| sidebar99 |
| Posted: Feb 14 2003, 02:56 AM |
JCSSTON can I get some help. I uninstalled my perfectly working MPEG2VD to reinstall it using the full174 version package.
Now I am getting this error........ Avisynth open failure Load Plugin:...........MPEG2Dec3.dll is not an Avisynth 1.0 plugin
Can you tell me what I have done wrong or forgot to do? Sigh!!
Nevermind, I installed Avisynth beta and it's cool now!
| BaronVlad |
| Posted: Feb 14 2003, 03:15 PM |
Terrorhörnchen
Hi again,
thanks for your wishes...
My mainboard has gone to hell, I will send it to Epox, I have a warranty of two years for it. Think that I need one or two weeks to get it to work. When done I will test mpeg2toVD (I have 4 movies on HD)
Bye
| BaronVlad |
| Posted: Feb 15 2003, 07:52 PM |
Terrorhörnchen
Hi Jory,
just got Sills machine and made two captures with your program. It is great, no bugs so far (and no virus ) Field Deinterlacing also work, all the resize filters as well... The tabs are pretty cool, and the website is updated with screenies and a how to , but the most important thing: About-Section: My real name
One thing that came into my mind: The new XVid Build of koepi for example requires output resolution diviable by 8, but Divx only by 2, Avisynth by 4...what about an option to set the W and H Modul as you like (like in GKnot) ? That is not necessary but would be a good "gimmick"
And maybe you should include decomb.dll and cpvas.exe in your installer. Dont know whether it is ok for Donald Graft and Wiljo Heinen ? It is great to see what you developed jory. Thank you very much for your hard work
EDIT: made 4 movies so far, no problem !!! When the movies are ready encoded, I will try to make a divx out of a SVCD, we will see, what your proggi does...
| BaronVlad |
| Posted: Feb 16 2003, 11:39 PM |
Terrorhörnchen
Hi again,
sorry for answering the third time
Just tried to make a divx from an SVCD. Problem was the resolution:
PAL SVCD is 480 * 576 (5:6). it is shown as 4:3 on the TV / Monitor. If you crop and then resize the normal way you get coneheads. You will get the right aspect ratio with 480 * 360 (4:3), but what to do with the cropping values ?
Solution: Crop as you like (i.g. 74 top and 76 bottom), then compare input resolution (576) and the cropped resolution (here it is 426). You will get 426/576 -> you cropped 26 % of the height -> 74 % of the height are left. Calculation with the "desired" height of 360 will result in ~266 (360*0.74)
It is not necessessary to think about the left and right cropping values cause normally they are the overscan values (i.g. 2 on the left and 2 on the right) You wont see on TV, so after the whole cropping procedure your right output resolution will be in this case 476*266. You now could calculate the aspect ratio (476/266 = 1.789) and resize using this value (i.g. into 358*200)
Would be a great addon for your proggie to add such a "SVCD resolution" button in the resize tab.
Thanks for listening to me and sorry for bugging you with new wishes every day
You see, I am obstrusive also without my own PC
| jcsston |
| Posted: Feb 22 2003, 09:13 AM |
Matroska Dev
My head still spinning from the previous PAL aspect ratio thing
I've included decomb.dll and cPVAS in the package with permission. I re-did the locations tab, hope you like the new icons I've also added FluxSmooth
Now I have two sites or mirrors Tripod GeoCities My Tripod account is almost out of bandwidth (900MB of 1GB month) and now with the bigger packages it's sure to go over
Anyways I hope you get your motherboard soon
| BaronVlad |
| Posted: Feb 24 2003, 02:20 PM |
Terrorhörnchen
Hi Jory,
it is great, I love the new design and it is very good to "distribute" the different versions ! Of course I got the full package...
My Motherboard is back, thanks Epox, I processed a small testfile - works. I wanted to record a film yesterday but somehowmy recording software didnt want to. So i have to wait for the next good movie in German television....
BTW: Dont let your head smoke....as I said this would be a nice addon, but we all can live without it, cause we all have a calculator and can do it the hard way
Thanks.
| jcsston |
| Posted: Feb 27 2003, 09:34 PM |
Matroska Dev
What if I simply put a list box that lets you choose and add different Aspect Ratios? It would seem easier than adding different buttons for each type of input. Also can I ask, How useful would a translation be for the buttons? or is that not really needed.
I've noticed you've been promoting this program on English Doom9
| BaronVlad |
| Posted: Feb 28 2003, 12:22 PM |
Terrorhörnchen
Hi Jory,
| QUOTE | | What if I simply put a list box that lets you choose and add different Aspect Ratios? It would seem easier than adding different buttons for each type of input. |
Sounds great, but should it work like the calculation that I mentioned above ? Then it would be the best that we could get
| QUOTE | Also can I ask, How useful would a translation be for the buttons? or is that not really needed.
It is not necessesary needed, but would be useful as I know many readers of the German board that dont understand so much English. They always ask me for a German VirtualDub... If you tell me how to do this I would translate the buttons into "German" buttons.
EDIT: I looked at the program again, think it is not useful to translate the buttons, cause most of the expressions are English anyway (How Should I translate cropping or resize - doesnt make much sense I think). SO IMO it will be the best, when I do a translation of your howto, everybody is able to use it then...
| QUOTE | I've noticed you've been promoting this program on English Doom9  |
Sure, it is a very important proggie for editing videos and digital caps, so it has to be a sticky there, no matter whether cofferscuffs thinks it is very helpful or not I think so, and many other readers do.
| BaronVlad |
| Posted: Apr 14 2003, 08:22 AM |
Terrorhörnchen
Just wanted to say a big thankyou to Jory again, I made some movies captured from DVB-T these days with this proggie - works perfect and simple as it should...
Great Job !
| ChristianHJW |
| Posted: Apr 16 2003, 12:24 AM |
I am sorry, its probably because Jory is a core team member of the matroska dev team that his excellent program is not developed any further ... sorry for that guys ...
| jcsston |
Posted: Apr 16 2003, 01:48 AM |
Matroska Dev
I've be doing MJPEG captures with VirtualDub for about 4 months now. and simply haven't worked on Mpeg-2 to VirtualDub any.
I had started Mpeg-2 to VirtualDub because I couldn't find an program that would make it easy to import MPEG-2 into VirtualDub. Now I've found DVX and some others that seem to the job almost as well.
| BaronVlad |
| Posted: Apr 28 2003, 03:34 PM |
Terrorhörnchen
I had some weird problems with MPEG22VirtualDub:
When I have 2 MPEG2 Source Files, everything is fine, but when I have more, i.g. 3 or 4, there is no sound in VDub. The mpa file is ok, it is as long as the movie is and it has sound, the Avisynth script is fine also, but I get no sound with VDub. After cutting out the commercials I want to save the wav. It takes only one second and the file contains no sound.
I have to do a very complicated way to fix this.
I had the same problems with one 4 GB file and a second file (normally the files are 2 Gig). i know that pvastrumento cannot handle files > 4 GB, may this be the problem ?
Any clue ?
Thanks, if you have the time Jory.
EDIT:
Oops, seems to be a bug in the old version of mpasource related to avisynth 2.0x, I will get the update and look whether this bug is gone...
I will try and tell you about the results. Maybe you should replace the mpasource for 2.5 in your installer then ?
More details can be found here:
http://forum.doom9.org/showthread.php?s=&t...ce&pagenumber=3
| Buckles |
| Posted: Jun 11 2003, 04:50 PM |
arrghh, i'm getting really frustrated:( I cant get the damned MPEG2toVirtualDub App to load. I keep getting an error message regarding COMCTL32.OCX . After much re-installing and messing with vb runtime files etc, it now seems to recognise i have COMCTL32.OCX installed but gives me this message:
'Failed to load 'ListView' from CMPCTL32.OCX. Your version of COMCTL32.OCX may be outdated. Make sure you are using the version of the control that was provided with your application.'
Any ideas?
Sorry if this or a similar question has been asked before, i have to confess i havent read all the posts. Any help would be great:)
Thanks in advance
Buckles. |
| jcsston |
| Posted: Jul 7 2004, 10:07 PM |
Matroska Dev
I've moved the site to http://jorydownloader.sourceforge.net/vb/index.htm Tripod has been getting tighter and tighter on bandwidth limit, they are now down to less than 1.5MB per hour. Which results in only 2 full package downloads every 3 hours (they block it for 2 hours when the bandwidth limit is reached). I cannot login to change the website when the account is blocked, so it will be a while before I can take it off the Tripod account and add a redirect page.
Please note I haven't done any updating to the program, just uploaded a copy of the website.
