| Anoopbr |
| Posted: Apr 12 2010, 03:04 AM |
I used to use AvertvUltra(M113) card for Capturing and used to work extremely well. Now they have stopped this card and launched Aversuper009(M733), With this card first time when we install it will work(capture) after that when ever we restart the PC the video doesnot appear, sometime it just flashes and goes off. I have seen this in two or 3 pcs .Can anyone help me??
Regards
Anoop |
| Oxyandy |
| Posted: Apr 12 2010, 03:14 AM |
you should send exact message to manufacturers website support... otherwise I suggest... have you tried any different driver versions ? check website for newer driver ?? |
| amitava.s.guha |
| Posted: Jul 4 2011, 10:03 AM |
Hi Anoop,
Were you able to resolve this issue? I recently bought the AverTV Super 009 card and not able to get the right settings for capture with Virtualdub. I am on Windows 7 OS. Earlier, I had a Pinnacle TV tuner card which worked seamlessly with Virtualdub on Windows XP.
If you were able to solve this, kindly post the resolution.
Thanks in Advance - Amitava |
