| hilfer |
| Posted: Feb 20 2007, 07:23 PM |
Hi everybody:
I've introduced a friend to the endless utilities of VD.
However he's having a problem that I cannot reproduce in my machine.
When he's trying to transcode an avi file with some audio problems, he's doing : Video : direct stream copy Audio : full processing mode
He gets an error message saying; "no audio decompressor could be found to decompress the source audio format (source format tag 2000)
What can he do to make it work ?? I can easily do that in my machine using the same file!!
What is he missing ??
Tks for any suggestion.
hilfer.
| Gral |
| Posted: Feb 20 2007, 08:11 PM |
Download this codec - http://fcchandler.home.comcast.net/AC3ACM/index.html unzip all files to any directory, right click on INF file and select "Install" |
| hilfer |
| Posted: Feb 21 2007, 10:24 AM |
Tks.
Will inform my friend and will let you know the result.
hilfer |
| mecnicman |
| Posted: Mar 23 2007, 04:35 PM |
Hi, I am having the same problem but with source format tag 0055. I downloaded and installed the mpeg codec this relates to, and gspot says its is installed, but I still get the same problem. Any suggestions or help would be appreciated! |
| mecnicman |
| Posted: Mar 23 2007, 06:30 PM |
After Reading more posts both here and on doom9, and installing a lot of codecs, I discovered a post about using AVI-MUX GUI first, then processing with virtual dub and it works for anyone with the same problem. |
| mimini |
| Posted: Jan 9 2008, 11:28 PM |
| QUOTE (mecnicman @ Mar 23 2007, 06:30 PM) | | After Reading more posts both here and on doom9, and installing a lot of codecs, I discovered a post about using AVI-MUX GUI first, then processing with virtual dub and it works for anyone with the same problem. | Doesnt work for me -sigh- |
