Pages: (23) « First ... 17 18 [19] 20 21 ... Last » ( Go to first unread post )
New FLV and Matroska plugins for VirtualDub, (works in progress)
Posted: Jul 2 2011, 07:00 PM
Matroska plugin v3.0 is released:
http://fcchandler.home.comcast.net/Plugins/Matroska
EasyRider
Posted: Jul 2 2011, 10:14 PM
EasyRider
Posted: Jul 2 2011, 10:37 PM
I try to open this file with VD and v3.0 plugin:
Complete name                    : C:\Documents and Settings\.....\starwars10MB-1.mkv
Format                           : Matroska
File size                        : 9.96 MiB
Duration                         : 36s 43ms
Overall bit rate                 : 2 319 Kbps
Encoded date                     : UTC 2003-08-01 21:18:13
Writing application              : VirtualDubMod 1.5.4.1a (build 1946/release)
Writing library                  : libebml-0.5.0 & libmatroska-0.5.0
Video
Format                           : MPEG-4 Visual
Format profile                   : Advanced Simple@L3
Format settings, BVOP            : Yes
Format settings, QPel            : Yes
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : XVID
Codec ID/Hint                    : XviD
Duration                         : 36s 40ms
Bit rate                         : 2 177 Kbps
Width                            : 696 pixels
Height                           : 288 pixels
Display aspect ratio             : 2.35:1
Original display aspect ratio    : 2.40:1
Frame rate                       : 25.000 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.434
Stream size                      : 9.35 MiB (94%)
Writing library                  : XviD 0.0.09 (UTC 2003-03-25)
Language                         : English
Audio
Format                           : Vorbis
Format settings, Floor           : 1
Codec ID                         : A_VORBIS
Duration                         : 36s 43ms
Bit rate mode                    : Constant
Bit rate                         : 96.0 Kbps
Channel(s)                       : 2 channels
Sampling rate                    : 48.0 KHz
Video delay                      : 8ms
Stream size                      : 422 KiB (4%)
Writing library                  : libVorbis 1.0 (UTC 2002-07-17)
Language                         : English
File open ok with mpc-hc .
But have some issues with sound in Virtualdub..
(No audio compressor could be found to decompress the source audio format..)
Posted: Jul 2 2011, 11:03 PM
It is Vorbis audio. The Vorbis support is very experimental right now, and the worst part is that currently there is no Windows codec which will work with it. Vorbis can be direct stream copied (sort of), but it cannot be played in VirtualDub.
If you just want to play the video, choose Audio -> No Audio to disable the audio track.
EasyRider
Posted: Jul 2 2011, 11:17 PM
yea, i see that right after the post.. even i install OGG Vorbis ACM Codec 0.0.3.6 nothing happen at all.. dry.gif
I just wand to convert to avi for hardware dvd player that not support mkv..
(any idea how to split / transcode audio to another format an insert to video..)
Anwy.. thanks mate
katz
Posted: Jul 3 2011, 02:52 PM
QUOTE (fccHandler @ Jul 2 2011, 07:00 PM)
Many thanks for your work!
I just have to report a bug with the AC3 input on VDub64. While the 32-bit works fine, on the 64-bit version when I play a file with an AC3 audio track I only get a loud pop when it starts/stops and no audio playback. I have your latest input plugin and standalone ACM installed and I am using VirtualDub 1.9.10 AMD64 build on Windows 7 x64.
ale5000
Posted: Jul 3 2011, 03:57 PM
QUOTE (EasyRider @ Jul 3 2011, 12:17 AM)
Althought the name is "OGG Vorbis ACM Codec" it is like a different (not compatible) format.
New VirtualDub forum
Posted: Jul 4 2011, 05:29 AM
QUOTE (katz @ Jul 3 2011, 10:52 AM)
To be honest, I've never tested the 64-bit build because I don't own a 64-bit machine myself. However, I can test it at work after the July 4th holiday. I will let you know if I discover any problems with the 64-bit build...
Posted: Jul 10 2011, 04:33 AM
@katz:
I tested the 64-bit build of AC3ACM at work. It was kind of tricky because our 64-bit work machines are servers which do not have audio cards! Nevertheless I was able to confirm it using Veedub64 to decompress the audio to .wav files, then I brought the .wav files home to inspect them. They are indeed silent.
The last 64-bit version which was confirmed to work was version 1.5, but there were significant changes during the migration to 1.6. Sadly I don't have any way to debug this directly, but I suspect a problem with the assembly portion of the code. I explored that part in agonizing detail over the weekend, and put it through a battery of tests.
I found to my surprise that decompression of 5-channel audio was broken, and it probably has been for a long time. It is fixed now.
In addition to that, I made a subtle change to the 64-bit build, and I would like you to test it and let me know if it fixes your problem:
http://fcchandler.home.comcast.net/AC3ACM
ale5000
Posted: Jul 10 2011, 10:33 AM
Minor thing: You haven't updated the version in the inf files of both AAC ACM anc AC3 ACM.
Posted: Jul 10 2011, 04:24 PM
Oops, thanks for catching that. It's fixed now.
Dstruct
Posted: Jul 11 2011, 03:52 PM
Minor bug: AAC ACM Codec 1.7 is still listed as "AAC ACM Codec 1.6" in Software Uninstall Control Panel ...
FIXED
ale5000
Posted: Jul 11 2011, 10:48 PM
Edit: Post removed
Dstruct
Posted: Jul 12 2011, 04:34 PM
Thanks. Fixed.
ale5000
Posted: Jul 13 2011, 03:01 PM
Since the Matroska input plugin support also audio-only files and the current message isn't clear, maybe it can be changed from "File ... does not have a video stream." to "File ... does not contain supported tracks or it isn't a Matroska file."
337 replies since Sep 26 2010, 04:58 AM Track this topic | Email this topic | Print this topic
