| leop2p |
| Posted: Jan 29 2013, 01:37 PM |
Hi!!!
Could you please help me to set up the capture parameters? I choose the capture device, VD says it has connected to my device, but when I start the testing capture, DB tells me that unable to start capture. I can't see any video input stream. There's a log:| QUOTE | Connected to capture device: iconBIT ARU65Duos (DirectShow) [!] CapDShow: Failed to build filter graph: render capture pin (hardware display) [E] Error: No capture filename has been set. Use File > Set Capture File... to choose a location for the capture file. [i] Starting test capture. [!] CapDShow: Failed to build filter graph: connect capture -> grabber [!] CapDShow: Failed to build filter graph: render capture pin (hardware display) [!] CapDShow: Failed to build filter graph: render capture pin (hardware display) [E] Error: Unable to start video capture. |
Thanks!!! |
| Abrazo |
| Posted: Jan 29 2013, 07:28 PM |
Can it be that VirtualDub was started two times ? > http://www.das-werkstatt.com/forum/werksta....php?f=7&t=1924
Recently I made a description on how to capture in this thread: > http://forums.virtualdub.org/index.php?act...=ST&f=6&t=21444 |
| leop2p |
| Posted: Jan 29 2013, 08:22 PM |
Made all as you said. But all I see is no preview and error at the log that says: | QUOTE | CapDShow: Failed to build filter graph: connect capture -> grabber [E] Error: Unable to start video capture. |
PAL B (Tried to check the VCR input setting with no result); All unchecked in the Timing settings; 720x576 / 25 fps; Compression: None (YUY2); Checked the Audio capture, Audio playback; Says that VD connected to capture device (DirectShow).
What I made wrong?
Thanks!
P.S. I started VD only one time and there's the only one VD proccess running in the task manager. |
| Abrazo |
| Posted: Jan 29 2013, 09:36 PM |
I hope someone else can give you a correct answer.
Still one idea : In VirtualDub's Options-menu > Preferences > Display > uncheck "Use DirectX overlay surfaces" or even uncheck "Use DirectX for display panes" If it does not help you may check them again. |
| Posted: Feb 2 2013, 08:04 PM |
The most likely cause of this error is that the capture device is configured to produce compressed output in a non-trivial format like MPEG-4. Video > Capture Pin and Video > Capture Filter are your best bets for reconfiguring this. |
| leop2p |
| Posted: Feb 3 2013, 10:23 AM |
It captures normally from 64-bit VD, but in 32-bit don't. I tried everything. |
| Abrazo |
| Posted: Feb 3 2013, 08:44 PM |
I have no experience with a mixed environment (32-bit / 64-bit).
For as far as I know, the 32-bit installation of VirtualDub needs 32-bit drivers for communication with the capturing device and also 32-bits versions of audio- and video compression codecs... Are these available on your pc ?
For the rest, why would you worry if it works with 64-bit ? The resulting AVI will play as good on a 32-bit Windows as on a 64-bit. |
| Posted: Feb 9 2013, 08:43 PM |
What's likely going on here is that the capture driver works fine with either 32-bit or 64-bit programs because it's a kernel driver, but only a 64-bit codec is installed for MPEG-4 decompression. Installing 32-bit ffdshow might do the trick. |
