Video Tutorial, Filters
evropej
Posted: Jan 23 2014, 10:13 PM
Is there a video tutorial out there to show how someone can write a simple filter and compile it for vdub?
Posted: Jan 23 2014, 10:25 PM
The sdk comes with all the stuff you need, and two simple filters you can alter to do your own stuff
The hardest part is doing a GUI
To figure out that you can download others with source code and have a read
The easy bit if fiddling with the picture :-)
I hadn't done any c++ programming at all until I decided I wanted to make a few changes to virtualdub
A knowledge of any other language is a major help though as you already know the concepts if not the words
evropej
Posted: Jan 24 2014, 04:26 PM
I have looked at it long ago and got discouraged. I am more of a visual person so I like watching a video. Plus, when someone demonstrates in a video, there is a lot of little gotchas that get answered. If I had more time and less hobbies, I would dig into it but for now, I am looking for an easy out lol biggrin.gif
Posted: Jan 24 2014, 05:29 PM
It's not a visual task though?
Kind of like asking to see a video of someone writing a book, just watching someone type won't be useful at all
I'm really not sure what you'd expect to see in a video that could be of any help at all
evropej
Posted: Jan 24 2014, 06:08 PM
So to find out what it really takes to compile a filter, you would need to start in virtualmachine with nothing installed. Try this out and you will be amazed.
You will find out that you do a lot of things which you are not aware of that most people don't, I speak from experience.
For example, I always install a c++ distribution package by default which installs dlls. I tried telling someone that it was easy to install MSU filters and run it so I could not understand why theirs didnt work. So one day I tried a clean install in a virtualmachine and bingo! He found out that he needed to install a package, use a 32 bit version, and then it would work. None are evident from the installation instruction which says put in in the plugin folder.
The code itself and the programming is not as critical.
I hope this makes sense.
4 replies since Jan 23 2014, 10:13 PM Track this topic | Email this topic | Print this topic
