Selecting Vieo Compresion, Cannot Select A Compresor
sakka252
Posted: Nov 6 2002, 04:25 PM
I am an experienced virtual dub user, however this is the first time
I have tried to capture video, and I am running into a problem.
When the I pull up the box "Select Vieo Compresion" there are
none to select from? Im sure it is simple but I'm lost. Please help.
greenval
Posted: Nov 12 2002, 02:47 AM
Im having the same (or similar) problem...though I do at least have the option if DivX driver to capture to.
If you get and answer let me know, and if I get an answer, I'll let you know!!
aquashack
Posted: Nov 13 2002, 11:26 AM
I can't be of much help here as I've got a similar problem...
When launching VirtualDub and going directly to the Video - Compression window, I see a full list of all codecs installed (including DivX - which is the one I want to use). However when I move to Capture mode and try to select a codec there, all I see is a very cut down list, containing only a few basic codecs.
Please help, as I'm desperate to start converting all my old video tapes to DivX!
Posted: Nov 13 2002, 04:13 PM
The list contains only those codecs which are capable of compressing the video format that your capture device is producing. Try changing your capture format to RGB or YUY2, or use "Set custom format."
aquashack
Posted: Nov 15 2002, 11:24 AM
Excellent! Thanks for that info.
Everything is now working well. Not quite sure what all those different formats mean or which is 'best' for my uses, but I guess that's a whole different topic...!
BaronVlad
Posted: Nov 15 2002, 07:25 PM
Terrorhörnchen
QUOTE (aquashack @ Nov 15 2002, 05:24 AM)
Best choice for capturing are huffyuv or an MJPEG Codec (i.g. Pic Video or Morgan or Leadtech)
Hochachtungsvoll
BaronVlad
5 replies since Nov 6 2002, 04:25 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
