Hi All I'm using Virtualdub 1.9.11 and opening a HD video file shown in VD as 25fps.
I need to extract a stills file, captured at 1 fps, i have set the conversion rate to 1 fps and created a stills file, however the file seems to have stills captured at 6 (ish) fps ???
the window, open during the capture process shows expected number of stills at 5960, which would be correct for a video of approx 99 minutes long, this is correct.
However it captures at about 6 fps and stops processing, normally after about 15 mins of video, which is about 1/6th of the video.
So the processing window has correctly calculated the number of images to capture and processed accordingly, but has taken 6 fps instead of 1 fps, resulting in the right number of images but stoped 1/6th into the video
Any ideas guys ??
Quite urgent
Thanks
Steve |
