| lipe123 |
| Posted: Feb 25 2005, 01:11 PM |
Hi all
I've got myself a AMD 64 pc to check it out a bit, and i got the XP64 beta installed etc..
So I downloaded VirtualDub 64 ed. and lo and behold just as I was going to be amazed at the new superfast encoding times - i couldnt open any files because I dont have codecs.
I usually use the Ace Mega codec pack, and I did install that. But vdub still sais it shorts the codec's needed to open the file. Do I need a special set of codecs for 64bit windows? where can I get it?
Thnx for any help. Cecil. |
| stephanV |
| Posted: Feb 25 2005, 03:18 PM |
yes, you need 64-bit codecs
uhm, unfortunately the only one i know of which a 64-bit version exists is XviD...
this thread might be a good read for you though
