Encoding Problem, maybe encoder has errors
Aldieb
Posted: Nov 22 2002, 10:21 PM
Ok. you know, i wont post the problem here i could fix it alone.
virtual dub works very well, but last time i wanted to encode a video strange things started to happen. the expected time looked like this: 48:16:23:18 and the file size just growed to about 3 gb. so i reinstalled any codec and got a new vdub version. nothing did help. i asked questions through every irc, no one was able to help.
i didnt install anything except the new Nimo Codec pack and Avisynth and some times i had to reinstall divx 502. but it is a vdub internal problem i think, cause every codec works with tmpgenc or other programs. even flask had'nt any problem. just vdub.
so now. if anyone had the same prob or knows what to do please tell. thx a lot
Aldieb
Posted: Nov 23 2002, 05:11 AM
That's too bizarre, dude. What video codec are you trying to compress to?
Aldieb
Posted: Nov 23 2002, 08:21 AM
yeah you're right. thats bizarre. but there is no one else smile.gif.
i tried every divx and xvid. but nothing works. its an internal problem as i said. direct stream copy doesnt work either. last night i did relaize this one smile.gif
Aldieb
Aldieb
Posted: Nov 23 2002, 09:49 PM
do i have to reinstall my hole system? thats the only option i didnt try so far. and i hope that i need not to do it.
Aldieb
Posted: Nov 23 2002, 10:44 PM
ok guys. after decoding every source-detail of vdub and not finding anything useful i just tried to exit every not-needed program the system was running. then i started to encode. within 2 minutes the estimated time showed 2 hours and 15 minutes and a 350 mb target file size.
i am thankful to everyone who had tried to solve this. this thread is closed smile.gif
Aldieb
4 replies since Nov 22 2002, 10:21 PM Track this topic | Email this topic | Print this topic
