Pages: (3) 1 [2] 3  ( Go to first unread post )
Audio Only And No Video After Encoding, Encoding Issues
Posted: Sep 16 2013, 03:30 AM
I'd try installing that (latest version from) https://sourceforge.net/projects/ffdshow-tr...neric%20builds/
After installing you'll have the ffdshow VFW configuration entry in your start menu
Then try the steps above
(It's a good 'decode lots of stuff' decoder)
Posted: Sep 16 2013, 05:06 PM
Maybe it is not so intelligent to ask for it, but given the fact that you do not talk about warnings or error messages, and also the fact that the File information dialogbox is showing you that the fraps decompressor is being used, ... the following question:
In VirtualDub's "View" menu, are the "Input video pane" and the "Output video pane" being checked, I mean is there a little "V" before their entries in the menu ?
If not, you will not get a preview at all, even if the right decompressor is installed.
Regards.
HatMaster
Posted: Sep 17 2013, 08:02 PM
QUOTE (Abrazo @ Sep 16 2013, 05:06 PM)
Regards.
Ok, so it turned out that I didn't have the 'Output video pane' option checked off in the View menu. I turned that on and I'm now getting an image in the navigation.
However, I notice that when I press the preview button right next to the stop button, it's only showing a non-moving image with perfectly fine audio. That's not supposed to happen because I've seen how the preview button correctly works on VirtualDub tutorials I've seen on Youtube.
Posted: Sep 17 2013, 08:56 PM
I don't know how familiar you are with VirtualDub...
but normally you have 'two' panes that must be visible.
The left pane is the "Input video pane" and should show the original video
The right pane is the "Output video pane" and should show you a preview of the video after filters have been applied and before encoding has taken place.
Via the View menu:
- these two panes should be checked (= actif) AND
- in "Pane Layout" the option "Both panes" should be selected.
Via the View menu you can also 'swap' these two panes, but if I were you, I shouldn't do that (so leave this option unchecked)
When you click the 'Input playback' button (the one just at the right of the 'Stop' button), the Input pane should show you a moving picture.
If not, then try via the Options menu > Preferences >
- at "Display" : uncheck "Use DirectX for display panes", and/or
- at "3D Acceleration" : uncheck "Enable 3D video filter acceleration (VDXA)"
In the Video menu, you should select "Full processing mode", so you can be sure that also the Output video pane will show you a moving picture.
Verify if all this makes any difference.
HatMaster
Posted: Sep 17 2013, 09:39 PM
QUOTE (Abrazo @ Sep 17 2013, 08:56 PM)
Via the View menu:
I've made sure the 'Both panes' option under the View menu is checked in addition to the 'Input video pane' and 'Output video pane'.
The Input pane is moving fine and the Output pane is staying still like you said.
Also, I've just tried the ffdshow Video Codec I recently downloaded. That worked, but the resulting file was 13 GBs, which I think is too big for Youtube. The original file I used was 31.9 GBs.
I'm currently testing each encoder a second time after the adjustments I made to see which one will give me a working file that is small enough. The x264vfw - H.264/MPEG-4 AVC codec that I've seen a bunch of people recommend is one of the codecs so far not giving me working video.
Posted: Sep 18 2013, 05:57 PM
When using the "Output playback" button (the one at the right of the Input playback button), the images in the Output video pane at the right should also move.
Concerning compression:
Much depends on the resolution of images in the video (for exemple 720x404 or 1600x900) and the quality that you like to keep.
Normally you should need 10 à 30 MB for 1 (one) minute of video (including sound).
An exemple (look for the 'print screen') of settings for the x264vfw encoder is available here (thanks to dloneranger):
> http://forums.virtualdub.org/index.php?act...=ST&f=4&t=21157
HatMaster
Posted: Sep 19 2013, 03:07 AM
QUOTE (Abrazo @ Sep 18 2013, 05:57 PM)
I used the exact same config settings you linked me for the x264vfw encoder, and I'm getting an error message saying:
"Cannot start video compression:
An unknown error occurred (may be corrupt data).
(error code -100)"
The x264vfw log says:
x264vfw [error]: x264_param_apply_profile failed.
raffriff42
Posted: Sep 19 2013, 03:28 AM
"Error -100" usually means an odd resolution. For example, see:
http://forums.virtualdub.org/index.php?act...1796#entry94101
Could you please post a MediaInfo report on your source file?
(MediaInfo view=text; copy all; paste between [CODE] and [/CODE] in your reply)
And could you please save your VirtualDub settings (File menu, save settings) and paste that in another CODE block?
HatMaster
Posted: Sep 23 2013, 04:52 PM
QUOTE (raffriff42 @ Sep 19 2013, 03:28 AM)
One of my test videos:
General
Complete name                            : E:\Programs Files TB\Fraps\Movies\FTLGame 2013-09-18 22-59-59-62.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 355 MiB
Duration                                 : 27s 333ms
Overall bit rate                         : 109 Mbps
Video
Format                                   : Fraps
Codec ID                                 : FPS1
Bit rate                                 : 108 Mbps
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 30.000 fps
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 3.893
Stream size                              : 351 MiB (99%)
Audio
Format                                   : PCM
Format settings, Endianness              : Little
Format settings, Sign                    : Signed
Codec ID                                 : 1
Bit rate mode                            : Constant
Bit rate                                 : 1 411.2 Kbps
Channel(s)                               : 2 channels
Sampling rate                            : 44.1 KHz
Bit depth                                : 16 bits
Stream size                              : 4.60 MiB (1%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 976 ms (29.29 video frames)
Do I save it as a .vcf file or .txt file?
Save Processing Settings:
VirtualDub.audio.SetMode(0);
VirtualDub.audio.SetVolume();
VirtualDub.audio.EnableFilterGraph(0);
VirtualDub.video.SetInputFormat(0);
VirtualDub.video.SetOutputFormat(7);
VirtualDub.video.SetMode(3);
VirtualDub.video.SetPreserveEmptyFrames(0);
VirtualDub.video.SetIVTC(0, 0, 0, 0);
VirtualDub.video.SetCompression(0x34363278,0,10000,0);
VirtualDub.video.SetCompData(4720,"AwAAAAUAAAAAAAAAAwAAAA4AAAAFAAAAAAAAAAAAAAACAAAAFwAAAPoAAADQBwAAAQAAAAAAAAAAAAAAAQAAAC5ceDI2NC5zdGF0cwAAcwB0AGEAdABzAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAQAAAAIAAAABAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==");
I also tried the Resize filter in the Video menu.
I set:
-Set the pixel size to 1200 x 752, which is divisible by 4
-Codec-friendly sizing to: Multiples of 4
I'm still getting error code -100
Posted: Sep 23 2013, 05:47 PM
Change the x264 setting 'keep input colourspace' to 'convert to yuv 4:2:0' and it'll work
raffriff42
Posted: Sep 23 2013, 07:38 PM
meowmeow
Posted: Sep 24 2013, 03:15 PM
QUOTE (HatMaster @ Sep 23 2013, 04:52 PM)
Set in x264vfw
Profile to Auto ('high' doen't support rgb - need 'high 444')
Level to Auto
VirtualDub Hack - check
Posted: Sep 24 2013, 04:07 PM
level and profile on auto can give larger than needed file sizes unless you particularly need 16bit video or 444
generally 8bit, 420 is used by most people
HatMaster
Posted: Sep 24 2013, 05:18 PM
QUOTE (dloneranger @ Sep 23 2013, 05:47 PM)
Works like a charm! Thanks!
meowmeow
Posted: Sep 24 2013, 05:32 PM
QUOTE (dloneranger @ Sep 24 2013, 04:07 PM)
True. But only Fraps, VirtualDub and x264 can produce RGB videos.
Look - this image becomes grayscale after 420 conversion! Ban all 420s happy.gif
30 replies since Sep 13 2013, 08:44 PM Track this topic | Email this topic | Print this topic
Pages: (3) 1 [2] 3
