Aspect Ratio
selliasrev
Posted: Dec 3 2002, 12:30 PM
I have 16/9 film ripped. In VirtualDub input view it is displayed with wrong
size (720/576). Output avi file also have 720/576 format. The output avi then
can only be displayed as is. Do I have to use resize filter? If so, does it mean I cant use direct stream copy? Or there is another solution. (fast if possible)
Thanks
selliasres
BaronVlad
Posted: Dec 3 2002, 04:07 PM
Terrorhörnchen
use ffdshow-alpha Version 2002-11-13 filter for the playback, you can change the aspect ratio without encoding again.
Get it here:
http://sourceforge.net/projects/ffdshow
Hochachtungsvoll
BaronVlad
selliasrev
Posted: Dec 4 2002, 08:45 AM
Thanks.
Now that I installed ffdshow, how do u tell windows media player/winDvD
to use it?
ChristianHJW
Posted: Dec 4 2002, 11:39 PM
'start' 'program files' 'ffdshow' 'configuration' ...
selliasrev
Posted: Dec 11 2002, 08:21 AM
I do visited ffdshow home page but there isn't doc to read.
Now after installed ffdshow, the avi files generated by
VirtualDub show no longer images. the avi files I grabed
elsewhere work normally. (No filter is active in ffdshow) ...
Do I need to reboot after reconfigure ffdshow?
outlyer
Posted: Dec 11 2002, 03:31 PM
Spanish Section Mod
QUOTE (selliasrev @ Dec 3 2002, 01:30 PM)
720x576 is the standard PAL (mainly European) resolution. PAL DVDs are usually in this resolution, although aspect ratio may be 16:9, 2.35:1 or whatever, and yes, you should resize when encoding to the appropiate TV aspect (16:9 or 4:3) and then crop the black lines (so you'll get the real cinema aspect (16:9, 2.35:1, 1:85:1...)).
5 replies since Dec 3 2002, 12:30 PM Track this topic | Email this topic | Print this topic
