Selecting The Channel
curmudgeon
Posted: Nov 23 2002, 08:14 AM
I know this doesn't have anything to do with Virtualdub itself, but I
imagine someone has run into it before.
I have a Hauppage WinTV (model 401) telivision card that I use as
a capture source. I know that Virtualdub can not select channels (a
shame, though I understand why), but I wondered if anyone knows
how to select the channel without starting WinTV and changing it
manually (by an initialization file, a regsitry entry, or some similar
method).
I tried changing
"HKEY_LOCAL_MACHINE\SOFTWARE\Hauppauge\wintv32\Channel"
(which actually does contain the last channel used), but it does not
affect the channel that comes up when starting WinTV (or Virtualdub).
Thank you for your help.
Brian Young
Posted: Nov 24 2002, 04:30 PM
Who says Virtualdub can't change cahnnels???
I have the ATI AiW Radeon 7500 (TV 7.7 version drivers), which uses WDM drivers (not supposed to work with Virtualdub), and it changes channels just fine.
In Capture mode, Video->Source->TV Tuner button->select the channel you want, hit enter, and apply.
I just used Virtualdub to change from channel 4 (local advertising) to channel 30 (CMT). No problems here. biggrin.gif
Brian Young
Neo Neko
Posted: Nov 24 2002, 07:20 PM
VirtualdubMod Alpha tester
Here is the trick. Can you tell the card to tune to a specific channel at a specific time unattended? I can do what you just outlined with my Hauppage WinTV GO 404. But I can't tell the software to do that when I am not there.
curmudgeon
Posted: Nov 24 2002, 11:18 PM
QUOTE (Brian Young @ Nov 24 2002, 10:30 AM)
In Video -> Source, I get three sections:
1. A "Video Connector" section, selectable (radio button) to Tuner,
Composite, or Camera.
2. A "Color" section for Brightness, Contrast, Saturation, and Hue
(selectable from 0-255)
3. A "Standard" section, selectable (radio button) to NTSC-M,
NTSC-Japan, PAL BDGHJ, PAL M, PAL N, or SECAM
And OK, Cancel, Default, and Help buttons on the bottom.
jcsston
Posted: Nov 25 2002, 01:42 AM
Matroska Dev
You have the Vfw driver for WinTV, Brian Young has the WDM driver with a WDM wrapper so it will work with VDub which uses VFW.
Use the Matroska file format
4 replies since Nov 23 2002, 08:14 AM Track this topic | Email this topic | Print this topic
<< Back to Capture
