| -vdub- |
| Posted: Apr 12 2013, 05:48 PM |
You video sample here : http://www.mediafire.com/?dig1sovkd1p75o1
I changed the file extension to .ts as media info showed your mpg video as Format: MPEG-TS which contains video: AVC and Audio: mp2
MediaInfo
General ID : 1 Complete name : Drive:\ANT1_01_10_2012_01_30_54.ts Format : MPEG-TS File size : 6.28 MiB Duration : 12s 274ms Overall bit rate : 4 122 Kbps
Video ID : 1350 (0x546) Menu ID : 300 (0x12C) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Format settings, GOP : M=3, N=12 Duration : 12s 240ms Bit rate : 3 725 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Bits/(Pixel*Frame) : 0.359 Stream size : 5.43 MiB (87%) Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Transfer characteristics : BT.601-6 525, BT.601-6 625, BT.1358 525, BT.1358 625, BT.1700 NTSC, SMPTE 170M Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio ID : 1351 (0x547) Menu ID : 300 (0x12C) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Duration : 12s 288ms Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Video delay : -1s 244ms Stream size : 288 KiB (4%) Language : Greek
Text ID : 1352 (0x548) Menu ID : 300 (0x12C) Format : Teletext Language : Greek
I don't know ffdshow-tryout and could maybe be done with that, or should be capable of doing so.
If not download this http://code.google.com/p/ffinputdriver/downloads/list choose the ...-32.zip for x86 unpack it all to virtualdub/plugins32 folder
Run virtualdub load your video using Open Video File with the option FFMpeg Suported Files
If still not you need better splitters to load media files http://code.google.com/p/lavfilters/downloads/list
Try again load your video file with virtualdub as above |
| Abrazo |
| Posted: Apr 12 2013, 06:32 PM |
Hi psilos3,
Could it be due to the fact that Windows is not showing the file extensions (like *.AVI, *.MP4, *.MTS, ...) of your video-files ?
Via Windows Explorer > Folder Options-menu > View-tab > uncheck "Hide extensions for known file types" and
now verify what it gives in VirtualDub via DirectShow input driver...
ADDed:
I don't know if it also would make a difference if - in VirtualDub - you would go to the Options-menu > Plug-ins..., click on the DShowInputDriver.vdplugin and Configure... and there check "Match file extensions ...". After confirmation, restart VirtualDub and retry... |
| psilos3 |
| Posted: Apr 12 2013, 07:07 PM |
Hi Abrazo!!!!! The Match file extensions was already checked, but i tried your 1st advice and even if the file was not displayed, as at windows xp, when i press open it worked!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Thank you so much my friend!!!!! 2 months i 'm bothering with it and i couldn't find a solution, i was looking at vdub but the solution was at windows options!!!! I 'M SO GRATEFUL!!!!! Thousands of thanks!!!!!!!!! You rock!!!!!!!!!!!! P.s : -vdub- thank you also for your effort! |
| Abrazo |
| Posted: Apr 12 2013, 07:29 PM |
Sometimes finding the cause of a problem is not always evident.
I'm glad for you that it has been solved. |
| psilos3 |
| Posted: Apr 12 2013, 07:58 PM |
| QUOTE (Abrazo @ Apr 12 2013, 07:29 PM) | Sometimes finding the cause of a problem is not always evident.
I'm glad for you that it has been solved. | Thank you again! I 'm using it right now. Finally!!! And because of your help!!! I owe you big time! |
| -vdub- |
| Posted: Apr 13 2013, 01:35 AM |
Microsoft super nanny modes. Have always preferred to see all file extensions and set to do so when after installing windows os. All software's should work the same whether file extensions are shown or not shown. I didn't tested with virtualdub no other software could be virtualdub or microsoft lazy development team a bug with all microsoft os !
Tried and it messed up with virtualdub I did see the same error you had. Though also messed around with DirectX 3D (without DirectX the same) when used with video decode filter. Where would see two tiny windows top left of virtualdub. After restoring the file extensions to show again the same problem remained !
I shut down and restarted again virtualdub (a few times with testing this) loaded another video file (mp4) only then virtualdub restored to normal operation. After I did a restore using system restore to an earlier to be sure.
Something wrong with the video or just the way windows os is ? |
