Can't Access Audio / Compression... Menu
furiousgame
Posted: Feb 14 2003, 05:17 PM
I am running VirtualDub 1.3.14 on WinXP and whenever I try to access the Audio / Compression... menu (after enabling Full processing mode), the program crashes. I have tried to access this menu for several different avi files encoded with several different audio codecs (or none at all) using both the normal version of VirtualDub and the P4-optimized version, and I've never actually seen what's in that menu. All other menus under Audio work as well as all of those under Video.
VirtualDub crash report -- build 14328 (release-P4)
Disassembly:
064410e0: 890424 mov [esp], eax
064410e3: e898d30100 call 0645e480
064410e8: 83c408 add esp, 08
064410eb: 33c0 xor eax, eax
064410ed: 89430c mov [ebx+0c], eax
064410f0: 894308 mov [ebx+08], eax
064410f3: 894304 mov [ebx+04], eax
064410f6: c745fc04000000 mov dword ptr [ebp-04], 00000004
064410fd: 8b5ddc mov ebx, [ebp-24]
06441100: 81c386000000 add ebx, 00000086
06441106: 8b4304 mov eax, [ebx+04]
06441109: 85c0 test eax, eax
0644110b: 741b jz 06441128
0644110d: 0fb650ff movzx edx, byte ptr [eax-01]
06441111: 85d2 test edx, edx
06441113: 0f8526010000 jnz 0644123f
06441119: 83c4f8 add esp, f8
0644111c: 48 dec eax
0644111d: 890424 mov [esp], eax
06441120: e85bd30100 call 0645e480
06441125: 83c408 add esp, 08
06441128: 33c0 xor eax, eax
0644112a: 89430c mov [ebx+0c], eax
0644112d: 894308 mov [ebx+08], eax
06441130: 894304 mov [ebx+04], eax
06441133: c745fc03000000 mov dword ptr [ebp-04], 00000003
0644113a: 8b45dc mov eax, [ebp-24]
0644113d: 83c044 add eax, 44
06441140: 8945e4 mov [ebp-1c], eax
06441143: c745fc07000000 mov dword ptr [ebp-04], 00000007
0644114a: c745fc08000000 mov dword ptr [ebp-04], 00000008
06441151: 8b45e4 mov eax, [ebp-1c]
06441154: c70080615106 mov dword ptr [eax], 06516180
0644115a: c745fc07000000 mov dword ptr [ebp-04], 00000007
06441161: 8b5de4 mov ebx, [ebp-1c]
06441164: 83c332 add ebx, 32
06441167: 8b4304 mov eax, [ebx+04]
0644116a: 85c0 test eax, eax
0644116c: 741b jz 06441189
0644116e: 0fb650ff movzx edx, byte ptr [eax-01] <-- FAULT
06441172: 85d2 test edx, edx
06441174: 0f85af000000 jnz 06441229
0644117a: 83c4f8 add esp, f8
Please help.
Posted: Feb 14 2003, 08:19 PM
Maybe you have a faulty audio codec installed. Please post the entire crash report.
furiousgame
Posted: Feb 17 2003, 10:56 PM
As per your request:
Disassembly:
0644117d: 48 dec eax
0644117e: 890424 mov [esp], eax
06441181: e8fad20100 call 0645e480
06441186: 83c408 add esp, 08
06441189: 33c0 xor eax, eax
0644118b: 89430c mov [ebx+0c], eax
0644118e: 894308 mov [ebx+08], eax
06441191: 894304 mov [ebx+04], eax
06441194: c745fc03000000 mov dword ptr [ebp-04], 00000003
0644119b: 8b4de4 mov ecx, [ebp-1c]
0644119e: e86d590400 call 06486b10
064411a3: c745fc00000000 mov dword ptr [ebp-04], 00000000
064411aa: 8b45dc mov eax, [ebp-24]
064411ad: c7400460615106 mov dword ptr [eax+04], 06516160
064411b4: c745fcffffffff mov dword ptr [ebp-04], ffffffff
064411bb: 8b45d4 mov eax, [ebp-2c]
064411be: c7400c60615106 mov dword ptr [eax+0c], 06516160
064411c5: 8b4df4 mov ecx, [ebp-0c]
064411c8: 64890d00000000 mov fs:[00000000], ecx
064411cf: 8b1c24 mov ebx, [esp]
064411d2: 8b742404 mov esi, [esp+04]
064411d6: 8b7c2408 mov edi, [esp+08]
064411da: 8be5 mov esp, ebp
064411dc: 5d pop ebp
064411dd: c3 ret
064411de: 8b db 8b
064411df: 4d dec ebp
Windows 5.1 (WinXP build 2600) [Service Pack 1]
EAX = 63090000
EBX = 00189576
ECX = 77e760de
EDX = 00000000
EBP = 0012f150
DS:ESI = 0023:00000016
ES:EDI = 0023:0645e520
SS:ESP = 0023:0012f10c
CS:EIP = 001b:0644116e
FS = 003b
GS = 0000
EFLAGS = 00010206
MM0 = 00ff00ff00ff00ff
MM1 = 00ff00ff00ff00ff
MM2 = 000000eb00e800d7
MM3 = 8000000000000000
MM4 = c000000000000000
MM5 = fcd66b2d7e5d1800
MM6 = 8000000000000000
MM7 = f280000000000000
Thread 00000c08 (Main thread)
Init.cpp(219)
Init.cpp(238)
Init.cpp(256)
Init.cpp(318)
Main.cpp(182)
Main.cpp(205)
VideoSource.cpp(566)
FilterSystem.cpp(427)
FilterSystem.cpp(561)
0644116e: lameACM!0000116e
06443bc2: lameACM!00003bc2
0645e66e: lameACM!DriverProc [06440000+1e520+14e]
77f5f485: ntdll!RtlUnlockHeap [77f50000+f467+1e]
77f5f4a1: ntdll!RtlUnlockHeap [77f50000+f467+3a]
77e73996: kernel32!GlobalUnlock [77e60000+1391c+7a]
77e7399e: kernel32!GlobalUnlock [77e60000+1391c+82]
76b437b0: WINMM!SendDriverMessage [76b40000+36f0+c0]
76b43707: WINMM!SendDriverMessage [76b40000+36f0+17]
76b43925: WINMM!CloseDriver [76b40000+38da+4b]
76b438ed: WINMM!CloseDriver [76b40000+38da+13]
77be358d: MSACM32!acmGetVersion [77be0000+13a0+21ed]
77be3a82: MSACM32!acmDriverClose [77be0000+3a4c+36]
004a07e4: ACMDriverEnumerator()
77be3c9c: MSACM32!acmDriverEnum [77be0000+3beb+b1]
004a0d7e: AudioChooseCompressionDlgProc()
5ad77519: uxtheme!GetThemeBackgroundRegion [5ad70000+6eda+63f]
5ad71b71: uxtheme!DrawThemeParentBackground [5ad70000+1677+4fa]
5ad77590: uxtheme!GetThemeBackgroundRegion [5ad70000+6eda+6b6]
77d67ad7: USER32!SetWindowPlacement [77d40000+27a80+57]
77d6cde5: USER32!DefRawInputProc [77d40000+2ca50+395]
77d57137: USER32!CharPrevW [77d40000+16d6f+3c8]
77d5b763: USER32!DefDlgProcA [77d40000+1b742+21]
77d6ccd4: USER32!DefRawInputProc [77d40000+2ca50+284]
77d456b6: USER32!IsWindowVisible [77d40000+4f46+770]
77d581f1: USER32!CharPrevW [77d40000+16d6f+1482]
77d746d7: USER32!CheckRadioButton [77d40000+345cc+10b]
77d6644e: USER32!DialogBoxIndirectParamAorW [77d40000+26419+35]
77d6e97e: USER32!DialogBoxParamA [77d40000+2e934+4a]
004a1503: AudioChooseCompressor()
0049d089: AudioSource::getWaveFormat()
00495905: MenuHit()
77d6cc01: USER32!DefRawInputProc [77d40000+2ca50+1b1]
77d6ccf4: USER32!DefRawInputProc [77d40000+2ca50+2a4]
77d6cc9a: USER32!DefRawInputProc [77d40000+2ca50+24a]
77d445bd: USER32!TranslateMessageEx [77d40000+3e30+78d]
77d445c8: USER32!TranslateMessageEx [77d40000+3e30+798]
77d447d4: USER32!DefWindowProcA [77d40000+45cb+209]
77d447e4: USER32!DefWindowProcA [77d40000+45cb+219]
77fb4da6: ntdll!KiUserCallbackDispatcher [77f50000+64d93+13]
77d44e12: USER32!IsWindow [77d40000+4da0+72]
77d86f1e: USER32!DdeAbandonTransaction [77d40000+46e49+d5]
5ad73f9b: uxtheme!GetThemeColor [5ad70000+3ab8+4e3]
5ad8cc93: uxtheme!SetThemeAppProperties [5ad70000+1cb45+14e]
5ad71af6: uxtheme!DrawThemeParentBackground [5ad70000+1677+47f]
5ad71c89: uxtheme!DrawThemeParentBackground [5ad70000+1677+612]
77d44636: USER32!DefWindowProcA [77d40000+45cb+6b]
77d6c939: USER32!GetMenuInfo [77d40000+2c733+206]
77d4465f: USER32!DefWindowProcA [77d40000+45cb+94]
77d44651: USER32!DefWindowProcA [77d40000+45cb+86]
00498aa3: atch_0_4()
77d45cd6: USER32!ScreenToClient [77d40000+5bff+d7]
77d53346: USER32!CallWindowProcW [77d40000+1332d+19]
77341bdf: COMCTL32!InitCommonControlsEx [77340000+16c9+516]
77341d3a: COMCTL32!DefSubclassProc [77340000+1cb0+8a]
77341d4c: COMCTL32!DefSubclassProc [77340000+1cb0+9c]
77341d54: COMCTL32!DefSubclassProc [77340000+1cb0+a4]
77341cf4: COMCTL32!DefSubclassProc [77340000+1cb0+44]
77365bfe: COMCTL32!EnumMRUListW [77340000+24ca3+f5b]
77d491b3: USER32!CallNextHookEx [77d40000+916f+44]
7472c331: MSCTF!TF_UninitSystem [74720000+ba35+8fc]
7472c336: MSCTF!TF_UninitSystem [74720000+ba35+901]
77d5ff45: USER32!GetMessagePos [77d40000+1fa10+535]
77d4956b: USER32!GetMenuState [77d40000+94c2+a9]
77d4958e: USER32!GetMenuState [77d40000+94c2+cc]
77d4c092: USER32!GetWindowThreadProcessId [77d40000+c015+7d]
77d4c0a2: USER32!GetWindowThreadProcessId [77d40000+c015+8d]
77d89e94: USER32!BlockInput [77d40000+49e38+5c]
77d491dc: USER32!CallNextHookEx [77d40000+916f+6d]
77d44455: USER32!TranslateMessageEx [77d40000+3e30+625]
77d4414d: USER32!TranslateMessageEx [77d40000+3e30+31d]
77d45f28: USER32!GetParent [77d40000+5f06+22]
77d45f70: USER32!GetParent [77d40000+5f06+6a]
77d44d58: USER32!DispatchMessageA [77d40000+4d4d+b]
00493718: atch_0_0()
77dd24b6: ADVAPI32!RegQueryValueExA [77dd0000+2410+a6]
77dd24e5: ADVAPI32!RegQueryValueExA [77dd0000+2410+d5]
77f758b6: ntdll!NtClose [77f50000+258aa+c]
77dd17b9: ADVAPI32!000017b9
77f52013: ntdll!RtlAcquirePebLock [77f50000+1feb+28]
77f5201c: ntdll!RtlAcquirePebLock [77f50000+1feb+31]
77f5202c: ntdll!RtlReleasePebLock [77f50000+201d+f]
77e61a57: kernel32!GetStartupInfoA [77e60000+177e+2d9]
77e619ef: kernel32!GetStartupInfoA [77e60000+177e+271]
004d81af: WinMainCRTStartup()
77e7d93e: kernel32!LoadLibraryExW [77e60000+1d839+105]
004d8046: WinMainCRTStartup()
70a71a29: SHLWAPI!StrCpyW [70a70000+19cb+5e]
77f532fa: ntdll!wcschr [77f50000+307c+27e]
77e814c7: kernel32!GetCurrentDirectoryW [77e60000+21483+44]
-- End of report
Posted: Feb 18 2003, 03:14 AM
Looks like it crashed in the LAME MP3 codec. Try uninstalling the codec and see if it helps.
furiousgame
Posted: Feb 18 2003, 06:22 AM
I just installed another version of LAME over the top of the old one and the problem went away.
Thanks for your help!
Mystery
Posted: Feb 28 2003, 08:31 PM
have the same problem, but where u get the lame a other version of it.
5 replies since Feb 14 2003, 05:17 PM Track this topic | Email this topic | Print this topic
