Error Can Not Determine File Type
gondorf
Posted: Nov 21 2008, 03:24 AM
Using VirtualDub 1.7.7
I have a file that the VirtualDub can not determine what the file type is.
I used GSpot an found it was a
Video codec: mp4v Name : MPEG-4 video
Staus:Codec Status Undetermined
Audio codec: mp4a: MPEG-4 AAC LC
Info: 44100Hz , stereo (2/0)
Can VitualDub work with these type of files?
If so what am I missing?
Or is the file some how corrupt?
The file plays ok using Classic Media Player.
Placio74
Posted: Nov 21 2008, 06:02 AM
VideoAudio
QUOTE (gondorf @ Nov 21 2008, 05:24 AM)
Can open this file used QuickTime import plugin.
(Required installed QuickTime or QuickTime Alternative.)
Not related.
Media Player Classic use DirectShow filters - VirtualDub not (except - DirectShow input plugin).
BTW
Whay not use latest VirtualDub version?
gondorf
Posted: Nov 21 2008, 01:19 PM
Ok, I got the latest version of VirtualDub and the suggested plugin and placed them in the plugin32 folder.
This time it is telling me that the file is unknown or unsupported file type.
Any other suggestions?
Thanks for the reply.
Placio74
Posted: Nov 21 2008, 02:35 PM
VideoAudio
Which plugin?
If DirectShow input plugin...
...when open, select video file and change file type to DirectShow input driver.
If QuickTime input plugin...
...Quicktime.vdplugin file is in plugins32 subfolder?
BTW
VirtualDub Plugin Pack - input plugins with installer.
gondorf
Posted: Nov 21 2008, 04:42 PM
QUOTE (Placio74 @ Nov 21 2008, 02:35 PM)
Which plugin?
BTW
I do not understand what you mean by the DirectShow pluging?
I can not get VirtualDub to even open the the video.
Here is what I am doing.
Start VirtualDub.
Select Open file
Select video
Hit ok
This is when the error about Unkown or Unsupported file popup's up. So you see I can not even open or loaded the video.
Yes, the QuickTime plugin is in the plugin32 folder and the inf file is in the main VirtualDub folder.
About the DShowInputDriver.vdplugin , I have tried it both the plugin32 and plugin folder both yielded the same results, the unknown file or unsupported file type.
One point here is I have nor run the other program auxsetup.exe . Do I need to run this program?
chornobyl
Posted: Nov 21 2008, 05:36 PM
Start VirtualDub
Select File>Open
Select video
Select type>DirectShow input
Hit ok
Placio74
Posted: Nov 21 2008, 05:56 PM
VideoAudio
Watch this video: http://ifile.it/7dewuo5
QUOTE (gondorf @ Nov 21 2008, 06:42 PM)
Not related. It's for VirdualDub frameserving.
BTW
Unfortunately, when i try...
MOV or MP4 with MP4V > Gabest MP4 Splitter + ffdshow > DirectShow input driver = "File ... does not have a video stream."
Also of course, can use Avisynth script (DirectShowSource or QTSource).
gondorf
Posted: Nov 22 2008, 12:36 AM
Ok , I followed you instruction and the file was open, using the direct plug-in.
Thanks
In the past when I used the program I never had problem opening a video.
I tried using the
Video: Direct copy
But it said "The source use a algorithm that is not compatible with AVI files. Direct stream copy can not be use"
Is there a way that I can keep from re compressing the video and losing more quality.
Thanks for you patience with me.
Placio74
Posted: Nov 22 2008, 04:48 PM
VideoAudio
Direct stream copy audio/video from MOV/MP4 to AVI in VirtualDub?
At this moment - can't.
Try MPEG Streamclip (it use QT) or Avidemux.
(Save to MOV or MP4 container.
To AVI - possible, but only for some A/V.)
dub&duber
Posted: Feb 19 2011, 02:10 PM
QUOTE (Placio74 @ Nov 22 2008, 04:48 PM)
Does it still apply to the latest version ? I tried to open a .mp4 file and the following error message was displayed :
The file […] is of an unknown or unsupported file type.
According to VLC media player the video track is "H.264 / MPEG-4 Part 10, AVC (Advanced Video Coding)" encoded. Installing ffdshow tryouts Beta 7 didn't solve the problem. I just would like to extract a sequence from the video.
Placio74
Posted: Feb 21 2011, 09:13 AM
VideoAudio
QUOTE (dub&duber @ Feb 19 2011, 04:10 PM)
Does it still apply to the latest version ? ...
Yes - Direct Stream Copy mode was planned in QuickTime import plugin, but it seems that plugin is no longer being developed (last version from october 2007).
However, You can change container to MKV (using MKVtoolnix) and then can try fccHandler's Matroska plugin (where Direct Stream Copy is possible).
...I tried to open a .mp4 file and the following error message was displayed :
Using QuickTime plugin (with installed QuickTime) or DirectShow plugin (with installed required DirectShow filters - splitter and decoders)?
dub&duber
Posted: Feb 21 2011, 02:57 PM
QUOTE (Placio74 @ Feb 21 2011, 09:13 AM)
However, You can change container to MKV (using MKVtoolnix) and then can try fccHandler's Matroska plugin (where Direct Stream Copy is possible). […] Using […] DirectShow plugin (with installed required DirectShow filters - splitter and decoders)?
Thanks ! I used MKVToolnix to convert my .mp4 file to a Matroska one. Then I was able to open it and save the part I was interesting in. However I had to disable the audio because the track is "MPEG AAC Audio (mp4a)" encoded and apparently ffdshow tryouts doesn't properly support it. Maybe I needed a special plugin or something. But it doesn't matter as I was interested by the video in priority.
Note that I found the VirtualDub Now Has a Directshow Driver Plugin thread (VideoHelp.com Forum) very useful during my search. It convinced me to install Haali Media Splitter and ffdshow from x264.nl, because of the splitter & decoders you mentioned, but apparently I didn't have to.
To sum things all I needed was MKVToolnix, the Matroska plugin and ffdshow tryouts.
ale5000
Posted: Feb 21 2011, 03:29 PM
QUOTE (dub&duber @ Feb 21 2011, 02:57 PM)
Do you have the version 2.3 of the Matroska input plugin? (if not, update it)
ffdshow tryouts support it.
If the audio doesn't work, try this:
Go on File => Open video file... => Select the video => Check "Ask for extended options after this dialog" => Click "Open" => Check "Direct Stream Copy raw AAC (no ADTS headers)" => OK
New VirtualDub forum
Placio74
Posted: Feb 21 2011, 04:29 PM
VideoAudio
Or...
Save video and audio separately - video without audio track and audio through export to 'raw audio' - and mux A/V using AVI-Mux GUI (AVI or MKV) or MKVtoolnix (MKV).
Also of course can de-mux audio to raw/binary and mux again with video using AVI-Mux GUI.
Works for me - after that audio is playable.
BTW
I checked several files and indeed I noticed a same issue - when edit (and saving in Direct stream copy mode) some MKV files created previously from MP4 (re-muxed MP4>MKV).
ale5000
Posted: Feb 21 2011, 09:03 PM
@Placio74: Have you tried my method?
17 replies since Nov 21 2008, 03:24 AM Track this topic | Email this topic | Print this topic
Pages: (2) [1] 2
