Status Window Refuses To Show Up, When starting with VCF scripts
Andrex
  Posted: Aug 14 2012, 10:03 PM
Hi, whenever I launch VirtualDub 1.9.11 (build 32842/release) with a script file to make a subtitle embedding process, it will absolutely refuse to obey the "Show status window" previous setting, which is set to ON all the time. I have to manually go to the View menu and re-activate the option to show the status window.
Unfortunately, the VD scripting system does not provide any means to enable/disable the status window on the VCF scripts to use as a workaround for this error.
Alternatives:
1. Fix the bug and try to obey the previous status window status
2. Add a command such as VirtualDub.ShowStatusWindow(1) to the VCF scrips (this command should be definitely present)
I use VirtualDub to embed subtitles with DivXLand Media Subtitler (which I develop) but this has nothing to do with the problem; I tried from the command line as well and the status window is always hidden)
Posted: Aug 18 2012, 11:49 PM
The status dialog is intentionally hidden by default during batch operations to avoid autonomously popping up dialogs during the batch process. In current versions, there is an option in Preferences under the Batch category that allows the visibility of this dialog to be controlled separately for batch/scripted operations.
1 replies since Aug 14 2012, 10:03 PM Track this topic | Email this topic | Print this topic
