| raffriff42 |
| Posted: Sep 25 2013, 09:23 PM |
| QUOTE (Virtualnoob123 @ Sep 25 2013, 09:23 PM) | Ok, this seems to work just fine now:
| CODE | #avisynth ## speed change test: ## half speed from frame 0 to frame 29; ## 130% speed from frame 30 to frame 149 ## normal speed to end of video
V=AviSource ("D:\Movie Folder\Kharg Island\Scout vs stinger noob 45fps.avi")
return UUChangeSpeed(Trim(V, 0, 500), 1) \ + UUChangeSpeed(Trim(V, 501, 1000), 4) \ + Trim(V, 1000, 0)
function UUChangeSpeed(clip c, float factor) { oldRate = FrameRate(c) newVid = AssumeFPS(c, oldRate * factor) return AudioDub(ChangeFPS(newVid, c), c.TimeStretch(tempo=100*factor)) }
But for some reason instead of being 4 speed from 501-1000 frames it goes back to normal at around 600-650 frames. And stays normal speed to the end of the video. |
That's because frames were removed to speed up the video. |
| Virtualnoob123 |
| Posted: Sep 25 2013, 09:26 PM |
I added that piece of code to mine like this:
return Trim(V, 0, 500) \ + UUChangeSpeed(Trim(V, 501, 1000), 4) \ + Trim(V, 1001, 0)
And got the same resaults. Goes back to normal speed at around 600-650! |
| raffriff42 |
| Posted: Sep 25 2013, 09:33 PM |
OK this change to the code will show what's happening with the source frames. As mentioned in the comment, when done debugging, add a "#" in front of the "ShowFrameNumber" line to disable it | CODE | #avisynth
## debugging: show the original frame number from the source video ## (when done debugging, add a "#" in front of this line to disable it) V=V.ShowFrameNumber()
function UUChangeSpeed(clip c, float factor) { oldRate = FrameRate(c) newVid = AssumeFPS(c, oldRate * factor) return AudioDub(ChangeFPS(newVid, c), c.TimeStretch(tempo=100*factor)) } | |
| Virtualnoob123 |
| Posted: Sep 25 2013, 09:34 PM |
| QUOTE (raffriff42 @ Sep 25 2013, 09:23 PM) | | QUOTE (Virtualnoob123 @ Sep 25 2013, 09:23 PM) | Ok, this seems to work just fine now:
That's because frames were removed to speed up the video. | Well, how do I get the video to speed up from frame 501-1001 and not drop off 400 frames too early?! |
| raffriff42 |
| Posted: Sep 25 2013, 09:49 PM |
Just watch the video, it works I promise you. I guess I fail at explaining. |
| Virtualnoob123 |
| Posted: Sep 25 2013, 09:59 PM |
| QUOTE (raffriff42 @ Sep 25 2013, 09:49 PM) | | Just watch the video, it works I promise you. I guess I fail at explaining. | Yes, you have solved my problem and thanks.
It's just I want to stop the speeded up section on frame 1000, but it drops off at 650. Guess I just add 450 frames to the code.
| meowmeow |
| Posted: Sep 27 2013, 03:17 PM |
Thanks! Nice, nice code works with both video & audio only. And those frames which lost - they're lost while maintaining same FPS at shorter time. |
| malky |
| Posted: Sep 28 2013, 10:13 AM |
Great code.Much easier solution than mine.
http://forums.virtualdub.org/index.php?act...4&hl=virtualdub |
| raffriff42 |
| Posted: Sep 28 2013, 10:43 PM |
Thanks. I should really credit this post (I think it was this one) for the idea. |
