku Sings Levan Polka.flv file, sampling rate is really 22.05 KHz It was a mistake, because I have now discovered that libfaad2 used by ffdshow-tryout for decoding aac erroneously set as SBR all aac tracks with low sampling rate.
Many players/decoders upscale all aac files with low sampling rate to 44100 Hz in any case. The "Audio output sampling frequency" in mkv header is wrong sometimes.
You can't use only SBR / PS info from the header in any container because often they aren't declared, you need to directly parse aac like mediainfo (look for implicit SBR / PS detection).
Edit: The file from the example is different, here the HE-AAC - HE-AACv2 audio test file (file from the example): http://www.megaupload.com/?d=NUBLKZYJ It is an .mkv with 2 audio tracks (no video track otherwise the file would be a lot bigger).
Edit2: You can see the aac parser here: http://mediainfo.svn.sourceforge.net/viewv...io/File_Aac.cpp
| jpsdr |
| Posted: Dec 26 2010, 01:58 PM |
The thing i don't understand, is that i've no mkv pluggin installed for VDub, but i can open mkv file without problem... I'm not complaining, of course, but i'm curious to know why... I've on my PC installed Haali splitter, ffdshow (+VDub filter), and Directshow plugin of Avery Lee. When i open an mkv with VDub, i see the icon of Haali (twice) and one of ffdshow. Just curious... |
| L.H.V.F. |
| Posted: Dec 27 2010, 12:28 AM |
| QUOTE (fccHandler @ Dec 25 2010, 02:26 AM) | L.H.V.F.: Try this one instead: http://fcchandler.home.comcast.net/TestFLV.zip It is the same version 1.3, but built with Visual C++ 6.0 instead of Visual Studio 2005. I will be very interested if this makes a difference for you. |
Hi, fccHandler
I have tested your compilation of Visual C++ 6.0, and the problem that I have noticed about the Input side no loads a video to be continued in limited account user. But now I have opened in Administrator account and the K-Lite Mega Codec have indicated that various codec registry entries are truncated. I think this strange because runs a video in limited user, and Administrator not (?). The moitah plugin no needs a Administrator account for works right.
After I test the VirtualDub with other instalation (MISSING CODEC) in Administrator account, I will go post a reply of the results.
I have tested your plugins in Administrator account, after uninstall earlier version with problems, and now in Administrator account the plugins works right. Again I would say that Moitah plugin works equal in any user mode. Snapshot of my Control Panel: http://img339.imageshack.us/i/imageofcontrolpanel.png/
The Visual Studio 2008 of accord with the my teacher has a different functions, others no exists more, and that would can there problems in different compilators (2005-2008). I have Visual C++ 2008.
I can see one problem in the last update of FLV plugin in this video: 20101214bl3_1292371138.flv http://img69.imageshack.us/i/snapshotgreenscreen.png/ Moitah plugin not shows a green screen in the first frame: http://img683.imageshack.us/i/snapshotmoit...itahplugin.png/
Respectfully, L.H.V.F. |
| dumah |
| Posted: Dec 28 2010, 04:08 PM |
Matroska also has a green color in the first few frames, when I converted to AVI (xvid) he also gets the green frames, sometimes it happens that the converted MKV to AVI is not correct. |
| ale5000 |
| Posted: Dec 28 2010, 04:50 PM |
@L.H.V.F.: If the plugin appears in the list, but it just say MISSING CODEC it can also be that the plugin is working correctly but it is ffdshow-tryout that isn't working correctly (I'm talking about the VFW part of ffdshow-tryout). I'm not sure if the Moitah plugin is using VFW or not.
| L.H.V.F. |
| Posted: Dec 28 2010, 09:34 PM |
| QUOTE (ale5000 @ Dec 28 2010, 04:50 PM) | @L.H.V.F.: If the plugin appears in the list, but it just say MISSING CODEC it can also be that the plugin is working correctly but it is ffdshow-tryout that isn't working correctly (I'm talking about the VFW part of ffdshow-tryout). I'm not sure if the Moitah plugin is using VFW or not. |
I was referring about the different forms of works of the plugins. The Administrator account runs normally any video, and differently one limited account have problems, that I have noticed many times, this account not loads a video in Input side. The Moitah plugin runs a video without problems, independently of user hierarchy. The problem of (MISSING CODEC) has been solved, was only I uninstall the earlier K-Lite Mega Codec, for install other more recent that problem of codecs that I can solved this problem. Other problems that I can see is in this video 20101214bl3_1292371138.flv, this problem is independent of user mode, the fccHandler FLV plugin show a green screen in the first "key" frame, and in the Moitah plugin not, shows only a black frame.
Snapshot of my control Panel: http://img339.imageshack.us/i/imageofcontrolpanel.png/
The fccHanlder developer made a same program compilated with Visual C++ 6.0, and the first problem persists under a limited user account (...Input side not loads a video...). Other problems are secondary.
http://img69.imageshack.us/i/snapshotgreenscreen.png/- FLV fccHandler plugin
http://img683.imageshack.us/i/snapshotmoitahplugin.png/- Moitah plugin
Have you downloaded the mentioned video 20101214bl3_1292371138.flv ?
Thanks, L.H.V.F. |
| ale5000 |
| Posted: Dec 29 2010, 01:38 AM |
@L.H.V.F.: The file "20101214bl3_1292371138.flv" works well with the latest version of the flv plugin of fcchandler. The problem of the first frame being green isn't specific to .flv files, you get it also for .mkv for example. I really don't think that the compiler is the problem and also just because it is compiled with Visual Studio doesn't necessarely mean that the file depend on .net framework.
I haven't had time to try on a limited user so I cannot say anything for now.
| Loadus |
| Posted: Dec 31 2010, 11:48 AM |
@fcchandler: I remember that you weren't very fond of a plugin that writes stuff on it's own, but I'm still requesting this.
Could you cook up a version of the MKV plugin and your (awesome) MPEG-2 plugin that automatically write an index file right next to the original file (ie. without going to advanced settings)? I open the files usually with SendTo, and if there is an existing index, VirtualDub will open the file in a zap.
If it's too much hassle and work, then no probs.
Thx again for these awesome plugins, especially the MPEG-2 one. ^^
| L.H.V.F. |
| Posted: Jan 3 2011, 02:17 AM |
Hi ale5000 and fccHandler
Now I have tested on my other computer, under limited user account, this windows xp SP3 original and constantly updated, and the plugin works correctly, runs the video in Input Side. The problem, how I can see, comes of the part of the compilator. The other computer has only Visual C++ 2008 as compilator, and the windows original has both, 2005 and 2008 in the library. My teacher was right in the incompatibility of the compilators, is necessary to have both. However this windows are formated in FAT32, instead of NTFS, and not blocks to write in Program Files (Arquivo de Programas), and WINDOWS\System32...
Snapshot of the Control Panel of the other computer: http://img684.imageshack.us/i/imageofcontrolpanel.png/
Thanks, L.H.V.F. |
| chornobyl |
| Posted: Jan 3 2011, 05:27 PM |
@fccHandler On your website, page "FLV plugin Change Log" have wrong title "FLIC plugin Change Log". |
| L.H.V.F. |
| Posted: Jan 8 2011, 12:09 AM |
Hi ale5000
The moitah FLV Input Driver, since that I use this, before of the fccHandler leave available in his site, in the moitah plugin was needed in the VirtualDub a decoder, and in this plugin have exhibited message of error, if not there was a decoder. Then I would went search a decoder, and at time I found this: http://www.4shared.com/file/wVx1iOS7/vp6_decoder.html. The problem of need a decoder specific, not became impossible to use the moitah plugin, but fccHandler plugin runs maybe without this problem of need the decoder. I can open more videos with this decoder installed in the moitah plugin, despite of be an On2 VP6 decoder.
Edit: The new link of the VP6 On2 Decoder are now at:
https://docs.google.com/file/d/0B2P9tmmpSwF-eUdEMWJXVUhMWXc/edit?usp=sharing (vp6 decoder.zip)
4Shared has blocked for only registered users do download of the shared files.
Edit (2): My Minus.com account and online folder were deleted, because for a long time this sharing service was not working, and was not giving features of a sharing site that I previously and initially, wanted.
| ale5000 |
| Posted: Jan 9 2011, 12:04 AM |
@L.H.V.F.: I didn't really understand your message but you don't need a specific "vp6 decoder" since ffdshow-tryout already contains a vp6 decoder (you just need to enable it in it's vfw configuration).
| L.H.V.F. |
| Posted: Jan 9 2011, 03:32 AM |
| QUOTE (ale5000 @ Jan 9 2011, 12:04 AM) | | @L.H.V.F.: I didn't really understand your message but you don't need a specific "vp6 decoder" since ffdshow-tryout already contains a vp6 decoder (you just need to enable it in it's vfw configuration). |
Before the fccHandler developer release your FLV plugin, I had used moitah plugin. At time I had not how opened my FLVs videos in VirtualDub, the plugin showed a error, saying of missing of a decoder. I don't know if I not would had a decoder if the moitah plugin would go function correctly, but after that I had installed the On2 VP6 decoder and the error disappeared in the moitah FLV Input Driver.
In other case, in the first release of WMV fccHandler plugin, it have showed a message in one video that I have, saying of fault of codec. Then I installed a decoder and the problems was solved. The video in WMV, that I will go to post one day, despite of have the codecs with K-Lite Mega Codec, stay missing a codec anyway, on the video or audio until install a decoder. The codec of last file mentioned is a hack, and this video works different of official, and needs to install a specific codec/decoder of microsoft. |
| Posted: Jan 9 2011, 07:20 AM |
| QUOTE (chornobyl @ Jan 3 2011, 01:27 PM) | @fccHandler On your website, page "FLV plugin Change Log" have wrong title "FLIC plugin Change Log". |
Good catch, thanks!
http://fcchandler.home.comcast.net/Plugins/FLV
| ale5000 |
| Posted: Jan 9 2011, 02:31 PM |
@L.H.V.F.: Your automatically translated "english" is really difficult to understand, it would be better if you divide the text in more simple phrases. If it showed an error then it means that ffdshow-tryout isn't configured correctly. Try to post a screenshot of the VFW configuration of ffdshow-tryout.
