Filter Use, settings
dizzy23nc
Posted: Jan 22 2003, 01:00 AM
I'm using the deinterlacer map and resize filters. Resize has an option for interlacing. Should I check that box if I'm using the map filter?
Also, the background images are not as clear as the rest of the picture. For example: a car driving toward you is clearer the closer it gets. Would the sharpen filter work for this?
jcsston
Posted: Feb 2 2003, 03:14 AM
Matroska Dev
QUOTE (dizzy23nc @ Jan 21 2003, 07:00 PM)
No, If you are deinterlacing before you resize (which I recommend) you video will be (hopefully) progressive and not interlacing settings would be needed
It may be blurry because of a low video bitrate
Use the Matroska file format
1 replies since Jan 22 2003, 01:00 AM Track this topic | Email this topic | Print this topic
