Problem With Neat Filter, Neat Filt stops working after 43 Minutes
raydoyle
Posted: Sep 7 2013, 06:22 PM
I’m not very experienced with Filter Using and at the Moment I could use
a little Help with the following Problem:
The Source for my Project is a captured VHS turned into .avi with GordianKnot.
I want to denoise the Picture with NEAT Filter.
The Result looks wonderful with one Mistake:
The NEAT Filter has stopped working after ~ 43 Minutes.
Sounds strange , but the Movie is filtered only till Minute 43, the Rest is still noisy.
I tried other .avis – same Mistake.
What am I doing wrong ? I would love to have the Quality of the Filter for the
whole Movie.
Is there a Limit of Time/Space I have to uncheck ?
Excuse my poor English & Thanks in Advance.
(Software:Win 7 HP , VirtualDub 1.6.11 , Neat 2.0)
Posted: Sep 7 2013, 06:39 PM
There's no limit like that in Virtualdub
raydoyle
Posted: Sep 7 2013, 06:52 PM
Thank you for the fast Answer.
Any other idea ?
Posted: Sep 7 2013, 06:58 PM
I'd try with the maker of the filter
raffriff42
Posted: Sep 7 2013, 09:25 PM
Looks like the "Demo" version has a 30 minute time limit...so you got 15 free minutes (?)
http://www.neatvideo.com/featuremap.html
-vdub-
Posted: Sep 8 2013, 01:54 AM
Most filters if not all work are better with using an intermediate lossless avi video
Many ways to work with intermediate video with Virtualdub one of those ways to do this..
Install Largarith Codec http://lags.leetcode.net/codec.html
Open Virtualdub
Load your old avi video
Set video compression to Largarith
Save the video as avi (1)
Drag and drop the new saved avi (1) video to Virtualdub
Set Neat Filter and make adjustments to your liking
Save the video as avi (2)
Drag and drop this new avi video (2) to Virtualdub
When ready to save the final avi video do so using another video compressor set to a format you need such as x264vfw
1. If need to install a codec
2. Close Virtualdub
3. Install the codec
4. Open Virtualdub load avi video (2) (or the last avi you saved)
Set the video compressor for your final video and its settings
Save the final video as avi
raydoyle
Posted: Sep 8 2013, 04:59 AM
Thanx to all for more Answers.
@ raffriff42:
It's a full Version of NeatVideo.
@ -vdub-:
I will try it your Way.
Will take some Time - then I gonna report.
raffriff42
Posted: Sep 8 2013, 08:49 AM
Might be a bug:
25fps * 60sec * 43.69min = 65535 frames = max unsigned 16 bit int value...
raydoyle
Posted: Sep 8 2013, 10:54 AM
@raffriff42:
Wow!
Can that Value be changed ?
raffriff42
Posted: Sep 8 2013, 02:01 PM
The developer should be notified. Hopefully it's an easy fix, but if Neat has an inherent 16-bit limit, it might be a very difficult fix. sad.gif
While you are waiting, you need to split your videos into segments, I guess.
raydoyle
Posted: Sep 8 2013, 05:52 PM
Thanx again raffriff42 !
I will contact the Developer.
And splitting that Video is another fine Idea !!
10 replies since Sep 7 2013, 06:22 PM Track this topic | Email this topic | Print this topic
