| Fess |
Posted: Jan 11 2003, 06:23 PM |
Hello everyone...
I've downloaded Donald Graft's logo filter at http://shelob.mordor.net/dgraft/ but I'm having some problem with the finished file.
The issue I'm haveing is creating a bitmap how he said to create it: 'Static Logo' Create a 24-bit-depth windows bitmap file with the desired size and with a transparent color zone if desired. The transparency color may be arbitrarily selected and then configured in the filter configuration.
I know how to create a 24-bit-depth bitmap, but not with a 'transparent color zone' I am only 6+ months PhotoShop7.0 educated.
What I do is creat a image on a blue background. Flatten and save as 24-bit-depth bitmap.
I enter this bitmap as the input file and put a check mark to enable the "Transparent Color" which is 255 blue. I modify the tolerance to get rid of any extra visible blue an it looks passable.
Is this correct? I am worried the steps I took in PhotoShop7.0, can someone correct my steps in PhotoShop If they are incorrect?
Regards Fess |
| jcsston |
| Posted: Jan 11 2003, 06:43 PM |
Matroska Dev
Yes that is how I do it. But like green better  AFAIK .BMP's cannot have transparency information of any sort in them.
| Fess |
| Posted: Jan 11 2003, 08:49 PM |
jcsston....
Thanks for you input...
Regards Fess |
