| humanfly |
| Posted: Dec 6 2002, 12:28 AM |
I have a geforce 4 128mb with vid in and out. running xp pro
Is it possible to capture from a video composite source (cable) that is transmitting a negative image, and invert it on the fly?
I have managed to use sonic foundry vegas video to capture and then convert with an invert filter however this is time consuming .
What i need to do is apply the filter to the streaming video...
Is this possible? |
| jcsston |
| Posted: Dec 6 2002, 01:12 AM |
Matroska Dev
In Virtualdub you could apply filters while capturing a clip and then play it back as soon as the capture is over.
| humanfly |
| Posted: Dec 6 2002, 01:20 AM |
Yes, i have been experimenting with that.. but what i really want to do is apply invert in real time...
Is it possible? |
| jcsston |
| Posted: Dec 6 2002, 01:46 AM |
Matroska Dev
Not that I know of
| humanfly |
| Posted: Dec 6 2002, 04:09 AM |
Are there any other software apps that are capable of such a thing? |
| Neo Neko |
Posted: Dec 6 2002, 04:27 AM |
VirtualdubMod Alpha tester
You can use Dscaler to invert the colors of your scrambled porn...... |
| humanfly |
| Posted: Dec 6 2002, 10:43 AM |
yes, very droll...
But can it do it in real time? Whilst streaming, i want to go in to the capture and back out to a tv... |
| humanfly |
| Posted: Dec 6 2002, 04:05 PM |
COOL!!!
It worked, the invert filter works a treat! thanks...
Can i use dscaler to record also? |
