| TechMage89 |
| Posted: Mar 10 2005, 11:01 PM |
Contemporary Anachronism
Slow hard drive? I dont think 5,400 RPM would cut it. What's your hard drive's speed?
-------------------- I'm not insane, everyone else is! |
| i4004 |
| Posted: Mar 10 2005, 11:53 PM |
you mean ata100 on 5400 or ata33 on 5400? i think both would do, btw.
for example, let's say ata33 drive can sustain 10MB/s (and it probably can). that probably enough for 640x480huff.....but then again, what huff if he has a cap. device with hardware codec on it; http://www.plextor.com/english/products/Co...ertX-AV100U.htm
also; http://www.plextor.com/english/products/Co...cedtechspec.htm
this model has mpeg1/2 capping only, so vdub should not be used as a cap utility at all, as vdub can't write mpegs.
capuser should of told us hardware specs at the beginning.
#################################################### edit; oups; there's more data there; http://www.plextor.com/english/products/Co...onvertXComp.htm
this model actually has no compressor on the chip! compression is done by pc's cpu.
btw. capuser did you tell us what video compression u use? you said this;
| QUOTE | | I've gotten rid of them before by re-encoding (while I record) with huffyuv, but this time they dont seem to go away. |
how about using huff _always_? or even better, using mjpeg as a compressor (if you don't have space for huff, and nobody really does... )
| capuser |
| Posted: Mar 11 2005, 04:18 AM |
| QUOTE (i4004 @ Mar 10 2005, 11:53 PM) | you mean ata100 on 5400 or ata33 on 5400? i think both would do, btw.
how about using huff _always_? or even better, using mjpeg as a compressor (if you don't have space for huff, and nobody really does... ) | yeah i mentioned earlier that it does zero work, its all pc labor, no compression, which i know is half the problem
and ive heard negatives about mjpg before, so ive kinda stayed away from it.....i'll give it a whirl
my main concern is quality, which is counter-attacked by resolution, hense my problem, but i got plenty of hdd space to play with, and i NORMALLY do re-encode with huffy from YUY2........is it possible to avoid yuy2 and go straight to huffy/mjpg?
p.s. im workin with a maxtor 250gb 7200 |
| i4004 |
| Posted: Mar 11 2005, 04:24 AM |
| QUOTE | | is it possible to avoid yuy2 and go straight to huffy/mjpg? |
| capuser |
| Posted: Mar 11 2005, 05:02 AM |
| QUOTE (i4004 @ Mar 11 2005, 04:24 AM) | | QUOTE | | is it possible to avoid yuy2 and go straight to huffy/mjpg? |
| i4004 |
| Posted: Mar 11 2005, 05:35 PM |
| QUOTE | |
now be carefull, or you'll get;
<smile>
| capuser |
| Posted: Mar 11 2005, 09:58 PM |
it wont let me capture through mjpg unsupported video format |
| i4004 |
| Posted: Mar 11 2005, 11:52 PM |
what's that mjpeg that doesn't support yuy2 input?
| capuser |
| Posted: Mar 12 2005, 09:33 AM |
| QUOTE (i4004 @ Mar 11 2005, 11:52 PM) | | what's that mjpeg that doesn't support yuy2 input? |
So youre saying use MJPEG as input or compression?
I only show MJPEG available for input, not compression. |
| i4004 |
| Posted: Mar 12 2005, 04:47 PM |
yuy2 is the colorspace, and mjpeg is compression; yuy2(your card)->mjpeg(your pc)
select yuy2 as colorspace (as you did so far) , and then go to 'compression' and select mjpeg there. offcourse, that presumes you have a vfw mjpeg codec installed.
| capuser |
| Posted: Mar 12 2005, 07:10 PM |
| QUOTE (i4004 @ Mar 12 2005, 04:47 PM) | yuy2 is the colorspace, and mjpeg is compression; yuy2(your card)->mjpeg(your pc)
select yuy2 as colorspace (as you did so far) , and then go to 'compression' and select mjpeg there. offcourse, that presumes you have a vfw mjpeg codec installed. | alright, well, its only listed under input, not compression, and i cant even use it as input, so, guess i need to install it |
| capuser |
| Posted: Mar 12 2005, 07:56 PM |
actually, check this out
i got 6 unencoded avi's that I recorded (about 2 gigs each). Each video file is perfectly in sync with its audio. So now, to combine them, I opened up Vdub. It automatically detected that the files were associated with each other, and appended them.
Ok, so I got 6 files loaded in vdub. I edited some video out, then direct streamed the video and audio, to make one big file. Finally, I check out the one big file, and the audio was out of sync.
I'm guessing I should append the videos and save it as one big file before doing ANY editing?
what would you suggest
(P.S. i read once that cutting video out from a non-keyframe can cause video to become out of sync, but every frame in the video IS a keyframe, so I ruled that out) |
| i4004 |
| Posted: Mar 12 2005, 10:55 PM |
| QUOTE | | Ok, so I got 6 files loaded in vdub. I edited some video out, then direct streamed the video and audio, to make one big file. Finally, I check out the one big file, and the audio was out of sync. |
this hapens to me too, but if i encode the avi that seems like it lost sync, it's not really offsync after encoding.
i assumed ms .avi parser is clumsy with opendml, or something like that. offset was really immense in dshow. but there was no offset if i loaded the file to vdub, and no offset if i encoded that 'suspicious' file.
if you're on ntfs, uncheck the 'enable multisegment capture' to start making the big .avi files. or at least try that. i know that's not an option for me, as i'm on fat32. offcourse, that also means that in event of some crash you'll have harder time recovering already capped stuff.
| Posted: Mar 12 2005, 11:18 PM |
Captures are basically guaranteed to not have video and audio streams of the exact same duration, so they will desync if you attempt to use append to join them (unaligned splice). You'll probably find the captures are out of sync if you play them in the editor immediately after loading as well. |
| i4004 |
| Posted: Mar 13 2005, 12:08 AM |
we were talking about auto-append of segmented files that vdub cap made.
not about manual appending of non-segmented files.
| QUOTE | | It automatically detected that the files were associated with each other, and appended them. |
as said, only desync i get (when i load first segment, and vub appends automatically others, and then i save that as one big file) is the dshow desync on playback for which i couldn't care less.
