| DocKurt |
| Posted: Aug 29 2002, 08:09 AM |
Hello!
Hope you can help me: I use the latest version of virtualdub, and it worked well till last week (capture). I donīt know why, but if i now try to open the capture-dialogue , the program comes with an error 418 (is in use by other programs...). I could not remember that I changed/installed somtheing on my computer. I tried to re-install the wdm-capture drivers- nothing helped. But the capturer device works-I can capture with the program that was shipped with my Geforce (Winproducer).
My configuration: MSI KT330 Ultra-Aru Motherboard /1400 AMD Athlon /512 MB DDR Ram MSI MS-8871GF 4 Ti-4400 Pinnacle PCTV pro card Soundblaster Live Player 5.1
Thanks in advance DocKurt |
| SillKotscha |
| Posted: Sep 3 2002, 06:20 PM |
smart Moderator
just close your TV-application which is for sure open and "working" behind...
| DocKurt |
Posted: Sep 4 2002, 12:19 PM |
No,it īs not- i uninstalled everything which could touch this "area" ! : |
| SillKotscha |
| Posted: Sep 4 2002, 01:49 PM |
smart Moderator
indeed strange... what are you doing??
I tried to (re)produce the error message... I only get your mentioned message, if I try to open two cap-devices but that won't work as everyone knows (e.g. as I said TV-app + Vdub_capture or open vdub->capture avi and then open another vdub and -> capture avi )
After (re)starting your system and you don't open any application, is it possible to open vdub -> capture avi?? ... ok, you won't have a clear picture to capture but it's just to see if this error occures as well...
if not, then I don't kow because I usually would open my TV-app -> close it, open vdub -> capture avi ... and here we go
maybe after you closed your TV-app, your drivers are still in use (e.g. you'll here sound although you closed your app)...
