Capture Device Problem
limak
Posted: Nov 5 2002, 03:16 PM
hello,
virtual dub is unable to recognize wfm capture device of my sytem. graphics card is nvidia mx400 while the tvcard is flyvideo 3000. any possible cause and remedy suggestion is welcome...
p.s. os:winme
JanMann82
Posted: Nov 6 2002, 04:03 PM
I can't say you why, but is wfm not a Windows Metafile
and you need VFW WDM Driver wich will work with virtualdub.
then see www.VirtualDub.com -> Documentation -> Howto insta ....
sorry when i missunderstood you
jan
limak
Posted: Nov 6 2002, 04:43 PM
i mean *WDM capture device*... sorry for the typo.
btw chipset of flyvideo 3000 is bt869.
Stefan
Posted: Nov 6 2002, 10:08 PM
This card requires "Windows 98 SE / Me / 2000 / XP with DirectX 8.1 installed" according to LIFEVIEW.
Video capture with DirectX (WDM) is another interface than VDs Video for Windows (VFW) interface.
JanMann82 suggested that you try to use a WDM to VFW Wrapper software to get the card working under VD. Maybe Lifeview provides such a software in the driver package, check it.
The installation of the wrapper for Windows 2000 is described in VirtualDub documentation: How to install the VFWWDM wrapper for Windows 2000 and in Low Resolution Capture with VirtualDub.
Please report the results with Windows ME and your card...
Stefan
limak
Posted: Nov 12 2002, 03:40 AM
hi again.
i reinstall winme (with norton ghost) and retry to capture. i am able to see video from the tv card but with the attempt to capture vd crashes. further attempts to capture bring the same problem- that i have already explained.
then i edit the registry a la windows 2000 tweaking, as stefan suggested, but nothing changes... cannot capture, along with a vd panic error ending.
so maybe there is no bt869 compatability yet...
fyi...
4 replies since Nov 5 2002, 03:16 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
