| Andrew03 |
| Posted: Apr 29 2010, 03:53 PM |
I installed Virtualdub 1.9.9. version and ffdshow. ffdshow was set how the picture shows. I wanted to open wmv file while constructing ASF index block and I got this message:
VirtualDub Error
ASF: Unhandled Replicated_Data_Length 0 in packet at 104856909 |
| Oxyandy |
| Posted: Apr 29 2010, 05:09 PM |
that sounds like corruption in the file.. I assume is downloaded from the net... other files open ok ? |
| Andrew03 |
| Posted: Apr 29 2010, 05:28 PM |
I converted other wmv file and I played converted avi file in BSplayer but video isn't good. There isn't video, there is only audio. |
| Oxyandy |
| Posted: Apr 29 2010, 05:40 PM |
Well, what codec were you using to save video as ? I suggest Xvid (default settings) How did original file play ?
With the corrupt file... You could try Windows Movie Maker, choose import video, then drag to timeline, then finish movie, save to my computer, choose save location, show more choices, other settings, save as DV-AVI
then these saved files are openable in VirtualDub for further editing..
If you do not already have Windows Movie Maker, Windows Movie Maker 2.1 (XP) http://www.brothersoft.com/windows-movie-m...load-76169.html
Windows Movie Maker 2.6 (VISTA +) http://www.brothersoft.com/windows-movie-m...load-67210.html |
| Andrew03 |
| Posted: Apr 29 2010, 06:40 PM |
I use mega code pack but i also tried xvid codec. There isn't still video, just audio. |
| Oxyandy |
| Posted: Apr 30 2010, 07:52 AM |
Can you provide a bit more detail, please.. It seems now you are able to open wmv files fine.. What happens next ? Do they play ok in VirtualDub ?
