| rmmcclay |
| Posted: Oct 19 2003, 04:26 AM |
How to Do Time Lapse with VirtualDub ------------------------------------------------ There are many ways to do this, but here's a simple recipe I use to create time-lapse movies:
1. Open the source AVI in VirtualDub. (Let's say an hour-long video of clouds moving real-time across the sky.)
2. Under Video => Frame Rate => Frame Rate Conversion, check Decimate and enter a value. Try 15 or 30 or 60 or 120 for example. Higher numbers = faster. Leave everything else default.
3. Set Video to Full Processing mode and select a compression codec (I use DivX 4).
4. Set Audio to No Audio.
5. Save the AVI under a new name.
6. Open this new file in VirtualDub.
7. Go to Video => Frame Rate => Source rate adjustment and check "Change to" and enter a value, for example, 29.970. Set "Frame Rate adjustment" to: Process All Frames.
8. Set Video to Direct Stream. (Do not re-encode.)
9. No Audio.
10. Save out under a new name.
Done.
-Russ |
| timtom |
| Posted: May 27 2011, 08:57 PM |
Following your steps I was able to do time lapse, thank you BUT as I have many heavy video files that I have to convert this way would there be a way to do the same in one step instead of two?
I tryed to decimate by 10 and adjust the source rate to 29.97 in one step but when I save it, the results does'nt inclued the 29.97 source rate. How could I do it in one step?
Tim |
