Poor Audio While Capturing, with pctv pro and sb audigy player
LL_NEO
Posted: Oct 23 2002, 02:45 PM
OK guys here is the prob. While my sound is OK with the pctv vision program, when I try to capture with virtual dub my sound is of very bad quality. Do you know what might be the problem?
greool
Posted: Oct 24 2002, 12:55 PM
Try wintvsel.exe.
I had the same Problem, then iI found this at http://www.hauppauge.de/sw_pci.htm.
1 replies since Oct 23 2002, 02:45 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
