| John I. |
| Posted: Apr 28 2010, 08:02 PM |
VirtualDub 1.9.x-test16 is losing frames.
Settings: ---------------- Video compression threads= 1 Video filter threading= Auto Video filter process-ahead= Auto
Source= AVI (Uncompressed) 27 frames. ---------------- When re-compressing using 'Full processing mode':
Case 1: Codec= (XVID 1 Pass) Output = 22 frames (5 Frames lost) Case 2: Codec= (XVID 2 Pass) Output = 22 frames (5 Frames lost)
Case 3: Codec= (DIVX 1 Pass) Output = 23 frames (4 Frames lost) Case 4: Codec= (DIVX 2 Pass) Output = 23 frames (4 Frames lost)
Case 5: Codec= (Uncompressed) Output= 27 frames (NO LOSS) Full Processing ----------------
Case 6: VirtualDub 1.9.9 (Any Codec) Output= 27 frames (NO LOSS)
| mayhem |
| Posted: Apr 28 2010, 11:17 PM |
Yup, its not isolated, just did two quick little test videos, one was 112 frames and the other 142 frames and after processing with test16 they came out as 108 and 139, losing 4 frames, and 3 frames respectively.
This was in full process mode with threading enabled, although even after setting the filter threading to disabled this still occured. After setting the compressor threading to 0 behaviour returned to normal.
| Posted: Apr 29 2010, 05:04 AM |
Yeah, this was caused by some changes I tried to make to fix some annoying issues with the B-frame delay queue code. Basically, it was a bit sketchy in one-thread mode, and it became unreliable in multithreaded mode (100% CPU lockups). I'm trying to rewrite it. |
| DanskDranker |
| Posted: Apr 29 2010, 03:38 PM |
Build 33732 is not good.
It does not .Pass file when I have they started to convert my video into Xvid Twopass 1st pass, but it does in build 32817 |
| Posted: Apr 30 2010, 04:20 AM |
Uh, in English? |
| Posted: Apr 30 2010, 05:11 AM |
Pushed out another release with an attempted fix for some of the frame dropping issues. Also, I figured out and fixed the problem that was causing Run Video Analysis Pass to not run the video codec like it does in 1.9.9. |
| Barough |
| Posted: Apr 30 2010, 11:44 AM |
Thnx for the new Build.
| John I. |
| Posted: Apr 30 2010, 02:45 PM |
| QUOTE | phaeron Posted on Apr 30 2010, 05:11 AM
Pushed out another release with an attempted fix for some of the frame dropping issues. |
Frame dropping issue is resolved.
Thanks phaeron
| pureocean |
| Posted: Apr 30 2010, 06:54 PM |
@phaeron: Thank you very much for build 33740. Xvid 1pass problem is fixed. If you can fix to Smart Rendering, i would be very grateful. Thank you for all your efforts. |
| DanskDranker |
| Posted: Apr 30 2010, 10:05 PM |
Thank You. It works great now
Edit: It works not 100%, so here is a crash report
VirtualDub crash report -- build 33740 (release) --------------------------------------
Disassembly: 00421ca0: 53 push ebx 00421ca1: c644242c01 mov byte ptr [esp+2ch], 01h 00421ca6: e8e5260600 call 00484390 00421cab: 84c0 test al, al 00421cad: 7517 jnz 00421cc6 00421caf: 8b4c2410 mov ecx, [esp+10h] 00421cb3: 3bcb cmp ecx, ebx 00421cb5: 885c2424 mov [esp+24h], bl 00421cb9: 7407 jz 00421cc2 00421cbb: 8b11 mov edx, [ecx] 00421cbd: 8b4204 mov eax, [edx+04h] 00421cc0: ffd0 call eax 00421cc2: 32c0 xor al, al 00421cc4: eb2f jmp 00421cf5 00421cc6: 8b442410 mov eax, [esp+10h] 00421cca: 0fb6500c movzx edx, byte ptr [eax+0ch] 00421cce: 8b4810 mov ecx, [eax+10h] 00421cd1: 8b4008 mov eax, [eax+08h] 00421cd4: 53 push ebx 00421cd5: 53 push ebx 00421cd6: 52 push edx 00421cd7: 50 push eax 00421cd8: 51 push ecx 00421cd9: 8bce mov ecx, esi 00421cdb: e8a0fcffff call 00421980 00421ce0: 8b4c2410 mov ecx, [esp+10h] 00421ce4: 3bcb cmp ecx, ebx 00421ce6: 885c2424 mov [esp+24h], bl 00421cea: 7407 jz 00421cf3 00421cec: 8b11 mov edx, [ecx] 00421cee: 8b4204 mov eax, [edx+04h] 00421cf1: ffd0 call eax 00421cf3: b001 mov al, 01h 00421cf5: 8b4c241c mov ecx, [esp+1ch] 00421cf9: 897d00 mov [ebp+00h], edi 00421cfc: 5f pop edi 00421cfd: 5d pop ebp 00421cfe: 5e pop esi 00421cff: 5b pop ebx 00421d00: 64890d00000000 mov fs:[00000000], ecx 00421d07: 83c418 add esp, 18h 00421d0a: c3 ret 00421d0b: cc int 3 00421d0c: cc int 3 00421d0d: cc int 3 00421d0e: cc int 3 00421d0f: cc int 3 00421d10: 6aff push 0ffh 00421d12: 6850005f00 push 005f0050 (RtlUnwind@16+161a) 00421d17: 64a100000000 mov eax, fs:[00000000] 00421d1d: 50 push eax 00421d1e: 64892500000000 mov fs:[00000000], esp 00421d25: 83ec08 sub esp, 08h 00421d28: 53 push ebx 00421d29: 55 push ebp 00421d2a: 56 push esi 00421d2b: 57 push edi 00421d2c: 8b7c2428 mov edi, [esp+28h] 00421d30: 33db xor ebx, ebx 00421d32: 8bf1 mov esi, ecx 00421d34: 8b4f40 mov ecx, [edi+40h] <-- FAULT 00421d37: 895c2428 mov [esp+28h], ebx 00421d3b: 395e6c cmp [esi+6ch], ebx 00421d3e: 895c2420 mov [esp+20h], ebx 00421d42: 0f8407010000 jz 00421e4f 00421d48: 385c242c cmp [esp+2ch], bl 00421d4c: 7419 jz 00421d67 00421d4e: 8b07 mov eax, [edi] 00421d50: 8b10 mov edx, [eax] 00421d52: 8bcf mov ecx, edi 00421d54: ffd2 call edx 00421d56: 8b4e68 mov ecx, [esi+68h] 00421d59: 3bcb cmp ecx, ebx 00421d5b: 7407 jz 00421d64 00421d5d: 8b01 mov eax, [ecx] 00421d5f: 8b5004 mov edx, [eax+04h] 00421d62: ffd2 call edx 00421d64: 897e68 mov [esi+68h], edi 00421d67: 8b0d847e6700 mov ecx, [00677e84] 00421d6d: 3bcb cmp ecx, ebx 00421d6f: 7411 jz 00421d82 00421d71: 8b01 mov eax, [ecx] 00421d73: 8b10 mov edx, [eax] 00421d75: 53 push ebx 00421d76: 681ca86600 push 0066a81c 00421d7b: 68f42f6000 push 00602ff4 00421d80: ffd2 call edx 00421d82: 8b4624 mov eax, [esi+24h] 00421d85: 8b28 mov ebp, [eax] 00421d87: 89442410 mov [esp+10h], eax 00421d8b: 8b5c2410 mov ebx, [esp+10h] 00421d8f: 896c2414 mov [esp+14h], ebp 00421d93: c703dc2f6000 mov dword ptr [ebx], 00602fdc 00421d99: 8b4c2428 mov ecx, [esp+28h] 00421d9d: 85c9 test ecx, ecx 00421d9f: c6 db 0c6h
Built on Aegis on Thu Apr 29 21:55:10 2010 using compiler version 1400
Windows 6.1 (Windows Vista x64 build 7601) [Service Pack 1, v.153]
EAX = 0ca3fec4 EBX = 00000000 ECX = 0250d368 EDX = 024f5238 EBP = 0ca3ff08 ESI = 0250d368 EDI = 00000000 ESP = 0ca3fe70 EIP = 00421d34 EFLAGS = 00010246 FPUCW = 027f FPUTW = ffff
Crash context: An out-of-bounds memory access (access violation) occurred in module 'VirtualDub'...
...reading address 00000040...
...while running thread "Processing" (thread.cpp:179).
Pointer dumps:
EAX 0ca3fec0: 0250d1d0 0ca3fefc 005f0220 00000000 004215b9 00000000 0250d1d0 024fcfb8 ECX 0250d368: 00603038 00000060 00000000 000005a0 0250d068 024f8c68 0250d130 01000001 EDX 024f5238: 024ea6a4 00000000 6e616801 024ec4d8 0250dd00 00000000 0000061c 00000000 ESI 0250d368: 00603038 00000060 00000000 000005a0 0250d068 024f8c68 0250d130 01000001 ESP 0ca3fe70: 00000001 0250d368 0ca3ff08 0250d368 776bf9b5 760c014d 0ca3fec4 005f0050 0ca3fe90: ffffffff 00422bda 00000000 00000001 0250d368 0250d368 00424403 00000001 0ca3feb0: 0250d1d0 0250d30c 006028dc 00000000 0250d1d0 0ca3fefc 005f0220 00000000 0ca3fed0: 004215b9 00000000 0250d1d0 024fcfb8 004ee587 0ca3ff14 00000001 00000000 EBP 0ca3ff08: 0ca3ff48 0052d90b 024fcfb8 0061fb08 00000000 0062fca0 000000b3 0062fc88 0ca3ff28: 00602e94 0062fca0 000000b3 0062fc88 00602e94 0ca3ff70 005f7dfd 00000000 0ca3ff48: 0ca3ff80 005d643e 0250d1d0 c078f129 00000000 024fcfb8 024fcfb8 c0000005 0ca3ff68: 0ca3ff54 0ca3fa48 0ca3ffc4 005d9c60 ccbd2d99 00000000 0ca3ff94 005d64e3
Thread call stack: 00421d34: VDDubVideoProcessor::WriteFinishedVideoFrame() 776bf9b5: ntdll!NtSetEvent [776a0000+1f9a0+15] 760c014d: KERNELBASE!SetEvent [760b0000+1013d+10] 00422bda: VDDubVideoProcessor::RunPathFlushCompressor() 00424403: VDDubVideoProcessor::WriteVideo() 004215b9: VDDubProcessThread::ThreadRun() 004ee587: ?$VDProtectedAutoScope1::?$VDProtectedAutoScope1() 0052d90b: VDThread::StaticThreadStart() 005d643e: _callthreadstartex() 005d64e3: _threadstartex@4() 75293e5d: kernel32!BaseThreadInitThunk [75280000+13e4b+12] 776d9df2: ntdll!RtlInitializeExceptionChain [776a0000+39d8f+63] 776d9dc5: ntdll!RtlInitializeExceptionChain [776a0000+39d8f+36]
-- End of report |
| DanskDranker |
| Posted: May 1 2010, 05:52 PM |
Something News??? |
| Posted: May 1 2010, 11:11 PM |
Perhaps you could be a bit patient while I debug this?
Update: Please try test-18. In local testing, it passes XviD smart rendering stress testing on 0/1 threads and Huffyuv recompression on 0-2 threads.
This post has been edited by phaeron on May 2 2010, 03:01 AM |
| pureocean |
| Posted: May 2 2010, 04:47 AM |
@phaeron: Smart rendering is working now. Anyomore, no need to using VDub1.8.8 for it. Thank you very much for fix.
There exists a minor bug: Although selected Fast Compress with Smart Rendering, if there is filters, Smart Rendering don't working. If filters is removed, Smart Rendering properly working.
(I'm sorry my bad english.) |
| DanskDranker |
| Posted: May 3 2010, 05:51 AM |
Thank You Now it works 100% |
| Posted: May 4 2010, 05:20 AM |
I fixed the frame mapping with normal/fast recompress mode with filters enabled... but I'm not sure if it will fix the smart rendering issue. Try test-19. |
