Add Noise/grain & Deblock Filters Needed, ffdshow has both of them & r quite good
Morsa
Posted: Oct 17 2002, 07:56 PM
ffdshow has these features and is GPL.
If there are any of its developers in this forum it would be nice to have the same filters for Vdub, they are really good.
The compressed AVIs opened in Vdub always look very blocky.
By now, I´m trying to understand its source code but I´m not skilled enough to export it right now.
If someone thinks it´s possible.......
Morsa
Posted: Nov 3 2002, 09:23 PM
Look at this, Noise use to reduce DCT artifacts/blocks.
http://forum.doom9.org/showthread.php?s=&t...&threadid=37135
Posted: Nov 4 2002, 06:27 AM
Noise can be a good thing??? Hot damn! And here I've spent so much time trying to eliminate noise in my captures...
Neo Neko
Posted: Nov 4 2002, 07:08 AM
VirtualdubMod Alpha tester
Noise is a bitch to encode and makes bitrate baloon on pretty much every codec. But it hides artifacts. smile.gif Here is a thing you might try. On the ffdshow config check the box next to RAW on the codec section. Viola! Now that noise is applied to all videos played through directshow!! Adding actual noise to an encode as it is encoding would only seem usefull if you want to give the impression that a video might be old or degraded. Other than that it will not improve your encodes.
Morsa
Posted: Nov 4 2002, 07:51 AM
so, what is the problem about having an Add grain filter, to give some deinterlaced material a good¨Film Look¨??
Avisynth Add noise filters
http://www.jungleweb.net/~sansgrip/avisynth/
Neo Neko
Posted: Nov 4 2002, 09:27 PM
Doing it while watching is one thing. Doing it while encoding is quite another. If you do it while encoding then your file sizes will explode.
Morsa
Posted: Nov 5 2002, 12:27 AM
I am talking about film look, not compression.
It seems to me like, Using an add grain filter is a kind of sin for the people in this forum .......
Posted: Nov 5 2002, 05:14 AM
I think in the Bible it states clearly "Thou shalt not add noise."
Morsa
Posted: Nov 5 2002, 10:54 PM
By these days I am experimenting with Marc FD´s add noise filter for Avisynth.
I´ve seen it does a good job eliminating that horrible macroblocks
Let´s see what happens.....
Milan
Posted: Nov 11 2002, 07:06 AM
I'm working now on ffvdub VirtualDub filter. It should be able to use all ffdshow image filters for processing video in VirtualDub.
ffvdub's sources are in ffvdub module in ffdshow CVS, however it's not very usable yet.
Morsa
Posted: Nov 11 2002, 05:29 PM
GOOD!!!!!!
Does it has the deblocking capabilities??
10 replies since Oct 17 2002, 07:56 PM Track this topic | Email this topic | Print this topic
