| hINDUs |
Posted: Jan 6 2009, 10:07 PM |
havent found a dedicated thread for a quicktime input plugin so here's a bug (?) report: the plugin works well with almost all my .mov files, but not all
 left shot is from quicktime.ini / mode=-1, right from mode=0 i want to set-it-and-forget-it to mode=-1 (auto) but i cant :/ also in mode=0 there is no keyframes
EDiT: bugger, the pic is not scaling automatically... |
| Placio74 |
| Posted: Jan 6 2009, 11:25 PM |
VideoAudio
I have seen it already with some files from cam's.
What's installed QuickTime version?
Can play correctly in QuickTime Player?
Maybe upload some sample file, example on ifile.it or depositfiles.com?
BTW There is no need to edit quicktime.ini file. Can call the configuration window when opening a video clip - Ask for extended options after this dialog option.
| hINDUs |
| Posted: Jan 7 2009, 04:17 PM |
the QuickTime version was 7.0.3, video plays normal in QT
now i updated to latest 7.5.5 and with mode=-1 (3) VDub is crashing on open setting by hand mode=1 puts an error window (which is normal) setting by hand mode=2 opens ok, but crash in movie setting by hand mode=3 opens as in picture, no crash setting by hand mode=4 crash VDub
the video is a proud 112MB long, i can put a first 10MB cutted from orginal, what behaves the same as orginal video i'm also looking from where im downloaded it, but it's not a easy task :>
video sample: http://rapidshare.com/files/180738762/Chap...--first10mb.mov
crash: An out-of-bounds memory access (access violation) occurred in module 'Quicktime'... ...reading address 05628000. http://paste.org/index.php?id=4731
EDiT: ufff, i found the link to orginal videos: http://media.panavision.com/ScreeningRoom/...ying_Part5.html
have fun! (btw - those videos are highly informative and i can only recommend you to watch it) |
| Placio74 |
| Posted: Jan 7 2009, 06:09 PM |
VideoAudio
Odd video resolution... it's problem. 853x480
Also, it's problematic not only in VirtualDub with QuickTime input plugin
[EDIT] No problems with 720p (1280x720) and 1080p (1920x1080) clips.
| tateu |
| Posted: Jan 7 2009, 09:14 PM |
| QUOTE (hINDUs @ Jan 6 2009, 03:07 PM) | havent found a dedicated thread for a quicktime input plugin so here's a bug (?) report: the plugin works well with almost all my .mov files, but not all  |
Yes, it's the odd size video...It's my fault that it skews the video and/or crashes...it has to do with the pitch of the video, which is usually width * BytesPerPixel. For Quicktime in RGB24, that means the buffer for one line of video is 853 * 3 = 2559 bytes. The AviSynth buffer probably gets rounded up to an even number, so when I copy and paste data from the Quicktime buffer to the AviSynth buffer it gets corrupted. I'm not sure when I will get around to fixing it...maybe this weekend or next? |
| Vito |
| Posted: Dec 15 2009, 01:27 PM |
| QUOTE (tateu @ Oct 12 2007, 03:09 AM) | And here's the first release for quicktime video (mov, some mp4, etc.):
binary http://www.tateu.net/software/dl.php?f=qtvd_bin
source code http://www.tateu.net/software/dl.php?f=qtvd_src
"Quicktime.vdplugin" should go in your plugins32 folder and "Quicktime.ini" should go in the VirtualDub root folder.
There are several different modes that can be used to open a movie, these are specified in Quicktime.ini as "mode=." Mode=-1 and color=-1 are the recommended defaults but you can read about the different modes in "Quicktime_ReadMe.txt." Eventually, these options will be implemented as an "Ask for Extended Options Dialog."
Audio is currently not implemented and I am sure there are many bugs. Questions, comments, suggestions, whatever...are welcome.
I will also most likely...someday...implement my avisynth OMF importer. |
When I open a video the screen turns green and when I hit play VD crashes.. Does anyone know what the problem could be??
I have windows 64bit
here the error: An out-of-bounds memory access (access violation) occurred in module 'Quicktime'... ...writing address 85B70000... ...while running thread "Dub-I/O" (thread.cpp:163). |
| Placio74 |
| Posted: Dec 15 2009, 02:53 PM |
VideoAudio
Vito, what is installed version of QuickTime and which is used video decoder mode (by plugin)? Also what are characteristics of source video?
| roseman |
| Posted: Dec 15 2009, 05:56 PM |
| QUOTE (Vito @ Dec 15 2009, 01:27 PM) | | QUOTE (tateu @ Oct 12 2007, 03:09 AM) | And here's the first release for quicktime video (mov, some mp4, etc.):
I used to get Green preview and output screens importing a Quicktime .MOV file (with h.264 codec) and the Quicktime plugin, IF i was using a 1.9.x version of VirtualDub.
VirtualDub 1.8.8 was not affected by this particular bug that 1.9.x suffered from.
Have you tried 1.8.8 or earlier to see if you get the same result? This might narrow down where the problem is...? |
| Posted: Dec 16 2009, 04:09 AM |
Please post the full crash dump for the QuickTime crash. There is something curious with the reported error -- that address is above where Windows should be allowing memory allocations (>2GB). |
| Vito |
| Posted: Dec 16 2009, 04:38 AM |
| QUOTE (Placio74 @ Dec 15 2009, 02:53 PM) | | Vito, what is installed version of QuickTime and which is used video decoder mode (by plugin)? Also what are characteristics of source video? | it is video which comes from my camera! It saves in h.264 |
| Vito |
| Posted: Dec 16 2009, 04:42 AM |
| QUOTE (phaeron @ Dec 16 2009, 04:09 AM) | | Please post the full crash dump for the QuickTime crash. There is something curious with the reported error -- that address is above where Windows should be allowing memory allocations (>2GB). |
VirtualDub crash report -- build 32661 (release) --------------------------------------
Disassembly: 100115c0: 01e8 add eax, ebp 100115c2: ad lodsd 100115c3: 37 aaa 100115c4: 0000 add [eax], al 100115c6: 8bf0 mov esi, eax 100115c8: 85f6 test esi, esi 100115ca: 59 pop ecx 100115cb: 59 pop ecx 100115cc: 7434 jz 10011602 100115ce: 56 push esi 100115cf: ff3580170210 push dword ptr [10021780] 100115d5: ff35a42c0210 push dword ptr [10022ca4] 100115db: e8eafaffff call 100110ca 100115e0: 59 pop ecx 100115e1: ffd0 call eax 100115e3: 85c0 test eax, eax 100115e5: 741b jz 10011602 100115e7: 6a00 push 00h 100115e9: 56 push esi 100115ea: e8c1fbffff call 100111b0 100115ef: 59 pop ecx 100115f0: 59 pop ecx 100115f1: ff15a4c00110 call dword ptr [1001c0a4] 100115f7: 834e04ff or dword ptr [esi+04h], 0ffh 100115fb: 8906 mov [esi], eax 100115fd: 33c0 xor eax, eax 100115ff: 40 inc eax 10011600: eb07 jmp 10011609 10011602: e86cfbffff call 10011173 10011607: 33c0 xor eax, eax 10011609: 5e pop esi 1001160a: 5f pop edi 1001160b: c3 ret 1001160c: 8b442404 mov eax, [esp+04h] 10011610: a3b42c0210 mov [10022cb4], eax 10011615: c3 ret 10011616: 55 push ebp 10011617: 8bec mov ebp, esp 10011619: 83ec08 sub esp, 08h 1001161c: 897dfc mov [ebp-04h], edi 1001161f: 8975f8 mov [ebp-08h], esi 10011622: 8b750c mov esi, [ebp+0ch] 10011625: 8b7d08 mov edi, [ebp+08h] 10011628: 8b4d10 mov ecx, [ebp+10h] 1001162b: c1e907 shr ecx, 07h 1001162e: eb06 jmp 10011636 10011630: 8d9b00000000 lea ebx, [ebx+00] 10011636: 660f6f06 movdqa xmm0, [esi] 1001163a: 660f6f4e10 movdqa xmm1, [esi+10h] 1001163f: 660f6f5620 movdqa xmm2, [esi+20h] 10011644: 660f6f5e30 movdqa xmm3, [esi+30h] 10011649: 660f7f07 movdqa [edi], xmm0 <-- FAULT 1001164d: 660f7f4f10 movdqa [edi+10h], xmm1 10011652: 660f7f5720 movdqa [edi+20h], xmm2 10011657: 660f7f5f30 movdqa [edi+30h], xmm3 1001165c: 660f6f6640 movdqa xmm4, [esi+40h] 10011661: 660f6f6e50 movdqa xmm5, [esi+50h] 10011666: 660f6f7660 movdqa xmm6, [esi+60h] 1001166b: 660f6f7e70 movdqa xmm7, [esi+70h] 10011670: 660f7f6740 movdqa [edi+40h], xmm4 10011675: 660f7f6f50 movdqa [edi+50h], xmm5 1001167a: 660f7f7760 movdqa [edi+60h], xmm6 1001167f: 660f7f7f70 movdqa [edi+70h], xmm7 10011684: 8db680000000 lea esi, [esi+80] 1001168a: 8dbf80000000 lea edi, [edi+80] 10011690: 49 dec ecx 10011691: 75a3 jnz 10011636 10011693: 8b75f8 mov esi, [ebp-08h] 10011696: 8b7dfc mov edi, [ebp-04h] 10011699: 8be5 mov esp, ebp 1001169b: 5d pop ebp 1001169c: c3 ret 1001169d: 55 push ebp 1001169e: 8bec mov ebp, esp 100116a0: 83ec1c sub esp, 1ch 100116a3: 897df4 mov [ebp-0ch], edi 100116a6: 8975f8 mov [ebp-08h], esi 100116a9: 895dfc mov [ebp-04h], ebx 100116ac: 8b5d0c mov ebx, [ebp+0ch] 100116af: 8bc3 mov eax, ebx 100116b1: 99 cdq 100116b2: 8bc8 mov ecx, eax 100116b4: 8b4508 mov eax, [ebp+08h] 100116b7: 33ca xor ecx, edx 100116b9: 2bca sub ecx, edx 100116bb: 83e10f and ecx, 0fh 100116be: 33ca xor ecx, edx
Built on Aegis on Sun Oct 18 12:54:39 2009 using compiler version 1400
Windows 5.2 (Windows XP x64 build 3790) [Service Pack 2]
EAX = 86ce0000 EBX = 04cf0f20 ECX = 0000001e EDX = 00000000 EBP = 0682fca0 ESI = 04cf0f20 EDI = 86ce0000 ESP = 0682fc98 EIP = 10011649 EFLAGS = 00010206 FPUCW = 027f FPUTW = ffff
Crash context: An out-of-bounds memory access (access violation) occurred in module 'Quicktime'...
...writing address 86CE0000...
Pointer dumps:
EBX 04cf0f20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ESI 04cf0f20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ESP 0682fc98: 00000f00 00000000 0682fcd0 100116ef 86ce0000 04cf0f20 00000f00 050f0020 0682fcb8: 00000000 04cf0020 04cf0f20 00000001 02de4158 80000000 86ce0000 1000903b 0682fcd8: 86ce0000 04cf0f20 00000f00 00000000 02de4158 00000000 00000000 04cf0020 0682fcf8: 00000000 00000000 00000000 000003e9 00000000 00000001 00000001 100065ff EBP 0682fca0: 0682fcd0 100116ef 86ce0000 04cf0f20 00000f00 050f0020 00000000 04cf0020 0682fcc0: 04cf0f20 00000001 02de4158 80000000 86ce0000 1000903b 86ce0000 04cf0f20 0682fce0: 00000f00 00000000 02de4158 00000000 00000000 04cf0020 00000000 00000000 0682fd00: 00000000 000003e9 00000000 00000001 00000001 100065ff 00000000 00000000
Thread call stack: 10011649: Quicktime!VDGetPluginInfo [10000000+22a0+f3a9] 100116ef: Quicktime!VDGetPluginInfo [10000000+22a0+f44f] 1000903b: Quicktime!VDGetPluginInfo [10000000+22a0+6d9b] 100065ff: Quicktime!VDGetPluginInfo [10000000+22a0+435f] 10002b57: Quicktime!VDGetPluginInfo [10000000+22a0+8b7] 004d2cb1: VDVideoSourcePlugin::_read() 004c77a5: DubSource::read() 0041cdb3: VDDubIOThread::ReadRawVideoFrame() 0051c27c: VDPostCheckExternalCodeCall() 0041d05e: VDDubIOThread::MainAddVideoFrame() 0041d816: VDDubIOThread::ThreadRun() 0051866f: VDThread::StaticThreadStart() 005b75ee: _callthreadstartex() 005b7693: _threadstartex@4() 7d4dfe21: kernel32!FlsSetValue [7d4c0000+1fceb+136]
-- End of report |
| Vito |
| Posted: Dec 16 2009, 04:44 AM |
| QUOTE (roseman @ Dec 15 2009, 05:56 PM) | | QUOTE (Vito @ Dec 15 2009, 01:27 PM) | | QUOTE (tateu @ Oct 12 2007, 03:09 AM) | And here's the first release for quicktime video (mov, some mp4, etc.):
There are several different modes that can be used to open a movie, these are specified in Quicktime.ini as "mode=."� Mode=-1 and color=-1 are the recommended defaults but you can read about the different modes in "Quicktime_ReadMe.txt."� Eventually, these options will be implemented as an "Ask for Extended Options Dialog."
Audio is currently not implemented and I am sure there are many bugs.� Questions, comments, suggestions, whatever...are welcome.
Have you tried 1.8.8 or earlier to see if you get the same result? This might narrow down where the problem is...? | hm..didnt work...but if I change to RGB 24..the screen becomes black instead of green. Also when I hit the left play button at the bottom it crashes. when I hit the second one it plays but only sound. |
