Pages: (10) « First ... 8 9 [10]  ( Go to first unread post )
Virtualdub 1.10.1 Test Thread
L.H.V.F.
Posted: Dec 29 2011, 12:00 AM
When I was using the Ffmpeg Input Driver, by raythe0n, and have used other program together, a .ts (Transport Stream) crash the last build of the VirtualDub 1.10.1 released:
VirtualDub crash report -- build 34703 (release)
Disassembly:
00523ac0: 50              push   eax
00523ac1: 0433            add    al, 33h
00523ac3: c087068b4df45e  rol    byte ptr [edi-bb274fa], 5eh
00523aca: 8ac3            mov    al, bl
00523acc: 5b              pop    ebx
00523acd: 64890d00000000  mov    fs:[00000000], ecx
00523ad4: c9              leave
00523ad5: c3              ret
00523ad6: cc              int    3
00523ad7: cc              int    3
00523ad8: cc              int    3
00523ad9: cc              int    3
00523ada: cc              int    3
00523adb: cc              int    3
00523adc: cc              int    3
00523add: cc              int    3
00523ade: cc              int    3
00523adf: cc              int    3
00523ae0: 8b44240c        mov    eax, [esp+0ch]
00523ae4: 8b542404        mov    edx, [esp+04h]
00523ae8: 8b4c2408        mov    ecx, [esp+08h]
00523aec: 01c1            add    ecx, eax
00523aee: 01c2            add    edx, eax
00523af0: f7d8            neg    eax
00523af2: 7429            jz     00523b1d
00523af4: 83c008          add    eax, 08h
00523af7: 741e            jz     00523b17
00523af9: eb05            jmp    00523b00
00523afb: 90              nop
00523afc: 8d742600        lea    esi, [esi+00h]
00523b00: df6c01f8        fild   qword ptr [ecx+eax-08h]
00523b04: df2c01          fild   qword ptr [ecx+eax]
00523b07: d9c9            fxch   st(1)
00523b09: df7c02f8        fistp  qword ptr [edx+eax-08h]
00523b0d: df3c02          fistp  qword ptr [edx+eax]
00523b10: 83c010          add    eax, 10h
00523b13: 73eb            jnc    00523b00
00523b15: 7506            jnz    00523b1d
00523b17: df69f8          fild   qword ptr [ecx-08h]
00523b1a: df7af8          fistp  qword ptr [edx-08h]
00523b1d: c3              ret
00523b1e: 57              push   edi
00523b1f: 56              push   esi
00523b20: 8b7c240c        mov    edi, [esp+0ch]
00523b24: 8b742410        mov    esi, [esp+10h]
00523b28: 8b4c2414        mov    ecx, [esp+14h]
00523b2c: 89ca            mov    edx, ecx
00523b2e: c1e902          shr    ecx, 02h
00523b31: 83e203          and    edx, 03h
00523b34: f3a5            rep    movsd
00523b36: 89d1            mov    ecx, edx
00523b38: f3a4            rep    movsb
00523b3a: 5e              pop    esi
00523b3b: 5f              pop    edi
00523b3c: c3              ret
00523b3d: 55              push   ebp
00523b3e: 57              push   edi
00523b3f: 56              push   esi
00523b40: 53              push   ebx
00523b41: 8b5c2414        mov    ebx, [esp+14h]
00523b45: 8b542418        mov    edx, [esp+18h]
00523b49: 8b44241c        mov    eax, [esp+1ch]
00523b4d: f7d8            neg    eax
00523b4f: 83c03f          add    eax, 3fh
00523b52: 7649            jbe    00523b9d
00523b54: 0f6f02          movq   mm0, [edx]      <-- FAULT
00523b57: 0f6f4a08        movq   mm1, [edx+08h]
00523b5b: 0f6f5210        movq   mm2, [edx+10h]
00523b5f: 0f6f5a18        movq   mm3, [edx+18h]
00523b63: 0f6f6220        movq   mm4, [edx+20h]
00523b67: 0f6f6a28        movq   mm5, [edx+28h]
00523b6b: 0f6f7230        movq   mm6, [edx+30h]
00523b6f: 0f6f7a38        movq   mm7, [edx+38h]
00523b73: 0fe703          movntq [ebx], mm0
00523b76: 0fe74b08        movntq [ebx+08h], mm1
00523b7a: 0fe75310        movntq [ebx+10h], mm2
00523b7e: 0fe75b18        movntq [ebx+18h], mm3
00523b82: 0fe76320        movntq [ebx+20h], mm4
00523b86: 0fe76b28        movntq [ebx+28h], mm5
00523b8a: 0fe77330        movntq [ebx+30h], mm6
00523b8e: 0fe77b38        movntq [ebx+38h], mm7
00523b92: 83c340          add    ebx, 40h
00523b95: 83c240          add    edx, 40h
00523b98: 83c040          add    eax, 40h
00523b9b: 73b7            jnc    00523b54
00523b9d: 83e838          sub    eax, 38h
00523ba0: 7911            jns    00523bb3
00523ba2: 0f6f02          movq   mm0, [edx]
00523ba5: 0fe703          movntq [ebx], mm0
00523ba8: 83c208          add    edx, 08h
00523bab: 83c308          add    ebx, 08h
00523bae: 83c008          add    eax, 08h
00523bb1: 73ef            jnc    00523ba2
00523bb3: 83e807          sub    eax, 07h
00523bb6: 740a            jz     00523bc2
00523bb8: 89c1            mov    ecx, eax
00523bba: f7d9            neg    ecx
00523bbc: 89d6            mov    esi, edx
00523bbe: 89df            mov    edi, ebx
Built on Althena on Fri Dec 23 22:05:52 2011 using compiler version 1400
Windows 5.1 (Windows XP x86 build 2600) [Service Pack 3]
Memory status: virtual free 1891M/2048M, commit limit 5211M, physical total 3328M
EAX = fffffd6f
EBX = 01e5cd00
ECX = 01e5cd00
EDX = 00000000
EBP = 0012f268
ESI = 000002d0
EDI = 01e5cd00
ESP = 0012f23c
EIP = 00523b54
EFLAGS = 00010286
FPUCW = ffff027f
FPUTW = ffffffff
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'VirtualDub'...
...reading address 00000000.
Pointer dumps:
EBX   01e5cd00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ECX   01e5cd00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
EDI   01e5cd00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ESP   0012f238: 00000000 00000000 000002d0 01e5cd00 0012f268 0051b0a8 01e5cd00 00000000
     0012f258: 000002d0 0012f2d8 00000108 0067c68c 00000168 0055ecaf 01e5cd00 000002d0
     0012f278: 00000000 00000000 000002d0 00000108 0012f300 00cb6298 0012f35c 00cb5d58
     0012f298: 000002d0 01e00000 01e5cd00 01e00000 00000168 00000108 0055e8b3 00000210
EBP   0012f268: 00000168 0055ecaf 01e5cd00 000002d0 00000000 00000000 000002d0 00000108
     0012f288: 0012f300 00cb6298 0012f35c 00cb5d58 000002d0 01e00000 01e5cd00 01e00000
     0012f2a8: 00000168 00000108 0055e8b3 00000210 00000000 021b4338 0043b86d 0012f2d8
     0012f2c8: 021b4338 00000000 00000010 00bfc298 01e00000 00000000 000002d0 00000210
Thread call stack:
00523b54: VDFastMemcpyPartialMMX2()
0051b0a8: VDMemcpyRect()
0055ecaf: VDPixmapUberBlitterDirectCopy::Blit()
0055e8b3: VDPixmapUberBlitter::Blit()
0043b86d: VDFilterFrameVideoSource::RunRequests()
00470028: VDProject::UpdateFrame()
0043ac45: VDFilterFrameRequest::CreateClient()
0043ac8d: VDFilterFrameRequest::CreateClient()
00439a12: VDFilterFrameManualSource::CreateRequest()
004477d0: FilterSystem::RequestFrame()
00471f94: VDProject::DisplayFrame()
0047f56a: VDProjectUI::UISetDubbingMode()
00471789: _catch$?RunOperation@VDProject@@QAEXPAVIVDDubberOutputSystem@@HPAVDubOptions@@H_NJJ2@Z$1()
7e368bd9: USER32!GetWindowThreadProcessId [7e360000+8a80+159]
77e581ea: GDI32!GetObjectType [77e50000+814e+9c]
7e37cbf9: USER32!DrawIconEx [7e360000+1cb84+75]
004720e3: VDProject::Preview()
00472dc1: VDProject::PreviewInput()
7e36885a: USER32!GetDC [7e360000+86c7+193]
7e36882a: USER32!GetDC [7e360000+86c7+163]
7e37a013: USER32!IsWindowUnicode [7e360000+19f72+a1]
0047ec11: VDProjectUI::MainWndProc()
7e369488: USER32!GetWindowLongA [7e360000+945d+2b]
00474d70: VDProjectUI::WndProc()
0048bd95: VDUIFrame::StaticWndProc()
7e368734: USER32!GetDC [7e360000+86c7+6d]
7e368816: USER32!GetDC [7e360000+86c7+14f]
7e37927b: USER32!GetParent [7e360000+1910f+16c]
7e37f40b: USER32!SendMessageA [7e360000+1f3c2+49]
004c579d: VDPositionControlW32::WndProc()
004c5ee2: VDPositionControlW32::StaticWndProc()
7e378ea0: USER32!DefWindowProcW [7e360000+18d20+180]
7e3792e3: USER32!SendMessageW [7e360000+1929a+49]
7e39ff7d: USER32!CreateMDIWindowA [7e360000+3fdc0+1bd]
7e3965d2: USER32!DeregisterShellHookWindow [7e360000+302c0+6312]
7e375e94: USER32!IsDlgButtonChecked [7e360000+14dfa+109a]
7c802542: kernel32!WaitForSingleObject [7c800000+2530+12]
7471577a: MSCTF!TF_RunInputCPL [746e0000+310df+469b]
74715f00: MSCTF!TF_GetThreadFlags [746e0000+35af1+40f]
7e375231: USER32!IsDlgButtonChecked [7e360000+14dfa+437]
7e37a039: USER32!CallWindowProcW [7e360000+1a01e+1b]
5d515e5e: COMCTL32!InitCommonControlsEx [5d510000+3619+2845]
5d51602f: COMCTL32!DefSubclassProc [5d510000+5f9e+91]
5d515fe4: COMCTL32!DefSubclassProc [5d510000+5f9e+46]
5d5631a2: COMCTL32!ImageList_LoadImage [5d510000+44a91+e711]
5d5160be: COMCTL32!DefSubclassProc [5d510000+5f9e+120]
7e3689cd: USER32!GetWindowLongW [7e360000+88a6+127]
7e37a43b: USER32!PeekMessageA [7e360000+1a340+fb]
7e3696c7: USER32!DispatchMessageA [7e360000+96b8+f]
0045f9f6: WinMain@16()
005e43d6: __tmainCRTStartup()
7c817067: kernel32!RegisterWaitForInputIdle [7c800000+1701e+49]
-- End of report
The second time have crashed for the same file:
Disassembly:
00523ad4: c9              leave
00523ad5: c3              ret
00523ad6: cc              int    3
00523ad7: cc              int    3
00523ad8: cc              int    3
00523ad9: cc              int    3
00523ada: cc              int    3
00523adb: cc              int    3
00523adc: cc              int    3
00523add: cc              int    3
00523ade: cc              int    3
00523adf: cc              int    3
00523afb: 90              nop
00523b1d: c3              ret
00523b3c: c3              ret
Memory status: virtual free 1904M/2048M, commit limit 5211M, physical total 3328M
EAX = fffffed7
EBX = 01a8cd00
ECX = 01a8cd00
EDX = 00000000
EBP = 0012f6fc
ESI = 00000168
EDI = 01a8cd00
ESP = 0012f6d0
EIP = 00523b54
EFLAGS = 00010296
FPUCW = ffff027f
FPUTW = ffffffff
Crash context:
Pointer dumps:
EBX   01a8cd00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ECX   01a8cd00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
EDI   01a8cd00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ESP   0012f6d0: 00000000 00000168 01a8cd00 0012f6fc 0051b0a8 01a8cd00 00000000 00000168
     0012f6f0: 0012f76c 00000108 0067cb38 00000168 0055ecaf 01a8cd00 00000170 00000000
     0012f710: 00000000 00000168 00000108 0012f794 00cc2b28 0012f7f0 00cbf9c0 000002d0
     0012f730: 01a30000 01a8cd00 01aa4880 00000168 00000108 0055e8b3 00000210 00000000
EBP   0012f6f8: 0067cb38 00000168 0055ecaf 01a8cd00 00000170 00000000 00000000 00000168
     0012f718: 00000108 0012f794 00cc2b28 0012f7f0 00cbf9c0 000002d0 01a30000 01a8cd00
     0012f738: 01aa4880 00000168 00000108 0055e8b3 00000210 00000000 02824338 0043b86d
     0012f758: 0012f76c 02824338 00000000 00000000 00cb5410 01a30000 00000000 000002d0
Thread call stack:
0043a752: VDFilterFrameQueue::Add()
5b1c4be6: uxtheme!CloseThemeData [5b1c0000+4773+473]
5b1c3a49: uxtheme!DrawThemeText [5b1c0000+2ff8+a51]
7e37c32c: USER32!GetActiveWindow [7e360000+1c2e8+44]
7c90e453: ntdll!KiUserCallbackDispatcher [7c900000+e440+13]
7e37c24e: USER32!DefWindowProcA [7e360000+1c17e+d0]
7e37c291: USER32!DefWindowProcA [7e360000+1c17e+113]
7e37c2d0: USER32!SetWindowLongW [7e360000+1c2bb+15]
7ca2b1ce: SHELL32!DragAcceptFiles [7c9c0000+6b1a9+25]
0047d6ed: VDProjectUI::MenuHit()
0047d745: VDProjectUI::MenuHit()
7e378d8b: USER32!DefWindowProcW [7e360000+18d20+6b]
0048b690: VDUIFrame::DefProc()
0047ed37: _catch$?MainWndProc@VDProjectUI@@IAEJIIJ@Z$0()
7e378eec: USER32!DefWindowProcW [7e360000+18d20+1cc]
7e37fb07: USER32!TranslateAccelerator [7e360000+1fac4+43]
7e37fb24: USER32!TranslateAccelerator [7e360000+1fac4+60]
0048b81d: VDUIFrame::TranslateAcceleratorMessage()
0045f9d9: WinMain@16()
-- End of report
Could you analyse this errors, phaeron? I don't know if I have done something wrong in settings. After two crash errors, then I tryed to use Freemake Video Converter for my conversions tests.
According with MediaInfo, the video has 29.970 fps (for this I can play this in my CRT television), and the Ffmpeg Input Driver, by raythe0n, recognizes that the video has "59,940 fps", as the double.
Is necessary to upload a sample for the same?
Thanks,
L.H.V.F. .
jep
Posted: Dec 29 2011, 07:37 PM
Sorry if wrong place.
Drag/drop mkv and edit. Then use a/v stream copy to save results without recoding.
Results in avc/aac avi that works sometimes and once remuxed to mkv (mkvtoolnix) always works.
Would like to use external encoder option to directly mux to mkv but refuses to allow video stream copy.
If possible to implement, please consider doing so.
Thank you for an app that has given great results over years of service.
evropej
Posted: Dec 30 2011, 03:21 AM
anyone noticing slower start up time with this version?
Posted: Dec 30 2011, 07:12 AM
QUOTE (evropej @ Dec 29 2011, 11:21 PM)
Nope, for me it starts up instantly. But check your plugins folders; maybe something in there is causing a delay.
levicki
Posted: Jan 7 2012, 02:45 AM
"ASF files are not supported" message is still shown in version 1.10.1 when you try to open WMV from the command line even though DirectShowSource driver is installed and .wmv is added to its extension list.
Jam One
Posted: Feb 24 2012, 08:19 PM
Regression in released version 1.10.1
Open TARGA image sequence --> images are flipped upside-down.
Versions 1.10.1-Test1 thru 1.10.1-Test7 are fine.
Version 1.10.1-Test8 and following versions are broken.
Posted: Feb 25 2012, 10:21 PM
TARGA read inversion will be fixed in 1.10.2.
Oh, and I deleted a lot of pointless drama.
Jam One
Posted: Feb 26 2012, 10:02 AM
Thank you very much for both!
142 replies since Feb 20 2011, 06:53 AM Track this topic | Email this topic | Print this topic
