Pages: (20) « First ... 8 9 [10] 11 12 ... Last » ( Go to first unread post )
Directshow Input Driver, 0.1
Sina
  Posted: Jun 23 2009, 07:32 AM
QUOTE (stephanV @ Jun 23 2009, 07:04 AM)
No.
too bad.
what about next version?
Posted: Jun 24 2009, 03:45 AM
I'm afraid I don't see the point in doing this...?
stephanV
Posted: Jun 24 2009, 07:13 AM
Some people prefer to keep the amount of installed DirectShow filters to a minimum. Conflicting filters sometimes break games or other applications.
useful links:
Jam One
Posted: Jun 24 2009, 11:46 AM
...Ah... For the players it also means they can be launched from CD,
and play video recorded on this CD with use of *.dll-s supplied on this CD,
no matter if the OS have got the necessary codecs installed.
nieko_nera
Posted: Sep 12 2009, 07:55 PM
Corrupted video frames in final encode if i cut video
video sample: gme.ts, processing settings: gme.vcf
How to reproduce:
Open gms.ts in Virtualdub, load processing settings file gme.vcf, save as avi.
Open saved avi in Virtualdub and go to frame 1283
But if i save same gme.ts as avi without cuts there is no corrupted frames, and if i open gme.ts in VirtualDub, load processing settings, and before save as avi, i check frame 1283 is good, without corruption.
Thank You
my English is bad, sorry
DarkArchon
Posted: Oct 4 2009, 11:58 PM
I'm trying to open an FLV file, but I the FLV plugin for VirtualDub won't work, so I tried the Directshow plugin and keep getting this error...
"Unable to render audio stream: hr=80004005"
I've seen it mentioned in this topic, and appears to mean that there isn't a sound track to go with it (or one can't be found?), but this gets me no closer to solving the problem or really understanding this error, can anyone shed some light on it? BTW, the video file I'm working with does have audio, some more information about it...
Stream 1:
Type: Audio
CodecL mp3
Sample rate: 22050 Hz
Bits per sample: 16
Stream 0:
Type: Video
Codec: FLV1
Resolution: 400x226
Display Resolution: 400x226
Placio74
Posted: Oct 5 2009, 05:16 AM
VideoAudio
QUOTE (DarkArchon @ Oct 5 2009, 01:58 AM)
You have installed required DirectShow filter - FLV Splitter...?
http://www.videohelp.com/tools/FLV_Splitter
BTW
Any sample FLV file?
realdark86
Posted: Oct 18 2009, 02:33 PM
HELLOOO...
Could you please post the plugins, (especially x64) somewhere else other than megaupload?
Thanks...............
Placio74
Posted: Oct 18 2009, 05:23 PM
VideoAudio
QUOTE (realdark86 @ Oct 18 2009, 04:33 PM)
HELLOOO...
Hmm... I put recompiled plugins on SkyDrive.
NeXT
Posted: Oct 31 2009, 09:35 PM
Avery, I have some issues/questions about DS Input Driver.
1. When VD doesn't find any suitable VFW decoder, it doesn't automatically use DSInput, which is not very convenient.
2. Is DS Input Driver frame-accurate? What in your opinion is the best way to achieve frame-accurate recode?
a. VD-VFW
b. VD-DSInput
c. VD + AviSynth-DSS2
(first, I used a, but after some issues I switched to b)
Posted: Nov 1 2009, 01:27 AM
VirtualDub can't auto-switch at the codec level. The reasons are that the DirectShow input driver is an input driver and not a codec, and the second reason is that DirectShow codecs have a fundamentally different (and far more annoying) interface than the regular VFW codecs. The problem is that DirectShow codecs are stream-based, where the application has to push frames through and hope that the codec produces one at its output at some undermined point in time. It's much easier for the DirectShow input driver to handle this because it also lets DirectShow handle the container format. The downside is that currently this means you cannot use Direct Stream Copy mode.
As for frame accuracy, the VD-VFW path will give you the best results for cases where B frames are not used, especially for lossless or keyframe-only formats. This is also the fastest mode as VirtualDub has full control over the decoding path and can quickly short-cut frames that it doesn't need to decode. For MPEG-4 or other highly compressed formats that have B-frames, you will get a one-frame lag in this mode which will not be a problem if you use the DirectShow paths. As for the DirectShow input plugin vs. Avisynth's DirectShowSource, I can't say, but they are fairly similar in design and use the same underlying decoders and splitters.
NeXT
Posted: Nov 1 2009, 03:02 AM
QUOTE (phaeron @ Nov 1 2009, 08:27 AM)
Ok, I see the point. It's just confusing when you try to open a video file and VD returns an error box instead of opening that file (and, btw, when you select correct driver in the Open dialog, it doesn't show you *.avi files -- you have to manually type '*.*' and only after that choose desired avi).
What do you mean by 'DirectShow paths'?
Yeah, there's nearly no point in using DirectShowSource. I was asking about DSInpit vs DSS2 smile.gif
Posted: Nov 1 2009, 07:38 PM
Nearly all DirectShow-based input methods use similar methods and code paths in that they set up a DirectShow graph to render the file and then replace the endpoints with either a custom sample grabber or renderer to capture the output, leading to similar behavior.
NeXT
Posted: Nov 1 2009, 08:17 PM
Hm, I heard many times, that 'DSS2 is frame acurate, while DirectShowSource is generally not'..
Posted: Nov 2 2009, 05:19 AM
That's probably the case, but it also depends on the decoder in use. Some decoders are considerably more wishy-washy about giving you the frame you asked for than others; the WMV decoders used to be really bad at this.
291 replies since Jan 10 2008, 05:09 AM Track this topic | Email this topic | Print this topic
